Question about Measuring Tools & Sensors
Briggs and station 13.5 horsepower backfire and no compression
  • Measuring To... Master
  • 17,326 Answers
Timing issue, what proceeded this?
Posted on May 06, 2013
My Briggs and Stratton 23 horsepower motor model# 445577 on my Troy Bilt lawn mower won't start and I've changed everything the carburetors clean it gets fire but it backfires through the carburetor...
Take your flat head screwdriver and where the fuel/ air screw is tighten all the way then unscrew two and a half turns
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jonathan_8c3144e908769d21
Jul 07, 2014 | Garden
I have a Briggs Stratton 17.5 it backfired now won't start . now blowing gas out carb
sounds as you need to do a compression ck on the heads to see if you have a blown head gasket, If it does let me save you a lot of time n money don;t go 4 the head resurface and new gasket it won;t last long briggs sells a "short block" thats your best bet !!!!!
Jun 04, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Motor briggs
hi.. your inlet engine valve clearance need to be readjusted.(they are to tight)..the valve is not seating and allowing compression gasses to leak . this causes a pop/backfire on the inlet side...
Nov 04, 2013 | Garden
12 hp briggs backfires doesn't start
This could be a result of several different things, however the most common of these would be a sheered flywheel key. If this is the case it has throwed the motor out of time and is trying to fire while the exhaust valve is open causing the backfire and lack of compression to start. I hope this has helped.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Sep 30, 2013 | Simplicity "Citation 61"" 28-HP Briggs And...
Swisher 60" pull behind mower with 14.5 briggs engine. good spark and the starter will crank just fine. If I prime the carb with a little gas it will start imediately but wont continue. Any ideas..
Hi Andy, the carby will need to be removed and all jets cleaned out with compressed air. Basically its not getting enough fuel through the carby to keep running. Regards Phil.
Nov 28, 2012 | Swisher T14560 T - 60" Trailmower with 14...
Have a 26 horsepower briggs & stratton v twin want start backfires through carb.
Water in the bowl on the carb and or the spark plugs may need changed
Oct 03, 2012 | Garden
Briggs and straton 5 horsepower overhead valve lawnmower 1978 is backfiring through carborator
Remove the top engine cover and check that the aluminum flywheel key is not sheared, then remove the valve cover and ADJUST the 2 overhead valves. They have to be adjusted periodically on ALL small engines with overhead valves.
Aug 13, 2011 | Garden
Started using oil and smoking severely, all at once .
the best compression for a B&S is between 50 psi and 60 psi. if it's below 40 psi there is a problem with the rings or the tappet clearance (not letting the valves close all the way) but if it's smoking i would start with the rings...good luck
Apr 09, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
37 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
