Question about Dishwashers
Danavigate 3100 anemometer
All I really need are replacement cups for the masthead spinner. Any ideas where I could find them?
Tip
ICAPP-4 - A Wiki Manual
Cuisinart ICAPP-4 – Iced Cappucino and Hot Espresso Maker – A Wiki Manual
By Tha Mp3 Doctor (who also loves Cuisinart)
Since I am not well-versed in the copyright laws regarding reprinting copies of standard user’s manuals online, I am writing this Wiki Manual for the ICAPP-4. My unit is 12 years old (in 2009) and continues to run strong through two different owners.
General Directions for Making Iced Cappuccinos
- Place carafe on top of drip/tray grate with handle touching right front of ICAPP – the ice fill lines should be visible when looking at front of unit
- Turn “milk knob” to OPEN position, and open lid of ICAPP
- Remove milk container, espresso collector, espresso spinner cup and cover
- Put espresso collector back in place with two plastic teeth facing front of machine
- There is a stepped fill line inside water reservoir that measures off 1,2, and 4 cups
- Fill water reservoir with either 1,2 or 4 fill line cups – do not overfill to avoid damaging the electronics
- Add espresso grounds to espresso spinner cup
- Line up teeth of spinner cup cover with spinner cup so that the cover locks into place
- Fill milk reservoir with 3 oz of milk per cup of iced cappuccino that you plan to make – there is a fill line that measures off 2 cups or 4 cups
- Fill carafe with either 2 cups worth of ice or 4 cups, depending on how much iced cappuccino you plan to make
- Press down on lid and turn milk knob to HEAT postion
- Turn ICAPP on using the ON/OFF button – it will begin to heat – takes about 5-6 minutes (HEAT light will stay on during this process – doesn’t make noise or steam for several minutes)
- When READY light turns green, turn the milk knob to the DISPENSE MILK position – your espresso and milk will start dispensing
- Unit turns itself off automatically when ready – takes several minutes
on Feb 25, 2009 | Cuisinart ICAPP-4
Display only showing dashes ----- I have voltages on the 5 core cable from transducer to back of display .... what are correct values for these?
Try to identify if the fault is in the masthead unit or the display by using a known good unit ,or masthead or display.
Then have it repaired.
Feb 28, 2011 | Raymarine St60 Wind Vane Ducer E22078
Top rack spinner is not spinning
First check - ensure that the jets at the end of the spinner blade are not blocked. Check that the spinner is not siezed by turning it by hand, other than a cracked or disconnected pipe, there can not really be another reason for the spinner not rotating (if the bottom one rotates).
Jan 15, 2011 | KitchenAid Dishwashers
Soap still in large container on door at end of cycle. recently had center spinner arm and main console replaced twice. doesnt clean well. residue left in cups
residue..... check lower spinner arm and clean any bits from insideit by back washing with water, also check the pump inlet and filters.....
as for soap still in container, does the soap recepticle door open... if not just place the required amount of detergent on the lower half of the door..
If the door does open and there is still soap ing the recepticle there is definitely a water problem...
you can also try to remove both the upper and lower spinners and run the dishwasher for a couple of minutes to flush out any debris or buldup inside the lines.
A good quality dishwasher cleaner may also be wothwile trying....
Dec 17, 2010 | Electrolux EIDW6305GS Builtin Dishwasher
The spinner bush turns really slowly. It doesn't
u need to get a new belt. a local hardware store or walmart carries it. also u need to take the vacum apart further so u can clean out where the motor spins u will get much bettter results
Oct 06, 2009 | Eureka Vacuums
I need instructions for a Cuisinart Iced Cappuccino Maker
I have a PDF of the user manual if you want me to e-mail it to you. In the meantime, here is my Wiki Manual (BTW, pagan, the machine does make hot espresso or cappucino, but it doesn't froth per se like a regular espresso machine - it just heats the milk internally and dumps it into the espresso):
Feb 26, 2009 | Cuisinart ICAPP-4
NEED DIRECTIONS For Model ICAPP-4
I can answer just about any question you have on the unit - I wasn't able to find the manual online, but I would be more than happy to scan and e-mail you my copy of the original manual. In the meantime, here is my basic Wiki Manual:
-Tha Mp3 Doctor
Feb 25, 2009 | Cuisinart Coffee Makers & Espresso...
Dishes and Flatware Don't Get Clean
Check to see that the removable cup rack on the left is seated correctly. One of the support legs of this rack is located above center of the spinner. If this leg is sitting on the top of the spinner rather than the center cross member of the main rack, the spinner will not move after that rack has been loaded.
Also check that the spinner is free moving once the draw is fully loaded, some plates can sit low enough to obstruct the spinner.
Mar 20, 2008 | Fisher DD603FCSS Dishwasher
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
