Question about Garden
Lawnmower starts buts shuts off in a few seconds
    Scholar:
    New Friend:
  • 103 Answers
Change plug.
Check coil / wire.
Clean or replace air filter.
Check tank for trash / debri.
If there is debri in the gas tank, you need to have your carbruetor gone through and cleaned. The jets are clogged with debri....
Hope this helps you....
Posted on May 13, 2013
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
Lawnmower starting problems
Hot start problems are almost always valve related. As the engine heats the valve grows a few thousands thus not closing 100%. Here's a test next time it's cold pull it over to gage how strong your compression is, then when it's hot and you shut it down now pull it over and gage how strong your compression is.
My guess is that you have much more compression when cold than when hot... valve problem.
Solution; make sure valve lash is to spec when cold. This is a fairly technical ordeal but basically on the older style flat head engines you have to remove a small amount from the valve stem end to make sure your valve lash is to spec. You'll have to look up the spec and measure it.
Feb 18, 2018 | Craftsman Garden
Riding lawnmower starts but shuts off in 10 seconds
sounds like the carb needs a cleaning could be gummed up from old gas...good luck
Apr 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have an Older John Deere riding lawnmower with a
ck anti backfire selanoid on carb see if its moving and if it is then ck for 12 volts
Jun 07, 2009 | Garden
I have a Toro LX425 riding mower with a new battery. Tries to turn over for a few seconds and then the battery is dead. Jump started with a car battery. Fired up fine. Ran for 45 minutes cutting grass....
Your most likely talking new starter,never jump start a lawnmower with car,to much amps.fries your starter resulting in like low battery condition,If interested can give you a place you can get a resonable price ,Most places will shock you over 120 dollers.
May 06, 2009 | Garden
My lawnmower engine cuts out
I was having the exact same problem with my 6.5 hp Toro lawnmower with a Tecumseh engine. The engine would start up okay but after a few minutes of mowing, the mower would start missing and eventually shut down. I would pull and pull and pull on the starter rope, getting angry and frustrated and eventually going back in the house to let it cool down.
I looked up all kinds of information and I finally decided it was a bad coil (something about the resistance being low when the mower wasn't hot and then when it heated up the coil would conduct enough electricity to somehow make the engine shut down.)
I called a local shop and wanted to get an estimate on replacing the coil. I have no clue about engines so I dared not get into the guts of the mower myself. He told me to check the gas cap. HUH??????
He told me to make sure there wasn't a part missing out of it. I thought, what the heck would a gas cap have to do with the engine shutting down. Well, apparently there is a mechanism on these caps that prevents a vacuum from pulling on the fuel system and my gas cap indeed had a part missing. To verify this, I cut the grass for about 5 minutes. When it started to run rough, I took the gas cap off to allow pressure to escape from the gas tank and voila! it started to purr like a kitten.
So, I'm only out $4 for a new gas cap and I'm as good as new. Man I wish I was more mechanically inclined so I hope your problem is as easy to solve as this one.
Hope this helps!
Apr 12, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
