Question about Home
Triton t80 gsi
Why does the shower run colder than normal when on a hot setting eg usually num 5 but now have to use num 9
  • 44 Answers
SOURCE: Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Posted on Dec 15, 2008
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
  • 34 Answers
SOURCE: triton t80i water only warm in winter
That sounds like a water heater problem, wheres the heater at in your home. If it is effected by the outside weather i.e. the heater is in a cold environment then it would effect the hot water output. try turning up the thermostat on the heater if it is gas then it should be knob on the outside if it is electric you will need to remove the top or the bottom cover and adjust it with a screw driver. If this does not work the let me know and we try some other things. With the weather/temp outside effecting the water temp in the shower then I have a hard time believing it is the shower its self.
Posted on Feb 06, 2009
  • 16 Answers
SOURCE: triton topaz t80i. Power to unit ok, but no water flow.
sounds like the pump is broke. better off just replacing whole unit unless you order new pump from triton.
Posted on Jan 10, 2010
garypetterss
  • 15 Answers
SOURCE: How do I open a Triton shower box ?
there are usually screws on the top and the bottom of the shower unit holding the front cover on.
Posted on Apr 11, 2010
Triton jade 3 running cold
Sounds like you have an instant hot water system... (no hot water tank) if true, check that fuse.
Jan 12, 2014 | Home
Triton thermostatic shower hot water is reaching the shower but not traverling any further only cold water comes out.i've had the whole shower system off the wall and hot water flows out of pipe but when i...
Could be the pressure on the hot water flow is insufficient, you really need a 5/6 feet head of water from the shower head to the bottom of the storage tank for sufficient pressure.
Nov 06, 2017 | Home
My new triton mixer shower only runs cold water how do i get it hot
you might need to adjust the scolding setting behind the handle....
Jan 26, 2011 | Home
How to remove the cover plate from a triton t80 shower
Remove handle by locating set screw. Escutcheon (cover plate ) screws are now accessible to be removed.
Oct 06, 2010 | American Standard Showerhead & Valve Trim ...
Apr 11, 2010 | Home
Cold shower
You posted to the category:
Tritton Technology | T-NAS 120GB (trinas120) 120 GB Network Storage
Take the defective unit to a qualified repair-site, for trouble-shooting.
Nov 14, 2009 | Tritton Technology T-NAS 120GB (trinas120)...
Shower either runs cold or extremely hot
hi ya, if its a triton shower valve & only 2 years old it should have a 5 year guarantee, ring Triton & arrange a service call.
it sounds as though the filters could be blocked & more than likely the thermostat requires replacing as its more than likely scaled up?
You never mentioned where your based UK or abroad?
Kindly
Richie
Dec 15, 2008 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
