Question about HEWLETT-PACKARD CP1525NW Laser Printer
Repeating print trying to print a menu and the information gets repeated in a lighter print down the page....
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 63 Answers
It's the footer on the page which is printed, deleting the footer on the editing page will solve the problem.
Posted on Dec 17, 2013
Faded print
using the D-pad on your printer, scroll down the menu until you get to "maintenance"
Press OK
Scroll down to "clean printhead"
press OK
The printer will now make some noises and after about 30 seconds will say complete.
Now scroll down once more to "Print test page"
press OK
load paper and press the start button
Iff the printed page looks ok...job done. If still faint, repeat the above steps once more.
Nov 18, 2013 | Kodak ESP5250 All-In-One InkJet Printer
Only right side of the page prints - help!
Marks repeatedly appear at even intervals on the unprinted side of the page.
c00366165.gif Internal parts might have toner on them. The problem typically corrects itself after a few more pages. The paper path might need cleaning. Click here to go to the Print Defect ruler for more information.
Clean the device. The imaging drum might be low. Click here to go to the Print Defect ruler for more information.
Replace the imaging drum. The fuser might be damaged. Click here to go to the Print Defect ruler for more information.
Contact HP Customer Care Marks repeatedly appear at even intervals on the unprinted side of the page.
Contact HP Customer Care hi at the link given below, click on it and locate the page (halfway down) where it states this
Contact HP Customer Carehttp://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=ca&taskId=110&prodSeriesId=445194&prodTypeId=18972&prodSeriesId=445194&objectID=c00366102
Nov 04, 2010 | HP LaserJet 2840 Printer
Pages printed with dark horizontal lines the entire length of the page with a repeating (lighter) images.
I have seen bad laser scanners cause this...
A black line across the page from left to right, of various widths, at various intervals, all the way down the page.
First, though, I would reseat the toner cartridge. If the problem disappears, you are in luck!
Try another Toner Cartridge to see if the problem disappears.
It could also be a bad control board.
Good Luck.
Nov 03, 2010 | HP LaserJet 2420 Printer
Can't get my HP LaserJet 4MV to print. It printed yesterday but now it says "Printer not responding. The printer is on and I have checked all cables. Help
Can you perform a test print? Try this:
To print a Test Menu page
Press On Line] to take the printer off line.
2 Press [Menu] repeatedly until TEST MENU appears.
3 Press [Item] repeatedly until PS CONFIG PAGE (or another PS test page)
appears.
4 Press [Enter] to print the page. The page will print in less than one minute.
5 Press [On Line] to place the printer back on line.
Did the printer print? If so, you may have either an nterface or cable problem.
Oct 23, 2009 | Office Equipment & Supplies
Xerox Phaser 6360N ghosting images on each page
Is it a ghost of the image or just a repeating defect? In the menu, there is a repeating defect information page that you can print out. Depending on the spacing of the defect, you can determine which component it is.
Mar 10, 2009 | Xerox Phaser 6360/N Printer
Im running 12"X18" sheets from the manual feed tray..
You should print the "Repeating Defects Page" Using the printer's front panel menu keys perform the following steps:
  1. With Information highlighted, press the OK button.
  2. Scroll to Troubleshooting by pressing the Scroll Up or Scroll Down button.
  3. Press the OK button.
  4. Scroll to Print Quality Probelms by pressing the Scroll Up or Scroll Down button.
  5. Press the OK button.
  6. Scroll to Repeating Defects Page by pressing the Scroll Up or Scroll Down button.
  7. Press the OK button to print the Repeating Defects Page.
Most likely you have a defect on your magenta imaging unit. Switch the Magenta and Cyan imaging units and try the test print....if you have blue spots 3 3/4 then it is the imaging unit (drum). If not you may need to change the belt cleaner assy.
If it isn't the imaging unit then it will be a problem with the fuser rollers, so replace the fusing assembly.
Jan 15, 2009 | Xerox Phaser 7750DN Laser Printer
Print smudges and ghosts down the page
Usually ghosting is caused by the fusing unit, which usually means that it needs replaced to be honest. You could try getting into the fuser and giving the rollers a wipe, they may have dry toner on them which could also cause the fault. but i'd say the fuser could need changed!!!
Hope that helps  (",)
Dec 11, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
My HP printer 2420 leaves "ghost" prints on the pages.
This can be caused by one of two things.
1. faulty wiper blade on your toner so that the previous image in not being wiped off the drum.
2. worn fuser sleve.
To work out which it is you will need to do a half stop test: print off a normal document then when it is about half way through the printer ( unfortunatly you may have to repeat this to get the timing right) open the front cover. remove the toner cartridge. if you can see the ghosting on the page the it is the toner. if its not there then its a new fuser. to save on money and if your confident enouh you may be able to just chane the fuser sleve depending on the state of the fuser on a whole.
hope this helps
feel free to email me if you have any other questions:
pete@wedotoners.com
Oct 21, 2008 | HP LaserJet 2420 Printer
Printing issue
You need to replace the fuser. What is occuring is the teflon coating on the heat roller is worn and picking up some of the image off of the page and repeating it in a ghose like fashion.
Not a difficult replacement.
Mar 04, 2008 | Xerox Phaser 6200DP Laser Printer
Shadows on prints
Hi, The problem your having sounds like a Fuser . The Fuser will cause printed text to give a ghosting look down the page were it repeats itself.
Nov 30, 2007 | HP Color LaserJet 2600n Printer
HEWLETT-PACKARD CP1525NW Laser Printer Logo
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
