Question about Cobra 29 LTD CB Radio
Cb radio transmitting problems
I get great reception ad ear clearly other drivers but I can't transmit at all I key it and it makes a noise but when I try to tune it the dial on the awe meter doesn't move at all
    Novelist:
  • Cobra Expert
  • 500 Answers
Check your microphone and the SWR on the antenna.
SWR checks or bench checks should be free at a RadioShop or CBshops, and normally they will only charge for parts needed.
Posted on May 07, 2013
Benimur
  • 6966 Answers
SOURCE: microphone
If the radio receives OK and the TX red LED will not lit up when keying the mic, then it is a mic or mic cord or mic connector problem (or pin configuration). Internally to the mic, there is a switch for keying the PTT. This should be check down to the coiled cord to the connector.
If all of the above checks OK, then you would need to check the TX/RX regulator/switching circuitry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 31, 2008
  • 200 Answers
SOURCE: receiving fine but transmitting bad??
First off, that radio will not transmit very well anyways.  but for just off roading it should suffice.  You really should adjust your antenna's both of you.  First off this is almost definitely the problem if you can recieve but not send.  Also if you use the radio without a properly adjusted antenna it will destroy the radio over time, sometimes instantly.  pick up a cheap SWR meter and follow these steps: Plug the SWR meter into the radio, and the antenna. Start on channel 1, the meter should have a switch with 2 settings, one for adjustments and one for reading.  Key up (hold down talk button on mic) with the switch in adjust mode and adjust the knob until it reaches the adjustment marker. flip the switch to reading and key up again. Your goal is to get this reading as close to 1.1 as possible, anything above a 2.0 will damage your radio. if the reading is within range repeat for channels 20 and 40. good luck!
Posted on Jan 22, 2009
  • 773 Answers
SOURCE: cobra 29 ltd classic cb not transmitting
Check the ground. Make sure its grounded well on bare metal. To see if the ground is bad, or not making good connection, disconnect the antenna and turn it on. if it does not power up, that means your ground is bad, and it was grounding only through the antenna.
Make sure not to key up with out the antenna connected.
Posted on Feb 08, 2009
audio20
  • 22 Answers
SOURCE: swr meter not moving.
If the radio is working don't worry about the meter unless you absolutely want it. These little meters are not very accurate or reliable. Get an external SWR meter to check the antenna.
Posted on Apr 23, 2009
SOURCE: No audio Transmit
Try a hand mic with the set, there may be a short within the radio.If not your problem is with the audio amp in the radio itself.Repair should be about $15.00.
Posted on Aug 09, 2009
Why is humming coming from speaker when mic is keyed?
this is strange as most times if a proper transmit key is depressed , then the radio switches from receive to transmit , the mfg know this would cause some great squeal from receiver /transmitting so close to a receiver so the part that is the receiver is muted to keep this from happening , id say there is some fault in the part that does this muting of receiver
Apr 13, 2016 | Radio Communications
Problem no squelch noise or speaker like its muted, but can hear weather ok shows receiving and ant ok
Since the radio cannot transmit on Weather bands, there is no need for the radio to detect if it is transmitting when receiving weather.
In CB mode (on CB channels) the radio will mute when transmitting. So... a guess is that it is muting, or transmitting all the time in CB mode. Check for a mic problem by removing the Mic from the radio ... if it receives CB with no mic connected, then there is an issue with the mic. Otherwise, unless the unit is in PA mode (public address mode) it is likely something internal and beyond the scope of this service.
Sep 08, 2015 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
Handheld Radio Shack CB radio TRC-230 I can hear people but no one can hear me
First, lets make sure that the unit does transmit. Get a power meter and see how much power it transmits. If no power is being radiated, you need to have a technician check out the unit.
If you have power then pick a less crowded time to test out if anyone can hear you. Other people with more powerful equipments can only be a problem when you are transmitting on the same channel and both of you happen to transmit at the same time all the time. Chances are remote that this is your problem. Good luck. es
Mar 23, 2013 | Radio Communications
I have an almost new Midland 75-822 that the WX works fine on, but the CB doesn't seem to receive, or transmit. It operates normally, but no reception, and no evidence of transmissions.
you'll need a schematic and some knowledge. there a two diodes that control the rx and two that control the dx.Check them to make sure they are producing the correct power out put if they are not you should replace all 4
May 10, 2012 | Midland 75-822 40-Channels Handheld CB...
Cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
May 29, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
No audio Transmit
Aug 07, 2009 | Cobra 29 LTD CB Radio
Cant transmit
Hello Darren, Yes it sounds like the mic is wired bass ackwards,,! A cobra 25 mic wiring is
PIN #1- Shield or ground wire
PIN#2- Audio or Transmit modulation
PIN #3- Transmit or Dead Key
PIN #4- Receive Audio.
When your keying the mic, the RX wires are being connected to make the RX work,,,
*** Let me know how you get along with it. Either buy a new mic wired for your radio or you or someone comfortable with soldering needs to resolder the correct wires back on the mic plug,,,Like I said, let me know and have a great day,, Mechanic is back quiet!
Oct 21, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Transmitting problem
You are connected to a power source that is inadequate, possibly a poor ground in the vehicle or an underrated power supply if using as a base. Oxidized connections on the fuse or fuseholder may also be the cause.
Sep 02, 2008 | Connex 3300 240-Channels Base CB Radio
Maycom EM-27 Transmit noise
you don't need a noise supressor, i belive you have to change the mic or check real good your mic, specialy the transmit botton
Apr 28, 2008 | Radio Communications
Cobra 29 LTD CB Radio Logo
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
