The color on the monitor is all white and all i get is sound???????
  • 5,568 Answers
Check the video cable at both ends to ensure the plugs are seated well.
If they are, you may have a failed video card which can be a plug-in card but with many systems, it is part of the motherboard.
Unless the system is newer (<3 yrs), it may be time for a replacement monitor or system.
If you have a friend with a working system, connect your monitor to see if it is still working or borrow a known working monitor to connect to your system.
This way you can determine which end of the video chain has failed.
Posted on May 11, 2013
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 40 Answers
Push menu or settings button located on the monitor then adjust brightness, whit contrast, color by pushing arrows. just dink around with it blind until something happens. everything is plugged in properly
Posted on May 09, 2013
Where do the 4 wires go that come out of monitor plug that has no connector attatched to them
sounds like someone cut the wiring that went to a sound system perhaps
Jan 28, 2015 | Computers & Internet
Rgb internal wires which ones can u use to convert it into red, white and yello at other end for tv
RGB is a term that means the guns in the crt or other display are only driven by amplifiers for that color. So you have to have seperate signals and inputs for red,green and blue. Those come from the source in that method. They are then fed into the monitor for which each of those colors has its own channel and amplifier. If you dont have something that is supplying the RGB singals then it is of no use. The colors that you listed as red white and yellow are for COMPOSITE video with AUDIO. The yellow is the whole video signal and the red and white are stereo sound signals. No attempts at making that work will correct this unless you buy a converter.
May 14, 2014 | Philips 107E66 17" CRT Monitor
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
PL2010m displays two colors stays on just blue and white
Sorry, but this sounds like a controller issue. Are you able to open the monitor's menu? If yes, try the monitor on another computer with other cables, if that doesn't help its a internal problem. The only thing you could try yourself is opening it up and reseat all of the cables. If that doesn't help, you should contact a professional or consider replacing the unit.
May 29, 2010 | Planar PL2010M 20" Flat Panel LCD Monitor
Monitor turns green
This sounds like a problem with the cable. Monitors have Red, Green, and Blue signals. I have seen it where the cable has a short, or the plug has a bent or loose pin, and this causes the monitor to turn green.
It is also possible, but doubtful, that the video card is trying to run it as a Black and White monitor. B&W signal is sent over the green channel.
Jul 29, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
LCD Monitor pixels that should be black are white
The contrast of the monitor is very low. reset the monitor settings using the menu button in the monitor.
Apr 17, 2017 | Sony STYLEPRO SDM-S71R/B (Black) 17" LCD...
LCD MONITOR WHITE COLOR PROBLEM
No but I have a Westinghouse 20.1 in monitor doing the same thing. If anyone out there has a solution please email me at meet0818@yahoo.com. Include Westinghouse monitor on subject line.
Sep 16, 2008 | Computers & Internet
Blank white monitor
mostly the problem is cause by loose flex cable only connected to your lcd panel board. check if it mounted properly, otherwise the lcd panel board may be defective.
Aug 16, 2008 | Sony Computers & Internet
Weak red and green color of Sony GDM500PS
sounds like another IC has failed. there is one in this chassis (21N3) that causes similar problems. but i cannot recall what it is or it's IC designation, but i do beleive it is on A board
Jun 11, 2006 | Dell UltraScan P1110 21" CRT Monitor
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
