Question about Mongoose 29" Ledge 3.1 Mens Mountain Bike
Mongoose bike manual
Front wheel to tight
SOURCE: childs 12 inch mongoose is new, but back wheel does not spin prop
The bikes are pre-assembled by a machine that overtightens the rear axle.  I had the same problem with my daugher's 12 inch huffy princess bike and my other duaghter's 16 inch Schwinn bike.  If you loosen the nuts on the back axle it fixes the problem.  I have read that the idea thing for these bike is to have them re-assembled and re-lubricated by a bike shop, but I thought this might cost as much as I paid for the bike.
Posted on Jun 13, 2009
  • 1137 Answers
SOURCE: how to remove the cog on back the wheel of my
You'll need some tools:http://www.parktool.com/repair/readhowto.asp?id=48 There are various tools for various freewheels. ACS is different from Shimano for instance. The procedure is pretty much the same for all of them:http://en.allexperts.com/q/Bicycle-Repair-1824/cog.htm
Posted on Sep 04, 2009
SOURCE: New Mongoose 700c Men's Paver bike: Mongoose 700
Local bike shop determined that both wheels were defective. I took the junk back to Walmart and got a refund... PROBLEM SOLVED!!
Posted on Dec 30, 2009
  • 70 Answers
SOURCE: Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
Posted on Apr 03, 2010
  • 407 Answers
SOURCE: Bought a 26" Mongoose Detour
For the gear problem.Find the shifter.Use a pair of pliers and loosen the nut where the cable is passing through the shifter.Now withe the pliers pull the cable tight.Very tight.Spray the shifter with WD-40.That should fix it.
For the front rim,tighten all the spokes.Pliers will work,but a spoke too; will make the job faster.
Posted on May 16, 2011
I cannot get my chain to stop coming off. How do I keep the chain from slipping off?
Loosen the nut that holds the back wheel and pull it back until the chain is tight and then retighten the nut. If when the chain is tight, the wheel is not on the rear frame, you need to take a link out of the chain.
Jun 25, 2014 | Mongoose 20" Mode 90 Boys Freestyle Bike
How to install front tire of mongoose bmx
Remove wheels, remove valve stem from innertube. remove tire by getting tire edge over rim. reinstall in opposite direction. If this seems difficult consult local bike shop for assistance
Dec 28, 2012 | Freestyle Mongoose Bmx & Owners Manual -...
How do you remove the front wheel of a 20" Outer Limit freestyle Mongoose bike?
if i remember correctly it is a 15 mm socket for a ratchet that is the tool that i use at the shop
Jul 10, 2011 | Freestyle Mongoose Bmx & Owners Manual -...
May 16, 2011 | Mongoose Cycling
Describe how to remove the front tire of a mongoose bmx bike
loosen the bolts on the ends of the axals of the wheels on the forks
Sep 03, 2010 | Freestyle Mongoose Bmx & Owners Manual -...
Dec 28, 2009 | Mongoose Cycling
Front wheel wobbles
More than likely the wheel is out of true. There are 2 choices,
1 Buy a spoke wrench and attemp to true the wheel. You can do this by spinning the wheel to locate the spot where the wheel goes furthest to one side then tighten the spoke coming from the opposite side. Do this slowly 1/2 turn at a time. Do not over tighten the spoke. It may be necessary to loosen the other side slightly.
Alternate spokes between both sides of wobble.
2 Take bike to a good local bike shop to be tuned and have the wheels trued. Most shops offer a tune up at low cost. A well tuned bike will last a long time.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 06, 2009 | Freestyle Mongoose Bmx & Owners Manual -...
Childs 12 inch mongoose is new, but back wheel does not spin prop
Dec 14, 2008 | Mongoose Butterfly Summer 12" Girl's Bike
Mongoose 29" Ledge 3.1 Mens Mountain Bike Logo
41 people viewed this question
Top Mongoose Cycling Experts
Rommel Balcita
M.R.
M.R.
Level 1 Expert
WTF Chuck.....
WTF Chuck.....
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
