Question about Electrical Supplies
Yamaha mz300 throttle
Where can I find the throttle on a mz300 engine for my powermate generator?
It should be right their in the carb
Posted on May 10, 2013
  • 6 Answers
SOURCE: i cannot crank my coleman powermate generator.
If the engine will not crank-if it has an electric start, first check the battery and connections to the starter and ground. If the battery is good and the connections are clean and tight, then I would check the ignition switch. If it clicks once when the key is turned to the start position, check for a seized crankshaft (see below) If it does not click, then it could be the starter, solenoid, or the ignition switch. If it has a manual pull start, and it will not pull, check to make sure the crankshaft can turn freely and if not, disconnect the pull starter and check it again-if it turns freely the rope start mechanism is hung up-it must be freed up before you can pull start it. If the crankshaft will not turn at all you probably have a serious problem that will require a major teardown.
Posted on Feb 05, 2009
  • 15 Answers
SOURCE: engine surge up and down
Cleaned the carb again and set idle stop screw up
Posted on Nov 18, 2008
ILikeBMW
  • 117 Answers
SOURCE: engine won't maintain constant rpm
Hello There
Try cleaning or replacing the spark olug.
Hope this helps.
Many Thanks
Posted on May 22, 2009
protek480
  • 1714 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
Posted on Aug 01, 2009
VtToolMan
  • 704 Answers
SOURCE: I have a coleman powermate
Bascially you need to completely remove the old, stale fuel to start with. (you can use the old fuel it in your lawnmower mixed 50:50 with fresh fuel to use it up).
Then once you've drained the fuel tank, you'll have to clean out the carb with a Fuel Injector and Carb cleaner. Really spray the carb till it's soaked, since you've got a schellaced fuel system.
Make sure you remove the air cleaner so you can get the spray into the carb. Also, with the spark plug removed, and the power switch turned "off", so the generator won't try to start during this process. You can also slowly crank the engine with the pull starter, to help work the cleaner through the system.
Then let the unit set for about 10-15 minutes, so the cleaner can evaporate, etc. and then you can reinstall the spark plug.
Now add about 1/2 gallon of fresh fuel and you can try starting the generator. You might have to use some starting fluid to get it started, by carefully spraying it into the carb in very small bursts to keep the motor running
Once it's running smooth, you should always use fresh gas and make sure to add a quality fuel stabilizer, such as Sta-bil, to the gas you use in the generator, as it will keep the fuel system protected for up to 2 years.
I also always turn off the fuel shut-off on my generator to use up the gas in the line before storing it. Also, you should get the generator out at least every 3 months and run it for 15-20 minutes to keep everything working and lubricated, so it will work when you need it.
Just be sure to always add more Sta-bil to your fuel and turn off the fuel shut off and let it run out, before storing.
I've done this with my generators and they're now over 14 years old and always start on the first pull and run like tops!
If you can't get the unit running smoothly, you may have to take it to a small engine service shop for them to do a "tune-up" for you.
Hope you find this Very Helpful and best regards!
Posted on Sep 19, 2009
Coleman Powermate full throttle
There may be a choke handle that should reduce the engine RPM. Otherwise contact the Coleman technical support department.
Dec 22, 2013 | Coleman Powermate Powermate 5000W...
I have a briggs & stratton / Powermate portable generator; there is a lever with a black plastic handle on the end of it, right next to the 'choke - run' lever which has a red plastic tip on it. ...
The engine on your generator is also used for other applications some of which require an adjustable  throttle control. On a generator the engine must turn about 3600 rpm to obtain proper output of voltage and cycles. Upon further inspection of your throttle/governor you will probably find an adjustment consisting of a screw, nut or a tab on one end of the governor spring that can be reset for proper engine speed. (tab can be bent for more or less tension on spring) To check present governor setting, use a volt meter that has frequency setting. Make sure that generator is set to about 60 hz. (3600rpm) Good luck with your generator.
Aug 04, 2010 | Coleman Powermate Powermate 5000W...
I need to look at carb as I believe it is running to fast as I have150 volts in a 110 outlet
There is a throttle plate on the top of the engine above the front engine cover that will have a screw facing you. Turn the screw Counter clockwise to reduce engine speed and voltage. (Adjustment is for EX27 Engine speed)
Mar 20, 2010 | Coleman Powermate Powermate 5000W...
I need to rewind a rope on pull start powermate generator
This requires a bit of strength in the hands and the recoil will have a fair amount of tension behind it. Best have a small engine service center look at. Not expensive
Dec 19, 2009 | Coleman Powermate Generator Start &...
Engine starts and runs fine for about a minute
try to clean out the carb first with auto parts carb cleaner, then you may need to buy a totally new carb for the unit, as this company will NOT sell parts for these carbs due to the carb setting is sealed & has to stay at a set level for voltage output and setting
Nov 05, 2009 | Coleman Powermate Premium Plus 6250W...
Ust 3000 generator-only idles-no voltage output
chek brushes...if they seemed ok then replace AVR card
Sep 05, 2009 | Coleman Powermate Powermate 5000W...
Coleman 5500 W/Yamaha MZ300 engine, runs great, no power produced
next is...brushes..
if they were fine check AVR
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Aug 29, 2009 | Coleman Powermate Premium Plus 6250W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
308 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
