Question about Lexmark Platinum Pro905 multifunction InkJet Printer
Touch Screen Stuck On Incoming Call Screen?
The touch screen seems to be stuck on the incoming call screen. If I press ignore, the noise sounds but nothing else happens. I've tried turning it off, hanging up the phone, putting them on the hooks, pressing ignore, and even opening the cover. Please help, this is a huge part of our business
  • Lexmark Master
  • 684 Answers
Just Unplug the Power Supply and replug it in after 5 minutes, That should be able to fix the issue.
Posted on May 13, 2013
Patrillica
  • 141 Answers
SOURCE: paper stuck while printing on lexmark X5470
You might have a little paper stuck inside your printer or just clean the pick-up roller with alcool and try it again.
Posted on Mar 26, 2008
SOURCE: x3480 cover open message
Ajkill is right, although his description isn`t very exact. Take off the complete scanner part: (back hinges first, then the blue arresting lever at the front), disconnect the flat band cable and the power supply for the scanner part and take off the complete scanner part. You´ll see a triangular part that goes in a slot of the dark grey cover which covers the rest. It should press againt a white lever which itself presses a little black switch sitting on the printed circuit board. If this white lever has fallen off the switch is always in "Cover open" position. To get it and reposition it (if it isn`t broken) you have to take off the dark grey cover which covers all the rest: take off the front screws and carefully lever out the sides with a small screw driver. Good luck with the repositioning, it is very fiddely and to see how and where it has to go you best use a magnifying glass!  But I could manage it and my printer is working now again. And good luck with fitting it all together again without breaking anything!
Posted on Apr 11, 2009
SOURCE: cover open
This is because the white plastic rocker switch which is very poorly attached to the micro switch at the back of the unit has become dislodged which means the micro switch is permanently open. Unfortunately due to its very poor design it has probably lost its plastic lugs which keep it attached to the micro switch.
Solution:
Locate the dislodged rocker switch, you may have to turn the printer upside down and shake it. If it won't come out, shake it after removing the cover...
If the plastic lugs are still in place then you are lucky. You will need to get inside the unit to refit it...
Open the unit as if you were about to replace the ink. Unclip the plastic prop at the top; you can pinch it using a pair of pliers. The cover will now hinge up much further, there is some minor friction still but it will come up to 90 degrees with a gentle tug.
It will now easily lift away from the hinges on the main body. You can remove the ribbon leads if you like. They go back again very easily.
You should now be able to get your fingers inside the unit. You will need a flat blade screw driver to assist you refitting the rocker. You should feel it clip into place if the plastic lugs are in place, even if they are worn. Test it and check it won’t fall off again easily.
It is much more likely that it will fall off again as the lugs have worn away.
This can be fixed by heating a medium sized paper clip with a lighter and pushing it through the side of the rocker, in the same location as the lugs. Cut the paper clip with the pliers, this will leave a 2-3mm pin sticking through the side of the rocker. Do this for both sides. Resite the rocker, then using a flat blade screw driver push the pins into the holes on the black micro switch. This should be quite easy as the rocker will still site in the correct position even if they are missing.
You will now have a fully functioning switch which will be far stronger than the original design.
Put everything back together, and test it.
Posted on Sep 03, 2009
  • 4 Answers
SOURCE: "Paper jam" message but no paper jam
I should point out that I got linked to this problem while looking for a solution to this issue with my e232, and the post was for other e232 users. This will not work on an HP F4235.
Posted on Sep 17, 2009
  • 309 Answers
SOURCE: WHEN I PUT THE BLANK PAPER AND PRESS PRINT, THE
It sounds like your paper stock may be too thick for the printer. Many printers do not handle paper heavier than about 26 lb. without some problems. The issue is the paper-rollers are not sufficiently strong to grab the paper, bend it toward the paper path, and then feed the paper into the machine.
Try using a lighter weight paper - 20 to 24 lb. max., and see if the printer does a better job for you!
Posted on Jan 04, 2010
I cannot slide open my LG phone. I hear my Messages but can't open the phone, no matter what
What is your phone model?
These answers were given assuming that you're using a LG smartphone with a touch screen :
Scenario 1 : Can you see the screen lights up and any sort of graphical image when you hear incoming message ?
A : If you can, and still you cannot slide unlock, your touch screen has gone. Get a replacement touch.
Scenario 2 : You cannot see anything on the screen. It stays dark when you hear incoming messages/calls
A : Your LCD has gone. A replacement LCD or a Touch/LCD combo would fix the issue.
I hope you saved your back by either way.
May 29, 2017 | LG Cell Phones
Net bot etab 0607 phone bug -- can't hang up, looks stuck on answering splash screen? (I have screengrab)
I saw in one of the screens: "Use power button to end call" .
Yours may be selected, so try that.
Chris Knee
Nov 13, 2013 | Generic Android eTablet OS 2.1 4GB 800 MHz...
Touch screen
Most likely the digitizer is no longer working. This is what detects the touch on the screen. The digitizer will have to be replaced or the entire screen.
Sep 09, 2013 | LG Optimus Net L45c - Black net10...
I want to configure... email settings in samsung mobile
Hello
1. Locate information concerning your particular email service's incoming POP3/IMAP and outgoing SMTP server addresses. Refer to the resources section below for a list of server settings that pertains to many common e-mail providers.
2. Turn on your mobile phone and wait for the standby screen to appear. Touch the "Menu" button on your screen and select "Messages" from the menu, press "Select" to continue.
3. Go to the "Settings" menu and press "Select," choose the "Email" option. Select the "Email setup wizard," press the "Select" button and hit "Yes" to continue.
4. Choose an email account type you wish to configure, press "Next," choose the "Account" option, press "Name" and use your keypad to label your new email account.
5. Press the "Next" button to continue with the email setup. Enter your email address and password, press "OK" to continue.
6. Enter the incoming POP3/IMAP information pertaining to your particular email service and press "OK" to continue. Select the "Outgoing Server (SMTP" menu item) and enter in the appropriate SMTP address for your email provider and press "OK" to continue.
7. Hit the "Select" touch screen button and wait for the "You have configured this email account successfully" dialog to appear.
GOODLUCK
Dec 15, 2010 | Samsung Star GT-S5233 Cell Phone
The touch screen does not work for incoming calls and to stop alarm. I tried calibration of touch input but the problem persists. Please suggest a suitable solution.
hi :) after few time abjust the calibration of touch input ,still pro come. the phone touch screen already damage. pls send for repair :)
Jul 07, 2010 | Nokia 5800 XpressMusic Smartphone
Screen touch not working
screen touch note working incoming is start but any opsion not open
please soluction
Jan 23, 2010 | i-mate Jama 101 Smartphone
No ring on incoming call
i had the same problem and went searching on line till i found the answer, press the # button it takes the mute off or puts it on.
regards patty
Nov 08, 2008 | Samsung SGH-D900 Cellular Phone
Centro GSM freezes on incoming calls
yeah the same thing happends to me ever scence i put it on my computer nad i just got it so yeh im pretty mad :[
Mar 19, 2008 | Palm Treo 500 Centro
Lexmark Platinum Pro905  multifunction InkJet Printer Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
