Question about Honda EU3000iS Inverter Generator
Honda EU 3000is only runs on half choke
Only runs on half choke. New premium fuel and a little Sea Foam. new plug, No change
  • Honda Master
  • 15,478 Answers
Overhaul the carb. When you have to choke it to run, there is not enough fuel getting in
Posted on May 20, 2013
My volvo has sat up for hey year and a half and I put a new battery in it yesterday and crank it up and its own a little bit like the older all those it wasn't quiet like it normally he is so I'm wondering...
I would add a little Sea Foam product to oil and if you have 1/2 tank of fuel, add 1/2 can of Sea Foam to gas.
If your gas is old the Sea Foam should help.
Feb 05, 2015 | Volvo Cars & Trucks
I have a 2004 arctic cat dvx 400. Recently it got hard to start and backfiring. it will start and runs fine when it does, but if you let it set for any length of time, say 10 minutes or longer after u
Fill it up with premium gas, change the plugs, and run some sea foam through it. It will blow smoke after you add the sea foam and then clear up. That helps keep the varnish out of the carb (and unstick the choke etc.) and the high test gas will make it a lot easier to start and keep the plugs from fouling out as often. Also change/clean the air filter. This will give you optimal conditions for fuel air mixture and combustion. If you still have problems, go from there.
Oct 21, 2014 | ATVs
My th34 brushcutter is not starting.i replaced carborator diaphrams but still not start,i opened the muffler out and saw excessive fuel on the pistol.can anyone help me solve this problem.
yes get a rag wipe off all the fuel . blow dry all inculding the muffler and spark plug make sure your getting spark if you are spray a small shot in the spark plug hole of starting fluid tighten plug if it fires drain fuel tank remove intank filter put in fresh fuel i get some Sea Foam you can get it a walmart or autozone meijers it made for 2 cyle and 4 cyle engines pour sone about 1/4 cup in the emptyas tank try to prime and see if starts if so put in 1/2 cup of sea faom in 1 gal of new fuel and oil get a new gas tank filter there about $5 check wlamart replace when brush cutter gets running find a way to secure it remove the blade or disengage it and make it run maybe almost full choke then less and less but after it runing take it out and run it good and make it work . ( I winterize my lawn equipt with 5gals of 89 octane full i can of 104 octane booster and 2 cups of charcoal lighter fluid ( it kenosee and the fuel would break down or put 1/4 cup in a empty mower start it for 1 minute and leave it you put in fresh gas next summer it has the charcoal or sea foam as a carb cleaner for the season . i put sea foam or lighter fliud in my fuel all yr as ethonel breaks down in 25days
Dec 02, 2013 | Garden
I run my fuel rich (93+) with a quarter bottle of 104 octane boost. only because if today's new fuel sits too long it basically turns into sugar. here a few days ago i put a little more than a quarter...
run a few more tanks full of fuel through it and it may clear as the foam does its job.
Octane boost doesnt make for rich fuel, just higher octane.
To make the bike rich you need to adjust mixture screws or change jets, but making it rich will make it go slower, a bit like riding withthe choke on
Make sure all the other service items are done, plugs, aircleaner, oil, valve clearances
Jul 31, 2011 | kawasaki ZZR 600 Motorcycles
I have a coleman powermate premium plus 6250 generator,put in new plug ,new filter ,changed oil,cleaned the carb,put in new gas. runs ok at half choke but when go full choke it starts backfiring and runs...
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Dec 17, 2010 | Coleman Powermate Premium Plus 6250W...
My 13 hp honda power washer has a miss when it's not under a load. Is it a fuel or spark problem ?
Most likely fuel / plug. Easy to check. While running unloaded and miss-firing, try applying the choke just a little to increase fuel mixture (make run slightly rich), if clears may need carb kit. If it gets worse with slight choke running rich or plug faulty. Before you change parts try using premium fuel. If runs better problem solved.
Nov 02, 2010 | Honda Garden
Hi 6000 watt generator sat for 6 months with fuel shutoff. now will only run with choke on. thanks, Glenn
Hi, sounds like derty fuel, you will need to check and clean air and fuel filters; also wash your carbretta out with lean fuel. Drain fuel tank and replace with fresh fuel.
Aug 06, 2010 | Honda Electrical Supplies
I have hesitation in my motorcycle 1994 honda magna 750 vfour
same problem with my 94 magna. local shop put sea foam carb cleaner in and told me to ride. Problem solved. I had tried other
carb cleaners but no luck. Sea Foam cleaned the system up and
bike runs like new.
Oct 27, 2009 | 1994 Honda VF 750 C Magna
EU 3000is generator is running rough with Eco Throttle on
The air intake system on this unit is highly fine tuned. Make sure all covers including front battery cover, plenums, air intake system is properly installed and that any and all gaskets on doors and covers are not damaged.
Oct 01, 2009 | Honda 6370C - Parallel Power Kit For ...
Hard start wont run more than a few minutes
sounds like the air bypass valve may be stuck ,try pulling off a small vaccum line. the valve is used instead of a choke plate. when engine is cold it bleeds air around the throttle plate raising the idle.
Dec 06, 2008 | 1993 Chevrolet Corsica
Honda EU3000iS Inverter Generator Logo
317 people viewed this question
Top Honda Electronics - Others Experts
John
Level 1 Expert
Bill Boyd
ray gallant
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
