Question about Exercise & Fitness
Trotter 535 incline stuck on 12 percent...after moved machine to mew location
4 Suggested Answers
  • 3 Answers
SOURCE: I have a Trotter 535 treadmill. I need to turn
visit wefixfitnessequipment.com and I will tell you how to flip the deck, tighten the belt and where to get lube. If you are planning on flipping the deck make sure you lube it with the right kind of lube!
B. Clark
Trotter/Cybex certified technician
15 years exp.
Posted on Oct 20, 2010
SOURCE: Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
Posted on Feb 13, 2011
ercupa190
  • 12223 Answers
SOURCE: trotter 535 treadmill auto start and stop
1) Lube the Deck belt, very well according with your instruction manual maintenance.
2) Lube the rollers bearing too
3) Measure the input voltage motor, if there are The motor need repair.
4) Measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. God bless you
Posted on Jun 09, 2012
The trotter cxt treadmill goes on 4321 and then goes to ERR2. Do you know what the problem is?
if you have any move on your belt your motor control board is dead but if you have move and stop after some sec. may be
1. speed sensor need replace or fix
2. incline system need set
Nov 19, 2017 | Exercise & Fitness
My treadmill is stuck on incline 12 and wont move up or down tried all the resets?
Go into engineering mode by pressing the stop and speed up button at the same time while inserting safety key. Once in mode, press the stop button once more then press the plus incline button. the incline should calibrate itself. If not then you might need a motor control board.. I have some in stock, shoot me a message if needed
Mar 10, 2015 | Exercise & Fitness
I have trotter 535 - the following comes on the screen: error 4 - AC line freq out of spec - does anybody know the fix.
Error 4 is a no frequency lock or noisy line voltage. The most common fix for this to install a dedicated outlet. This is required for most treadmills out there.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Jan 08, 2014 | Exercise & Fitness
Trotter 535 treadmill auto start and stop
Jun 08, 2012 | Exercise & Fitness
Incline is stuck, motor still runs?
First try to calibrate the incline as described in your owners manual.
Start the machine. Press the incline up button. While pressing the button, remove the safety key.
Release the inline up button and reinsert the safety key. The machine should run the full cycle, up to maximum elevation, then back down.
If the motor moves and then resets, you may have an incline motor sensor defect. You will need to order a new incline motor. The sensor is not available separately..
Dec 15, 2010 | Epic View 550 Treadmill
Apr 05, 2010 | Nordic Track NordicTrack Treadmill, A2550
Image 17.0 Treadmill is stuck in incline position and will not go down. I do not plan to use the include at all, is there a manual way to move the incline to 0? Any suggestions?
Hello there, The first thing I would try is to calibrate the incline on the unit.
Do this using the following procedure.
With the safety key out, press the stop button along with the speed up button while inserting the safety key onto the unit.
remove your fingers from all buttons, Then press the stop button one time. Now press the incline up button one time.
The unit should go all the way to the top, then return to the bottom.
Remove the safety key and reinsert it to continue using the machine
If this does not work you can manually move the machine to the bottom using this procedure.
Remove the hood cover b removing 2 screws in the rear of the machine and removing the first 2 screws on the foot rails on each side.
You can now lift the cover out of the way.
At this point you will see the incline motor located in the center of the unit pointing in a downward direction.
On the top of the motor there will be a small fan encased inside of a metal cover. There will be a flat head screw located inside the metal frame where the fan is. Rotate this clockwise to lower the unit. (the motor is geared very high it may not seem as though it is moving but it is) be patient that procedure does take a little while.
Any questions please feel free to leave another message on this link.
Good Luck! Tim
Jan 10, 2010 | Icon Image 17.5 S Treadmill
B. Clark
15 years exp.
Dec 12, 2009 | Endurance T3 Treadmill
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
