Spaztic computer screen
My Compaq CQ58 laptop won't stop doing this:( I just need a solution to it if there is one available! I have tried taking out the battery and holding down the power button and it still doesn't work:/ HELP?:(
  • 77 Answers
2 reasons from what I can see in the video.
1. LCD screen is cracked
2. Graphics Processing Chip has overheated causing the display to malfunction. I have a youtube video on a desktop computer that I had repaired with the same problem CLICK HERE for the video.
CLICK HERE FOR LIVE TECH SUPPORT
Posted on May 04, 2013
  • 4088 Answers
SOURCE: Compaq presario a900 model a931nr wont boot, help!!!?
Sounds like the battery is in trouble (discharged) or the charger is bad. If you have access to a voltmeter, read the voltage across the power cable plug with the pack plugged into the house outlet socket. Does a lamp work when plugged into the same socket? If the pack checks ok, then the battery may not be able to receive charge. Have it checked by a dealer.
Posted on Jul 16, 2009
  • 243 Answers
SOURCE: I have a gateway laptop model mx6454. The
Your power adapter my be loose on the motherboard which would require soldering it back on.
To confirm if this is your problem plug your laptop in and press the cord in and press the power button continuously if it powers on thats your problem.
When pressing the cord in it may take a couple of different angles before you find the right one so press it in if that don't work press it in and lean on the left, then to the right, up, down etc.
I am experiencing this problem right now I have clamped my cord for a temporary fix.
Posted on Aug 28, 2009
steveparlin
  • 61 Answers
SOURCE: compaq presario cq50-100em wont start up
I'm sorry to say this sounds like a system board failure. On my HP DV200t, a very similiar issue occured, eventually only the led where you plug in the power cord would turn blue. I replaced the system board and all the issues went away.
Hope this helps, and I am sorry to be the bearer of bad news.
Posted on Aug 31, 2009
  • 84 Answers
SOURCE: My Compaq laptop will not boot up. It gets only
Tturn on your computer, then, before the windows boot screen appears, press the F8 key, this should bring up the start options , if it does not, turn off , turn back on and try again.
On the start options use the up/down arrows on keyboard to select "last known good configuration", press the enter key. Windows should start as normal if it does not do the process again but instead select "safemode" .
Posted on Oct 14, 2009
TimHuntJr
  • 88 Answers
SOURCE: When i push the power button, the little blue
sounds like *********** board is shot the only solution is to change it is costly i advise you to buy another laptop
Posted on Nov 09, 2009
Need a manual for a Compaq CQ58 Intel Pentium laptop
In the top bar or you can download complete as a pdf :)
http://www.manualslib.com/manual/491999/Hp-Cq58-200.html#manual
Feb 23, 2015 | HP Compaq Cq58-252Sa 15.6-Inch Laptop...
How can i adjust brightness for hp compaq cq58 laptop
ccfl screen
all this old are dead or bad. or turn yellow. all do.
all did.
all you can do is turn up the brightness or replace the tubes
CCFL are back lamp tubes. for the SCREEN
CQ58-nnn what, what it the full service tag Partnumber.
ill toss the 50 sided coin and land on cq58-100
the 100 model, is LED and not CCFL lamps
so what OS is running? Windows 7?
i yes, see the users guide on bightness.
read page 26
the magic F3 key.
if the key fails, that means, the drivers loaded on this pc are wrong.
http://h10032.www1.hp.com/ctg/Manual/c03308662
correct drivers are alway here at REAL HP (we are not hp)
im picking w7-64bit now, if not 64bit go back and change that first.
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-cq58-100-notebook-pc-series/5259203
May 03, 2014 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
Cant adjust the screen brightness of compaq CQ58
Some monitors, have an options in the driver section, for others, NVIDIA drivers, have options for contrast of brighness.
others laptops have a key convinations, like FN + another key to bright or contrast the color. look your keyboard for those keys,
sometimes has a little sun design
Dec 03, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
How to replace an inverter for a hp compaq cq58
Remove the screen surround you will see it at the bottom of the screen
Aug 12, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
Virus? Hard Drive Failure? Help Please!
This is because the Hard Disk Drive has failed and you need it replaced. If your warranty is still valid, take it back for repairs or buy another hard disk drive altogether.
May 19, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
What now
From the boot manager screen you have to go
Change defaults or choose other options.
Then select Choose other options.
Then select Troubleshoot
Then select Advanced options
Then select Startup Settings
Then click restart.
This will restart your computer and will give you a list in which you will select from. It should be option 4
May 18, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
How do i turn webcam on in chatrooms
Look for setting in the "chatrooms" software you are using to setup the webcam, if the option is available. There are Many Chat sites.
Mar 28, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
Boot image did not authenticate
My laptop compaq CQ58 does not start up so it gives me this message selected boot image did not Authenticate. Press <Enter> to continue. If l press continue it switches off, Pliz help wat should l do
Dec 02, 2012 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
Computers & Internet Logo
David Payne
David Payne
