Question about Frigidaire FDF50S Dehumidifier
Heater tube sensor
Can someone please tell me where I can find the tube heater sensor for this model? there has to an appliance repair shop, electronics shop that has this thing on hand. Can someond point me in the right direction? thanks
What is A5 on our frididare dehumidifier?
Hello Friend, this is Z. I am happy to assist you!
If you are receiving an error code AS on your Frigidaire dehumidifier, it typically means that your dehumidifier is experiencing a sensor failure. Because it is a smaller appliance, repairs are often more costly than the actual appliance replacement. Is your appliance still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Best of luck!
Jul 27, 2014 | Frigidaire FDL50R1 Dehumidifier
What is the part/how to find replacement discharge tube for DH400P? I lost the original hose because, initially, I was able to just drain into floor drain. Now, new location, I need to use the pump feature...
Try explaining what you need to an appliance parts supplier or find a current model DeLonghi dehumidifier and identify to a salesperson what you need.
Jun 12, 2014 | Dehumidifiers
Have a DDR583R with E-1 flashing blue, did not D-Humidify. Took unit to repair shop, 4 days later they called an said unit working fine, no repairs needed, cost 20.00. Came home, plugged unit in, works but...
If you're operating in area that where the ambient air temperature is between 40 & 60 degrees F. Like in a basement, where the air temp at floor level is cooler than at shoulder level, this could cause that reading. As dehumidifiers, unless they are Low temp models, will respond that way. Raising the unit up of the floor on to a sturdy table, counter top etc, that can handle the weight of the unit, plus a full bucket of water, will generally solve that problem.
If the unit, in all other facets is working as it should, do worry about it. If a sensor had gone bad and wasn't replaced, the unit wouldn't function at all. Also, keep in mind, that the repair shop's environment was different than yours.
Jul 13, 2011 | Danby DDR583R Dehumidifier
Humidity sensor not working correctly. Replace it?
The need for replacing it should be based on several things:
1. How did you determine it was the Humidity Sensor? Several other things, that are easily
solvable without having to replace parts, can mimic a faulty sensor.
2. How old is the unit? If it's 5 years old or older, it would probably be better to replace the unit,
rather than repair it.
3. Have you maintained the unit as instructed in the Owner's Manual? Regular cleaning and proper
storage when not in use, etc.
If, after answering all the above questions, you decide you want to make a DIY repair and want to order the part(s), Appliance Factory Warehouse is about the best supplier of parts out there. You can search for what you need at http://www.appliancefactoryparts.com/search/index.php
I hope this helps you to make the right decision. If I can be of further help, please contact me.
Jun 16, 2011 | DeLonghi DE500 Dehumidifier
Fan will not run
It's probably a common problem with these models: the fan motor causing a thermal cut off fuse to blow. I have the same problem. See this link on another site: http://forum.doityourself.com/humidifiers-dehumidifiers/177549-kenmore-dehumidifier-fan-stopped.html
Jun 23, 2010 | Kenmore 54351 Dehumidifier
Unit has stopped collecting water. Fan & Heater working ok. Been through problem page.None of those. Can you help please?
When it is below freezing outside, humidity drops inside.
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - 50% or less.
Jan 06, 2010 | Amcor Dehumidifiers
Tubing to drain the water into the container for the Amcor TC 120
take a sample piece of tubing to a home improvement,hardware,or appliance parts store to match it up.
Sep 29, 2009 | Dehumidifiers
E3 error
I got mine fixed tonight! It was not that easy but can be done.
After my last post, I called the customer service of DeLonghi. The agent can only refer me to the authorized repair shops but she does not know what “E3” meant. There is no shop in NJ where I live, and the closest one is in CT! One of the two shops there knows right away the E3 is the fault of a condenser sensor. He mailed me the part ($25) and I took the covers off (be very careful to record where the screws are from ---- they are not all the same size/shape, and also there are two small tabs on the top holding two cover pieces together, so don’t force it to open or you will break it). There is only one part looks like the same as the replacement part I newly obtained and it has a metal clip attached on the copper coils. Carefully replace the sensor on the coil as you find previously and plug the other end to the control board. It sounds lengthy but once you open the cover it will all become clear to you. Be patient and this can be done. Very glad to see/hear it is working now again!
p.s., the store first mailed me the wrong part (on the plug-in end it has two ridges rather than one) so I have to call them again to explain and they mailed me a different one with a single ridge. Apparently there are two types (old and new model) for this model.
Apr 26, 2008 | DeLonghi DE500 Dehumidifier
My dehumidifier is dead
WIZ huh? NAGEV says:
check the plug!??? - DUH! I also love ...
5) Remove and test the overflow cutoff switch.
6) Remove the humidistat and check it. Replace it if necessary.
7) If the unit still doesn't work, call an appliance repair person!!!
I guess he's only helping the repair person! Who would pay for this kind of advise? The layperson needs details not big words!
Jan 18, 2006 | Fedders A7DH65B2A Dehumidifier
Frigidaire FDF50S Dehumidifier Logo
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
john h
mike cooper
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
