Question about Honeywell International Heil Quaker Honeywell 1014460 Control Fan Timer
Heil fan control board replace
Replace
  • 575 Answers
Http://www.allpartsheating.com/1014460.html
Posted on May 06, 2013
What does a1236 mean for sevice
Acura Service Codes
A: Replace Engine Oil
B: Replace Engine Oil and Filter. Inspect various systems and components
1: Rotate Tires and check tire pressure and condition
2: Replace air cleaner element, check drive belt and replace dust and pollen filter
3: Replace transmission fluid and transfer fluid (if equipped)
4: Replace spark plugs, replace timing belt (if equipped), inspect water pump, and inspect value clearance
5: Replace Engine Coolant
6: Replace rear differential fluid (if equipped)
May 08, 2015 | 2008 Acura Mdx
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Code B256 on acura mdx 2007?
Acura Service Codes
Mar 08, 2015 | 2007 Acura MDX
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
What does A1236 code on Acura MDX mean?
Acura Service Codes
Apr 29, 2014 | 2007 Acura MDX
Purchased focus sport 2006 model no service manual. Mileage 43,000 kms. Need to know service intervals either time/mileage perhaps a copy of the service schedule will suffice.
These maintenance intervals come from the maintenance interval calculator
at www.autozone.com, using a starting point of 25,800 miles (43000 km), and
assuming 1000 miles (1666 km) driven per month, and "severe driving conditions," which
are actually normal usage characteristics, such as frequent short trips, urban driving, waiting in traffic, driving in hot weather, trips under 16 km in cold weather, etc.
STARTING MILEAGE: 25800 (43,000 Kilometers)
Item
Action
Service History
20000 miles or 32000 kilometers
Battery Check
Oil Filter, Engine Replace
Engine Oil Replace
Vehicle Inspect
Brakes and Traction Control Inspect
Tires Rotate
21000 miles or 33600 kilometers
Steering and Suspension Lubricate
Engine Oil Replace
24000 miles or 38400 kilometers
Engine Oil Replace
25000 miles or 40000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
27000 miles or 43200 kilometers
Engine Oil Replace
30000 miles or 48000 kilometers
Battery Check
Air Filter Element Check
Wheel Bearing Lubricate
Fuel Filter Replace
Engine Oil Replace
Fluid - A/T Replace
Cabin Air Filter Replace
Vehicle Inspect
Cooling System Inspect
Wheel Bearing Inspect
Ball Joint Inspect
Drive/Propeller Shaft Inspect
Exhaust System Inspect
Steering and Suspension Inspect
Heat Shield, Exhaust Inspect
Tires Rotate
33000 miles or 52800 kilometers
Engine Oil Replace
35000 miles or 56000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
36000 miles or 57600 kilometers
Engine Oil Replace
39000 miles or 62400 kilometers
Engine Oil Replace
40000 miles or 64000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
42000 miles or 67200 kilometers
Engine Oil Replace
45000 miles or 72000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
48000 miles or 76800 kilometers
Engine Oil Replace
50000 miles or 80000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
51000 miles or 81600 kilometers
Engine Oil Replace
54000 miles or 86400 kilometers
Engine Oil Replace
55000 miles or 88000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
57000 miles or 91200 kilometers
Engine Oil Replace
60000 miles or 96000 kilometers
Battery Check
Fuel Filter Replace
Spark Plug Replace
Fluid Filter - A/T Replace
Engine Oil Replace
Fluid - A/T Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
63000 miles or 100800 kilometers
Engine Oil Replace
65000 miles or 104000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
66000 miles or 105600 kilometers
Engine Oil Replace
69000 miles or 110400 kilometers
Engine Oil Replace
70000 miles or 112000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
72000 miles or 115200 kilometers
Engine Oil Replace
75000 miles or 120000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
78000 miles or 124800 kilometers
Engine Oil Replace
80000 miles or 128000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
And you can continue the pattern from there...
May 14, 2011 | Ford Focus Cars & Trucks
How often should I change the Transmission fluid, normal driving ? Thank you Gary
It's listed in your owner's manual. Schedule A is normal driving conditions.
SCHEDULE "A"
7,500 miles (12 000km) or at 6 months
- Change engine oil.
- Replace engine oil filter.
15,000 miles (24 000km) or at 12 months
22,500 miles (36 000km) or at 18 months
- Inspect front wheel bearings.
- Inspect brake linings.
30,000 miles (48 000km) or at 24 months
- Replace engine air cleaner filter.
- Replace spark plugs.
- Drain and refill automatic transmission fluid and filter (4.7L).
37,500 miles (60 000km) or at 30 months
- Drain and refill automatic transmission fluid and filter (5.2L/5.9L).
- Drain and refill transfer case fluid.
45,000 miles (72 000km) or at 36 months
- Flush and replace engine coolant at 36 months, regardless of mileage.
52,500 miles (84 000km) or at 42 months
- Flush and replace engine coolant if not done at 46 months.
60,000 miles (96 000km) or at 48 months
- Replace ignition cables (5.2L/5.9L).
- Inspect PCV valve, replace as necessary.
- Inspect auto tension drive belt and replace as necessary (5.2L/5.9L).
- Drain and refill automatic transmission fluid (4.7L).
67,500 miles (108 000km) or at 54 months
75,000 miles (120 000km) or at 60 months
- Drain and refill transfer case.
- Flush and replace engine coolant if it has been 30,000miles (48 000km) or 24 months since last change.
- Inspect auto tension drive belt and replace if required.
82,500 miles (132 000km) or at 66 months
90,000 miles (144 000km) or at 72 months
- Inspect auto tension drive belt and replace as necessary.
97,500 miles (156 000km) or at 78 months
105,000 miles (168 000km) or at 84 months
- Flush and replace engine coolant if it has been 30,000 miles (48 000km) or 24 months since last change.
112,500 miles (181 000km) or at 90 months
120,000 miles (192 000km) or at 96 months
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | 2001 Dodge Durango
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2009 | Ovens
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Honeywell International Heil Quaker Honeywell 1014460 Control Fan Timer Logo
130 people viewed this question
Top Honeywell International Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Honeywell International Hardware and Accessory Expert? Answer questions, earn points and help others
