Question about Garden
Craftsman 21032 trimmer
I have a trimmer with the briggs and stratton 21032 engine, the pull rope starter has worn down on the interior and the teeth no longer engage the engine when pulled, ie no resistence occurs when pulling the starter cord, basically Im unsure of how to go about replacing this part, and what kind of price range a replacement or professional repair would fall in.
  • 376 Answers
SOURCE: Craftsman 32cc Line Trimmer pull start will not engage engine.
With a flashlight, look into the area just in front of the pull rope. You'll see the fins on the flywheel. Turn the flywheel with a small screwdriver until you see a bracket mounted on it. There's is one on each side. While holding the flywheel still with another screwdriver, spray penatrating oil on each one and work them back and forth a few times. You'll feel them loosen up. They are spring loaded and should snap back into place. Hope you can understand this. Good luck.
Posted on May 25, 2009
sleprocks
  • 147 Answers
SOURCE: starter rope pulled out and wont retract on
remove the starter cover and try to wind the starter rope manuly. the rope may have to be replaced if worn or broke..
Posted on Oct 22, 2009
FreeTech
  • 426 Answers
SOURCE: replace pull rope
there should be a retaining C Clip that will need to be removed from the shaft look closely!
Posted on May 23, 2010
SOURCE: replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Posted on May 26, 2010
suzukiracing
  • 200 Answers
SOURCE: Craftsman Model 21032: Pull start does not engage.
The plastic gear is probably stripped and will need to be replaced.
Posted on Jul 19, 2010
I have a 3hp briggs & stratton//the pull rope pulls freely//it does not engage the engine and turn the engine over
You probably need to replace the starter recoil. This is not a very expensive fix. Just be aware that this problem is usually caused by having to pull the starter rope excessively because of some other starting problem. Once you replace the recoil, keep your engine running properly.
Sep 07, 2014 | Garden
My 26 year old Briggs & Stratton 8 hp engine (on a
Did you remember to "wind" the cord when you replaced it. They normally have a spring type of set up that you have to wind before you bolt everything together.
Jun 30, 2011 | Briggs & Stratton Electrical Supplies
I start twice (when I pull starter rope) then the rope won't go back can I know what happen
Your starter/recoil unit has malfunctioned. Disassembly/inspection down to the point where you can get the recoil off will be required. Remove the engine cover screws. The recoil unit may be part of the cover or may be under it. You will easily be able to access it. Replacement parts for your mower are readily available.
Apr 30, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
My Briggs & Stratton 500 Series with model 10T502, Type 0495 B1, and Code 07011 855 failed to start after I cleaned it because the rope/string had no tension on it. What do I need to do to get it...
Does the starter rope rewind? If So and You removed the engine shroud you have to be sure the Pull Starter lines up with the flywheel nut. If the rope does not rewind the return spring is broken so you have to get a spring and remove the shroud and install it. I would take the shroud off and with me to get the spring and the place may install it for you. Bolt the shroud back on and you should be in business.
Aug 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
I have a 2500 craftsman power washer with a Briggs and Stratton engine. I used it about a month ago and it worked fine. Took it out yesterday and I could not pull the rope to get it started. I took out the...
It sounds like the pump is seized. Make sure any pressure has been released by pulling the trigger on the gun. Sometimes this will allow you pull the cord. If the pump is seized, a new pump would be in order.
Jun 15, 2010 | Briggs & Stratton Garden
Starter rope pulled out and wont retract on craftsman trimmer/edger 32cc convertible incredi-pull
Oct 22, 2009 | Craftsman Garden
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
