Question about Vacuums
Vax turbo tool not working
My turbo brush tool Has stopped working. I have cleaned it and removed any hair and debris but it still won't spin. Please help.
  • 25 Answers
SOURCE: Hoover brushes stopped spinning
THE TURBINE WHICH DRIVES THE BRUSHES RUNS OFF SUCTION, A POOR DESIGN IN MY OPINOIN THEY GO BAD ON A REGULAR BASES. PROBABLY HAVE TO REPLACE TURBINE ASSEMBLY
Posted on Mar 27, 2008
reddevil6
  • 1673 Answers
SOURCE: Miele White Star SEB 204,
Yes, most likely the belt has stretch. Flat belts do this after a short time and need to be replaced when problems start with the brush roll not wanting to turn. Also check the brush roll, make sure that the ends turn freely, if not, then replace it also.
Posted on May 20, 2008
SOURCE: roomba keeps saying clean brushes yet are clean!
Remove the Yellow connectors on the end of the brushes and clean around the pin well. If there is too much there, the roomba thinks there is something stuck and goes into clear mode (as if there is a chord stuck).
Posted on Feb 24, 2009
SOURCE: Brushes won"t spin, Model F7452-900
SAME PROBLEM Hoover F7452 900 brushes won't spin; cleaned and move freely, under filter slid out and cleaned, still froze up....had it a little more than a year so probably no warranty.....assuming turbine related and will take it to dealer......how common is this problem with this model???
Posted on Nov 11, 2009
SOURCE: Brush stopped spinning
If you've had the brush out to clean it you need to re-set the trip switch which is a red button at the right side of the brush simply press it in till it clicks.
Posted on Sep 08, 2010
How do I clean the brush area after using my Pro Heat?
The brush or brushes (depending on your model) can be removed if needed. Routine cleaning should just require removing hair and debris from the brushes and wiping the area around the brushes.
There should actually be very little hair or debris around the brush roll if the carpets are thoroughly vacuumed by a properly working vacuum cleaner before being cleaned.
Jan 22, 2017 | Vacuums
Shark navigator uv440 pet brush won't roll
The hair in the bearings. I take pair of needel nose peirs. Its hard,but it only i found
Jul 14, 2014 | Shark Helmet NV22L Shark Navigator Upright...
Turbo tool used only once or twice, already brush moves so slowly it stops when I try to use. Brush can actually be stopped by hand. Manual says nothing at all about the brush ie. HOW to take apart to see...
It takes a lot of suction to spin the brush. First make sure the suction is good. Make sure the bag and/ or filters are clean. Replace if necessary. Most turbo tools can be opened up to clean. Most have a lever that allows you to open it up to clean hair, dust, etc from the fan and fan shaft and other areas inside the tool. The tools pick up a lot of hair and debris and some will wrap around the moving parts building pup to the point the brush will not spin fast enough. The same thing can happen to the brush roll on your vacuum so be sure to clean it too and replace the belt at least twice per year.
Oct 31, 2013 | Eureka Vacuums
Vax 2300
If the roller brush cannot be rotated easily by hand, it is likely that debris is jammed inside the end caps.Make note of the direction arrows on the end caps as you remove the roller brush. You will need to know this for reinstallation. The end caps are fastened with stop nuts. Removal of one will allow the inner shaft to be extracted for examination and cleaning. An old toothbrush is a good cleaning tool. Reinstall the inner shaft and stop nut. Check for free rotation of the brush roller. Place a new belt over the brush roller and reinstall the brush roller, being careful to observe the position of the arrows on the end caps. Inspect the motor shaft and remove any old belt residue before installing the new belt on the shaft.
Jun 30, 2013 | Vacuums
Bissel easy vac roller won't work
remove brush roll and clean any string, hair, or whatever from it. especially around the ends. you can also unscrew the ends and check for debris there also. when you put ends back on use a little wd40 to lube up the bearings. if that doesn't work replace brush and won't hurt to change belt
Feb 13, 2013 | Bissell Roller Brush 2037029 for Easy Vac...
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have an old fantom thunder upright and need to take the bottom off it to see what is stuck in it. I don't know how to do this.
moz-screenshot.jpgI found a manual for the Fantom Stick Vac, model FS801 (your model may be different).
For "Cleaning Air Driven Turbo Brush", it says:
  1. Remove the turbo brush from the hose or extension tube.
  2. Slide locking latch forward, then tilt the top housing of the brush upwards. The top housing is hinged and will tilt up approximately 45 degrees only.
  3. There may be some dust, lint, hair, etc. on the turbine wheel. Remove as much of this as possible.
  4. You may also use the unit's hose with the crevice tool attached, and use the vacuum to remove any additional debris from the turbine.
  5. Ensure that the turbine wheel moves freely by rotating it with your finger. If the turbine does not rotate, call Customer Service for help.
  6. Once clean, close the top cover of the turbo brush and slide the locking latch towards the rear of the brush to lock.
There is also an image in the manual that might help. You can download the manual for free here.
Hope this helps!
Mar 03, 2011 | Vacuums
The turbo brush attachment on my bissell cleanview helix suddenly wont spin. I bought this vacum a month ago. there is nothing wrong with the vacum otherwise.
The turbo brush may just need to be cleaned. If hair or other large debris gets wrapped around the brush, it can prevent it from spinning. Since the top of the turbo brush is clear, you can look in and see if there is a lot of hair wrapped around the brush. If so, you can open it up by removing the two screws on the bottom of the brush and popping the clear cover off, then cleaning all the debris from the brush (scissors work well if its hard to get dog hair off). Be careful to see how the brush goes back together as you take it apart.
If cleaning the brush doesn't fix it, the belt might be broken. As you're looking at the top of the brush, there is a little belt that goes from the brush itself to the large blue/green gear (it's red on some models) so that if you reach your hand in and turn the gear, the brush should spin. If this belt is broken or missing, it will need to be replaced. You can probably find a replacement belt online, or you can order a whole new turbo brush from the Bissell website for $24.99.
Feb 04, 2011 | Bissell Cleanview Helix Deluxe Bagless...
Roomba keeps saying "Clean Brushes"!!
Have you made sure the brushes aren't clogged with thread and hair, and that the brush bearings are still good?
1) remove the brush guard.
2) remove the brushes
3) remove any hair or debris using the cleaning tool
4) replace the Roombas brush bearings
5) replace brushed and brush guards
If this doesn't work then, try the following:
  1. Power off the Roomba.
  2. Remove the dirt bin.
  3. Place the robot upside down on a flat, padded surface.
  4. Check for any dust or dirt obstructing the Cliff Sensors (with Roomba upside down, the sensors are located in the four rectangular areas just inside the edge of the front bumper).
  5. Next, press the front bumper in to make sure it springs back.
  6. Make sure both yellow brush caps are installed correctly
  7. Make sure the main brush and the flapper brush each have a yellow bearing installed correctly.
Mar 26, 2010 | Roomba Robotic Floor Bagless Vacuum
Hoover hu 4207/1 pet hair removal turbo brush wont revolve
Try Larryclare1's solution for a Kenmore and see if it helps. Worked wonders for both my turbo brush attachments. http://www.fixya.com/support/t1095798-kenmore_model_116_powermate_jr_stopped
Feb 27, 2010 | Vacuums
Vacuums Logo
1,178 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
