Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
40 hp mercury
Keeps blowing 20 fuse on top of motor inside cover
    Champion:
  • 231 Answers
Hi Greg,
You Have A Short!
If You Put A New Fuze Does It Blow When You Turn The Key On, Or
As You Try To Start Or When You Operate The Trim Switch.
Try To Acertain What You Do When It Actually Blows The Fuze
Let Me Know
Cheers
Gordon
Posted on Nov 04, 2013
Will it hurt to replace the 20 amp fuse in my cigarette liter to a 25 amp it keeps blowing fuses
I am wondering if the fuse blows instantly or whether it lasts a while?
Fuse ratings for cars are usually mean or average values so a 20 amp fuse needs roughly 40 amps to cause it to instantly fail. I have not heard of a cigarette lighter needing that much current so I guess there is a fault that should be located and cured before you have a fire.
Maybe it is the element that is faulty...
I think fitting a 25 amp fuse would be slightly foolish...
May 12, 2017 | Cars & Trucks
2001 Mercury Mountaineer keeps blowing the PCM power diode (fuse #19)
Check all of the battery terminals and cables and check the wires on the starter/selonoid, start from the battery and follow the cable out and check all conections , clean and tighten them and if it still does it the starter/selonoid is bad and needs replacement...
Sep 18, 2008 | 2001 Mercury Mountaineer
Mercury 1989 60 HP Outboard Motor manual to find gas to oil ratio
50:1 But if your doing mostly low rpm cruising (trolling) then you could reduce that a bit to 75:1 to help reduce smoke. If you do mostly mid to higher rpm cruising, then 50:1 (1 pint to 6 gallons. )
Or 200mls in 20 liters if your Canadian.
Feb 26, 2016 | Seloc Mercury Outboard Repair Manual, 1965...
Where is the thermostat on a 1993 mercury 40 hp classic outboard motor
If it has one,it will be at top of block on port side close to the top plug,cover plate held in by 3 bolts
Jan 25, 2014 | Boating
Blower motor fuse
always start on a switch when they all they cause that
Nov 13, 2013 | 1998 Mercury Mystique
Cigarette lighter for 92 mercury grand marquis dose not work can not find fuse box
Theres a Black fuse box under the hood , on drivers side,that has fuses as well as the one inside under the dash. There will be a fuse diagram on the cover. It will more than likely be a 20 amp fuse. if no diagram you can purchase a fuse tester at your local parts store. some even cone with fuses. check the type of fuses it takes first and buy the assortment package they come with a tester. Believe it or no I use the fuses that actually light up when they blow. Makes it a hell of a lot easier to find which ones blown.
Jul 23, 2012 | 1992 Mercury Grand Marquis
94 Jeep Grand Cherokee 4x4 with the 4.0 Keeps blowing the fuse that controls the fuse box inside the jeep, its blowing a 40 amp fuse. I believe there is a short. but i don't where to look.
Get yourself a set of factory wiring diagrams,
otherwise your wasting your time
You have no idea what you working on, without
reference material
Helm.Com
Jun 20, 2012 | 1994 Jeep Grand Cherokee
Why does my mower keep blowing the 20 amp fuse
could be the safety switch for the pedal
Apr 23, 2012 | Husqvarna Garden
1992 gmc pickup keeps blowing heater fuses I replaced the blow motor and it keeps blowing
Have you replaced the blower resistor . some times they can cause the fuse to blow . You may need a muiltmeter to test the current draw on the blower motor circuit. the draw should be less then half of the rated fuse .( 20 amp fues draw is less then 10 amps) You did not say but does the blower work on high only or the lower speeds with out blowing the fuse ? if it does work on low or high with out blowing the fuse i would replace the blower resistor
Mar 06, 2011 | GMC Sierra 1500 Cars & Trucks
Electric sliding doors blow fuses but will work for a while after yu renew the fuse
There are 3 fuses for the sliding doors if your vehicle has the left and right sliding doors. There are 2 fuses if your vehicle is equipped with the right side only. There is a 20 Amp fuse - this provides power for the Sliding Door Control Modules and a 40 Amp fuse for each door. The problem is an electrical overload on one of these fuses. If the 20 Amp fuse is blowing, it is probably the door module(s) or the wiring between the fuse and the door module causing the problem. If the 40 Amp fuse is blowing,the problem could be the door module, the door motor/transmission, or the wiring between the door module and the door motor.
Jan 15, 2011 | 2003 Pontiac Montana
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
81 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
