Question about Car Audio & Video
I recieved an item that doesn't work
When i connected the speakers it started smoking. the unit burned.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
It sounds like you didnt hook the negative to the negative and the positove to the positive. Thats the only way that will happen. Or if you put to big of speakers on the amp
Posted on May 10, 2013
I have sw347-dv7 video door intercom.i wired it up using 60w speaker cable& smoke came from rear of unit.now nothing works as tried wiring again using cat6 cable
Using the speaker cable was probably overkill but no reason why it shouldn't work if the connections were all correctly made. The smoke suggests the connections weren't correctly made and you killed your unit.
You might be lucky and find it is a burned out bit of printed circuit that could be repaired or it could have damaged electronic components and be cheaper to replace the unit.
Jul 06, 2015 | Cars & Trucks
My 2000 Windstar runs well for first 20-30 mins then it starts to have engine knock it is also using oil but not burning it. Doesn't smoke doesn't show any signs of leaks under car either
Check your engine coolant. If its brown you may have a blown head gasket which is causing it to leak into the cooling system. (expensive fix) but if it's not brown I'd take it to a mechanic and have further inspection. Hope this helps:)
Sep 20, 2012 | 2000 Ford Windstar
Are there any prob buying pressure washers from pawn shops
First things to check is are air filter and exhaust. If there is signs of oil then the unit has been tipped and you will probably need to strip the cylinder head to sort it. Also check engine and pump oil levels and start the machine if you are allowed to. If it starts after a few pulls then you have a good chance of it being ok. White exhaust smoke is bad if constant as it is oil burning. Blue smoke isn't quite so bad as it indicates (probably) rich fuel/air mixture. Puff of white smoke that doesn't stay constant is also a sign that the machine may have been tipped at some time and it is just the oil residue burning of the cylinder head.
Jan 14, 2012 | Northstar Garden
Its an onkyo av reciever tx-sr601It was gaven to me from a friend...I can turn it on but it shuts off seconds after. I have left it unplugged many times and have retried but the same problem occurs. Does...
The receiver doesn't have a password, but the unit can be fried, let's go with by a process of elimination.
First, the most noticeable procedure would be to not plug in anything in back of the receiver, and plug it in the an outlet and turn it on. If the unit shuts off after a few seconds, then the unit has a short and must be sent in for repair.
If the unit stays on, then there is something that is being plugged into the Receiver that doesn't seem to agree. Start by plugging in one source at a time and repeating the step above. It's a slow process but hopefully and eventually, you will find the culprit.
In most cases though, it usually the speakers wires in the back touching even a slight bit or your speakers impedance don't match what the receiver is capable of taking.
I strongly recommend starting with the first step since this will allow you to figure out if the receiver is defective or is something else the culprit.
Hope this helps, Best of Luck
Jul 24, 2011 | Onkyo TX-SR701 Receiver
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
When i turn on my reciever it imedietly clicks and goes to stand by
This usually means that the amplifier is "clipping" and therefore is seeing a short.
This can be several issues, I would invite you to check the following:
1- Make sure no speaker wires are touching behind the Onkyo receiver. When hooking up speakers, it happens frequently that the speaker wires may touch and create a short, which will cause a "clipping" or a short on the receiver.
2- New Receiver are very sensitive to higher or lower impedance speakers. Make sure that the speakers you are hooking up to the receiver are not higher than 8ohm's, and lower than 6ohm's or the amplifier will eventually clip.
3- If this is a problem that started happening recently but has been working in the past, I would look back at what was done in the past to maybe have modified to your system. Are your speaker wires in the wall? Have you accidentally nailed a nail in the speaker wire, that can also cause a short.
4- If the above doesn't work, start from scratch. Unplug everything behind your receiver and simply plug-in the unit to a power outlet and turn it on. If the amplifier doesn't short, then there is something that your are plugging into the unit that does not agree with one another. If that is the case, start plugging in one thing at a time and follow the process of elimination. If the unit shuts off right away and nothing is plugged into the unit, the receiver might be defective and must be sent in for repair.
This is the longest solution but the more prominent to find the root of the problem.
Jul 20, 2011 | Onkyo Audio Players & Recorders
When i power it on it shuts off i got a kenwood kdc-mp825
Disconnect all of your speaker leads at the head unit, make sure none are touching, then power it back on. If it still cuts out, check your ground, if it doesn't, re-connect speakers one by one and test power again. It will either cut out when you get to a speaker or wire that's shorted, or work just fine. it's protecting itself from damage by cutting off when speakers are either bad or have shorted wiring. Most common shorted wiring happens on door speakers at the hinge. If it continues to cut off without speakers connected and you have a good ground, the unit needs service. If it still plays and you find the speaker or wire that's causing the problem, disconnect the wire at the speaker and test again, if it works, replace the speaker, if it doesn't, replace the wire. Hope this helps
Jul 07, 2011 | Kenwood Sirius KDC-MP825 CD Player
Paper won't feed from both tray and manual feed tray...motor starts, attempts to grab paper, but doesn't
THERE IS TWO REASONS. PICKUP SENSOR PROBLEM OR IN THE FIXING UNIT HEATER SECTION PROBLEM. SOMETIMES HEATING ELEMENT BURNED. CHECK THE BOTH ITEMS .
Jun 18, 2011 | HP Office Equipment & Supplies
Reciever message in dislay says overload.
Disconnect and reconnect all speaker connections, usually you get and overload when something isn't wired properly. Also make sure your unit well ventilated so that it doesn't overheat. If you still have problems then there could possibly be internal damage that may require electronic repair.
Apr 17, 2011 | Technics Audio Players & Recorders
White smoke coming out tail pipe and useing oil on a 2002 7.3
Hello and welcome to FixYa!
If it's only on cold start ups, then it's ok. You should be glad for it's a sign of engine in top condition. If the white smoke doesn't stop even when running then you may have a worn out piston rings which will surely require replacement to resolve the problem.
It surely is burning oil that's why it emits white smoke.
Hope this helps and thank you for using FixYa! Have a good one!
Apr 12, 2011 | Ford F-450 Cars & Trucks
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
