Question about Pool & Spa
Pool heater Sta-rite error code 128 r5
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 30 Answers
Hi please try to reset the circuit board, by turning the heater on/off from electric power, if don't work you got to replace the water temp sensor located inside the circuit board (BROWN WIRES) if still display the same problem try new circuit board.for this type the heater a master temp, pcb will work rev.R-13 Good luck. if you need part # let me know, remenber before replace any electronic parts in heater SHUTT THE POWER OFF.
Posted on Jun 15, 2013
  • 83 Answers
SOURCE: pool heater
If the heater fails to ignite after three attempts, the heater will automatically go into Lock Out. This is a safety feature on the heater.
Things for you to look at to see what is causing the problem are the display panel and diagnostic lights. When you turn on the heater, is it reading the correct water temp? If not, the Thermister has gone bad and will need to be replaced. When you try to start the heater, is there an Error Code displayed? Which of the Service Lights are coming on when the heater will not light? If it is the Serivce System, that is usually low flow of water. You may have a dirty filter, skimmer or pump basket full of debris, or a valve not completely open.
If the Service System light is the one coming on, then you will need to take off the top two halves of the heater and turn over the Display Panel. There are diagnostic lights on the back side of the panel. There may be a red light next to any of the following:
AGS, AFS, SFS, HLS, PS or THERMISTOR
If there is a red light next to one of these, then that is what has malfunctioned. If you need an Owner's Manual for the heater, you can find one online at the following link:
http://www.inyopools.com/owners_manual/sta-rite_heaters_max-e-therm.pdf
Posted on Jul 08, 2009
  • 83 Answers
SOURCE: Sta-rite heater error code 126
The 126 is not an error code, but it maybe the temp of the water that the heater is reading. If the heater thinks the water is 126 degrees, it will not start at all.
If the heater is reading the wrong water temp, the problem is the Thermister, which is the sensor that is suppose to read the water temp. You will need to replace this sensor in order to correct the problem with the heater. It is really easy to do!
If you have a manual for the heater, if you go to the Replacement Parts Listing for the Electrical System, page 53 in the online version, the Thermistor is Item #9. It goes into the left side of the manifold in the to place, between the first two manifold bolts.
Posted on Jul 10, 2009
  • 83 Answers
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Posted on Jul 14, 2009
  • 83 Answers
SOURCE: Sta Rite SR400 NG heater with code r=5
You can find an Owner's Manual online at the following site:
IF you have tried to restart the heater and received the same outcome, the r5, or S, is a badk control board. Sorry about that one!
What you may want to try is resetting the heater. You will need to put the SunTouch in the maintenance mode. Then turn off the heater, turn off the Circuit Breaker for the heater, wait about 15 to 20 minutes, then reverse the order. Circuit breaker, then heater, then try and start the heater without the SunTouch first. If it works, then try with the SunTouch.
  • 128 Answers
SOURCE: sta-rite lp heater wont start
Its the top. There is a membrane that controls the circuit board....the button pad is bad
Posted on Aug 30, 2009
Testimonial: "Thanks, I agree. After checking power supply all the way through to control board, placing a jumper from pins 9/8 and 9/7 on J6 I get lights on LED's"
Sta-Rite SR400 heater displays error r13
this is not an error code, its the startup sequence to your heater. after those numbers have been displayed you have to press the pool on button and set your temperature
Dec 28, 2014 | Pool & Spa
Starite 128 r5 error
ignition failure turn off then back on then see if ignitor is ok and check gas
May 24, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
My sta rite max e therm will not light
first ofall r 13 128 isnot an error code! blower comes on closes airswitch, then goes through all safeties, etc. need more info please ?
Nov 10, 2013 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Sta-rite Pool heater boot probem
bad temp sensor heater isn't reading to go on
May 14, 2012 | Sta Rite 333 Btu Natural Gas Heater...
Pool & Spa Logo
566 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
