Question about Motorola Mobility RAZR V3
Ringer When I call my girlfriends phone, she has a 20 - 25 second ringtone, but she only hears 10 - 15 seconds of it then it says missed call. When I am calling it, I let it ring all the way till it goes to voice mail, which is about 4 rings. I play the same ringtone on my phone and when she calls, I hear the entire ringtone. Any ideas? THanks
Try going to the fowarding or the voicemail, u will get to choose how long it rings or u can just turn it off which will automatically foward to voicemail, hope that helps
Posted on Aug 10, 2007
SOURCE:
Sumsung gGT-S6102 -I CAN NOT HEAR RINGTONE
My Dear Your Phone Ringer Default
So Please change Ringer and Ringin Sound Problem will solved
Aug 30, 2012 | Samsung GT-S6102 Galaxy Y DUOS - Unlocked...
Ringer delay
try copying your ringtones onto your phone instead of having them linked as ringtones from your memory card.
Feb 19, 2009 | Motorola Mobility ROKR E8 Cellular Phone
How do I increase my ring tone volume on my Moto Razor .?
You can set the length of your incoming ring to in the Call forwarding portion of the phone. Usually, it is set to 25 seconds. It can go as high as 30 seconds. To set the ringer to be longer or shorter, it goes by 5,10,15,... set of 5 increments. up to 30.
I would also recommend to use a factory set ringtone, set the profile to LOUD or OUTDOORS. With vibrate option on. Some downloaded ringtones don't play as loud.
Feb 10, 2009 | Motorola Mobility RAZR V3
Ringer too quiet
I do apologize for your issue with the quiet ringer. Especially if you have some important calls you are waiting for. Somethings to keep in mind. Everyday, you want to make sure you power down your cellular phone completely for about 10-20 seconds. That way it's refreshed.
Second, check your profile on the phone is on silent,meeting,outdoors,normal,etc? When you highlight either of them you can customize it. Make the volume higher. Also, for testing purposes set only factory made ringtones, which are already on your phone. Test them all out, and see which ones are sufficient. A lot of times if you download ringtones or use MP3's as ringtones, they are not loud enough.
I know this will assist you with your phone and ringers!
Cheers!
Feb 04, 2009 | LG Cell Phones
My ringer for my motorola e815 is to quiet
Is the volume all the way up.
You can select the ringer and vibration option, so you would not miss your calls, or you can try using other ringtones which have a higher tone.
Jan 28, 2009 | Cell Phones
No Ringtones?
it has ringtones pre-installed alreadyif the ringer is not working then you need to take it and have it replaced.
Sep 19, 2008 | Nokia 1100
BT Freestyle 2200
I think the internal ringer is a default and cannot be changed, but the external ringer can be changed.e03e2a2.jpg
Jun 26, 2008 | British Telecom Freestyle 2200 Trio...
My ringtones
Check the volume level of the ringer in the settings.
Secondly use a loud tone. There are some in this package http://www.exectones.com/
Mar 31, 2008 | RIM BlackBerry Pearl 8100
Problem with the number of rings
Remove the voicemail or extend ring time
don.t know is this code works world wide but you can try otherwise ask the provider to lengthen the ring time to 30 secs
then enter country code IE 61 for australia
* then vmail number IE 321 for optus
**30#
so your code should look something like this
**61*321**30#
then hit call.
remember the 61 and the 321 will vary on country and provider
Nov 09, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
95 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
