Question about Nextbook Premium 8 Se Android
Freezing when i boot up nextbook.
Yeah, whenever i boot up my nextbook se8, it freezes and i have to wait about 10 minutes to play it again. any help please...?
  • DAMASTER7 May 04, 2013
    all right thankx i will try this
My nextbook tablet is in safe mode and won't let me turn it off or play my games. how do I fix it?
Hi ( long press ) the power button . select POWER OFF. and then .,.(, LONG PRESS.) the POWER button again to turn it back on it should boot up . Cheers
Oct 26, 2016 | Nextbook Tablets & eReaders
Nextbook NXW9QC132 freezes
Hi Karla Call for expert assistance +1(518)348-9393 Thank you
Aug 24, 2016 | Nextbook Tablets & eReaders
Will not turn on. Get a rectangle with an orange rectangle inside.
It may be "freezing up". Press and hold the start button for 10 seconds. Release and wait another 10 seconds. Press to start as you would normally. It may start up but could take a minute or two.
Aug 07, 2015 | Amazon Kindle Fire HD 8.9"
Can't boot my tablet.when it gets to the sunflower screen it freezes.
On the top of tablet where the volume and the power button..Press both buttons down untill you see the updating pops up.
scroll down till you see the factory reset and press the power button. It should open your tablet.
Apr 07, 2014 | Nextbook Premium Series Next7P12
ASUS T100 stuck at preparing automatic repair message will.not reboot
Hello there, i just owned a brand new Asus T100 for 2 days and today on the 3rd day after purchasing, i faced problems during boot/start up where the laptop gets frozen on the Asus logo screen.
I tried holding down the power button for 10 seconds and turned it on again. It ran a series of windows software updates before the start up, then after all software updates have been completed, the laptop resumed to freeze at the Asus logo screen again. I tried holding the power button for 10 secs followed by holding the power button and volume up button at the same time, to get into automatic repair/repair mode. THIS HELPS, get into the repair mode!
To cut it short, i tried the other advanced options as well as the restart button in the repair mode but to no avail. After carefully reading the different options in the 'advanced options' in repair mode...
Here's what worked for me:
1) If you're stuck at the Asus logo screen which doesn't seem to boot for ages or at least 10 minutes, hold down the power button for 10 seconds and let the screen turn black. (I did this with my charger plugged in, not too sure if it matters)
2) Count to 10 seconds. Switch the laptop on by HOLDING THE POWER BUTTON + VOLUME UP BUTTON at the same time. This will send the laptop into an 'automatic repair', followed by a 'diagnosing this PC' and after which you will see a blue screen which is the repair mode.
3) On the blue screen you will see 2 buttons, 'Restart' and 'Advanced Options'. Click on 'Advanced Options'. (DO NOT CLICK RESTART, it does nothing as you will get stuck again at the logo screen)
4) After clicking 'Advanced Options', click 'Advanced ....' (i forgot what exactly) and click 'STARTUP REPAIR'. This is the crucial part.Then follow whatever the system promts you.
5) Afterwards, it will attempt to repair your system then lead you back to the logo screen for startup.
6) Wait a few minutes and you should be able to get to your login screen as usual.
Hope this helps. I chanced upon it by guessing which would actually help me.
Nov 19, 2013 | ASUS Tablets & eReaders
My nextbook 8se keep freezing up. I've only had it for a couple of days and I'm already getting ready to take it back! Any suggestions to why its doing this?
I don't know if this is available on that model. Give it a try. Press and hold the power button until you get the menu with the option to power it off. Press and hold your finger on the option to power it off for a few seconds. Hopefully you get an option to reboot the tablet into safe mode. This mode will disable all third party apps on the tablet. See if it freezes up. If it doesn't one of the apps is causing it to hang. This will at least tell you if the tablet itself is bad or if it is a problem with an app.
Dec 03, 2012 | Nextbook Premium 8 Se Android
Laptop screen freezes
this cud be a hardware issue where your voltage controller chip has blown the solution to this problem would be to replace the motherboard in most cases... but if u know someone who can do a chip level servicing it might help to ask them to replace the blown chip...
Sep 26, 2009 | ASUS R2H Tablet PC
Nextbook Premium 8 Se Android Logo
94 people viewed this question
Top Nextbook Tablets & eReaders Experts
D. E. Hev
Tom
Dustin
Dustin
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
