Don't know how to take the faceplate off. Please help
SOURCE: driver side power seat 2001 Chevy Tahoe
as long as nothing is stuck in track and you hear no noise when using switches, look for broken wire at connector or in harness. ck fuse first of course, if blown, something may be stuck in track causing it to stop and blowing fuse
SOURCE: 2001 Chevy Tahoe with ABS & Brake light on.
I hope you have the problem fixed by now, but, it is the ABS control under the truck. You need to go under the hood and open the fuse box and disconnect the 60 amp fuse for the ABS, this will turn it off before it burns up. This however will also cause the traction assist off light to stay lit all the time. To the fix the problem you can pay tons of money ($700 or so) to have the dealership install a ABS control and the problem will happen again over time. Or, remove it yourself, go on ebay and ship it off to a guy who repairs them for about $150 and you will never have the problem again. Also, if you wrap your cable ends with plastic and protect them good, you can still drive you truck while the part is being worked on. It takes about a week.
SOURCE: how to replace passenger side front seat belt on a 01 chevy tahoe
They Are easy to replace, They mount to the floor with one large bolt. The nut below is welded so if you can obtain a large enough socket ... You may als get one from a junk yard.
SOURCE: fuel pump 2001 Chevy Tahoe
no there is not. the only way to access is to drop the gas tank down.
SOURCE: is there a huel reset on 2001 chevy tahoe
Sorry there is no fuel pump reset on the Tahoe. If you have no fuel pressure, check the fuses and relay,and wire harness to the fuel pump from the inside frame rail on the drivers side. If you can hear the fuel pump working, check the fuel pressure at the shredder valve and there should be 60 to 66 PSI, if you don't you can try checking for 12 volt at the fuel pump wire harness at the frame rail. Good luck and keep me posted, be glad to help.
