Question about Sharp FO 4450 Laser Fax
Sharp FO-4450 errors when sending to Brother Intellifax 475-0E
I work in a busy office and we can send and receive faxes from approx 50 regular numbers daily. We can receive from the Brother but cannot send, any suggustions?
  • 1 more comment
  • Deniselynn Aug 09, 2007
    Hi, Brother Intellifax, 475-0E. Yes...they have their machine set to Auto-Recieve.
    We have a Brother MFC-8440 in the office as well and the Sharp and it commuicate fine.
    Hi. Thanks. Yes...they have their Brother Intellifax, 475-0E set to Auto-Receive.
    We also have a Brother MFC-8440 here that communicates with the Sharp with no problems.
    Cheers
  • Deniselynn Aug 10, 2007
    Thanks JayBlair, will check into these things and let you know... much appreciated!
  • 328 Answers
Tell me more. What model Brother? Did you call them and make sure the Brother is set to auto receive?
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 09, 2007
  • Jay Blair
    Jay Blair Aug 09, 2007
    SO many variables. Most commonly it is line failure. Or voltage drop. Are they receiving from other machines OK? The 4750e has a smart ring feature. Make sure it is turned off. Could be a LIU board that is failing. Check to see if they have not recently unplugged the phone line and possibly placed in the wrong plug. It should be in the Line plug.
  • 62 Answers
Soft sitch setting for ecm in the sharp machine.
Posted on Mar 23, 2008
Why do we get busy signal for every fax we send?
Check the lines and check the connection, usually it's a problem from your side, There is a nice troubleshooter in the manual so check it out: Brother Intellifax 1270e manual
Jul 23, 2014 | Brother IntelliFAX 1270E Plain Paper Fax
When I send a document the receiver gets a large image. I want the receiver to get a letter size image. How do I do this?
The image would have to be resized before sending to less than 8.5x11 inches. You will have to open the image and click resize.
Dec 30, 2009 | Sharp FO 4450 Laser Fax
Can send but can't receive faxes.
Make sure its on standby auto not manual.
Dec 15, 2008 | Brother IntelliFAX 4100 Laser Fax
Fax will only send and not receive
Call your fax machine from a regular phone and listen for fax tones. Sender may be dialing the wrong number. Is your phone line DSL?
Sep 05, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Drum cost
The price should be in the $50 range.
Here is a web site to compare
http://www.bizrate.com/faxmachines/products__keyword--sharp+fo+4450.html
Mar 13, 2008 | Sharp FO 4450 Laser Fax
Brother MFC 4450
The majority of Brother machines will usually not recieve when they have a scanner error. So your lucky.
Under the top cover where the original goes you will see a glass strip (this scans your original). It should light up when the machine is powered on. If not this item has most likely failed. I have seen it before where rust around the contacts have caused it to not work and after cleaned the contacts it did work but usually it just fails.
Another way to checkif the machine will let you is to do a copy. If it comes out black it means the scanner has failed. It should be a relatively cheap repair if it has.
Jan 30, 2008 | Brother IntelliFax-2820 Laser Fax
Sending and receiving faxes on legal size paper.
There should not be a problem with TX on LGL paper. If you want to configure the machine to recieve LGL on a regular basis: Press "MENU" 1-3. Then use the up/down arrows to select LGL. "MENU", "EXIT". That should do it. Good luck!
Apr 20, 2007 | Brother IntelliFax-2820 Laser Fax
Sharp FO 4450 Laser Fax Logo
200 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
