Question about Cyber Acoustics CA-3000 Computer Speakers
Re:ca-3000 speakers Hi!I bought the ca-3000 speakers back in 2005 at a local computer store and i tried to install them on my pc in the sound card,i have a sound blaster pci 128 sound card,i'm on the net quite a bit listening to music,and i followed the manual and they still don't work,i need help thanks much my nickname is snuffles,take care.
    President:
  • 2,022 Answers
See there is power on speaker and check the audio cabe connection is it properly connceted to audio jack in your sound card. bye
Posted on Sep 24, 2007
SOURCE:
No sound is coming out of my left speaker.
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 04, 2011 | Cyber Acoustics CA-3000 Computer Speakers
I need a new sound card for my Dell Dimension 3000 Where do I go , how much will it cost and how do I install one?
u can purchase from any local store go for creative sound card pci slot if u r in blore call 9972888885
Sep 06, 2010 | Dell Dimension 3000 PC Desktop
I just installed the Cyber Acoustics Model CA-2014 on my Dell computer and am getting no sound. It is plugged into the "green" port. I have tried the other ports but they do not work either. Do I need...
Disconnect the speaker source cable from your computer and to a MP3, CD Player, or anything else with 3.5mm headphone jack. If your speakers work on this source, you know are okay. And the issue lies on PC or Connector/Sound card.
Also please tell me, if you were able to hear sound with other speaker or headset.
Regards,
Riztech
Jun 15, 2010 | Computers & Internet
Speakers
check ur audio drivers installed correctly or not, then check whether u connected the speakers correctly or not... goto control panel--> sound and audio devices. click that and check whether your sound card drivers are installed or not....
Jul 02, 2009 | Dell Dimension 3000 PC Desktop
CAN'T CHANGE MY VOLUME SETTINGS ? COMPUTOR DOESN'T HAS SPEAKER HOOK UPS !
If the computer is the dell in title, then the speakers socket is the green jack , you find one at the back of computer, and one behind the front sliding panel.
If the computer is different from the one in title, then you may need to install an audio card into the computer.
In this case a simple solution may be installing an external audio card, klike the ones below.
SoundWave 7.1 Audio Adapter
USB Audio Adapter 3D Sound 5.1 CH Controller
If instead your computer has the audio jack , but has no sount it may need driver setup.
In that case follow instructions on link below to download and install drivers.
Dell Drivers and Downloads
Feb 18, 2009 | Dell Dimension 3000 PC Desktop
Dynex soundcard is installed however my pc still has no sound!
Hi Sammantha78,
I had a similar problem with my computer and I went and bought new sound card and installed it and I still had no sound. I then went and bought a new set of speakers and now i got sound. I suggest you test another set of speakers on your computer to see if it’s not your Altec Lansing speakers that is not working.
Sincerely,
Agent Xiong
Apr 15, 2008 | Dynex DX-SC5.1 Sound Card
Got no sound, no installation disc, I'm not that bright, and I'm only off from work today - help, please! Thanks! C
Hello cv21
Happy holidays
well, try to see if any back cable on computer is lose. depending your Operating system, go to your sound mixer on software, and see if volume is enable, and not in mute position, and all, other sound are up .
reconnect again your speakers to your PC,
good luck
Dec 26, 2007 | Cyber Acoustics CA-3000 Computer Speakers
Boston BA745 speakers bought. how to install drivers or whatnot on XP. Computer not recognize new speakers.
Mine dont work my pc wont recognize them. they were previously installed and now the driver isnt recognized. how do i fix it? do i download something?
Nov 25, 2007 | Boston Acoustics BA745 Computer Speakers
Speaker problem
Hi, Assuming that the speaker is plug in to the PC and power is also applied to the speaker - If the PC sounds comes out of the headset but not on the speakers, then the speakers are defective. Being new/recently bought, your best course of action would be to bring the unit back for replacement or at least the speakers since trying to repair it would void the warranty. Please remember to bring proof of purchase, warranty card or whatever document(s) are required for this sort of complaint. Good luck and kind regards.
Aug 20, 2007 | HP P5302M Computer Speakers
Cyber Acoustics CA-3000 Computer Speakers Logo
138 people viewed this question
Top Cyber Acoustics Audio Players & Recorders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Paul Bade
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
