Question about Toyota Sequoia Dash Kits - Dash Kits 7053-CN
Electrical diagram toyota innova
Starting problems and fuel injectors are not spraying
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,449 Answers
Check your fuel pump is working.
Posted on Dec 15, 2013
Forgot its a 2002 Toyota Camry 2.2 4 cylinder won't start new fuel pump new filter check all fueses and grounds but what could be the problem
NO if it was timing belt it would not start on carb cleaner
check all you fuel connections lines and electrical, its not turning the fuel on
Aug 12, 2015 | Toyota Cars & Trucks
I took de oil filter out i connected direct tube i start de it didnt start
Check de-compression lever. Motor will not start if de-compression lever is operated. The lever stops the valves from closing. If lever is operated then there will be no compression when motor is pulled over with starter cord or electric starter operated.
Check fuel cut off at injector pump is not operated. This is how motor is normally stopped.
There must be no air in the fuel line, fuel filter, injector jump or injector. Undo the fuel line at the injector and pull starter or operate electric starter. Fuel should spit out. If not, crank some more until fuel comes through.
if there is fuel in the tank, filter not blocked and injector pump working then if not fuel at injector then maybe injector pump faulty.
If fuel at injector line then remove injector, crank motor and look for spray of fuel.
If if you have checked for spray of fuel and motor compression then motor should start.
Mar 15, 2015 | Kipor Kde 5000ta Diesel Portable Generator
Innova is not started
it can be your ECU the fuel pump section of it has failed . or your noise relay . has failed.or both.a noise relay give power to the injectors.that information to do so .is from your ECU the cars brain.only way to fix is by changing them.
May 04, 2013 | Toyota Sequoia Dash Kits - Dash Kits...
Toyota innova front washer motor has no supply voltage. please send electrical wiring diagram and fuse location.
Best Manuals Visit the on-line store, known as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Apr 03, 2013 | Toyota Cars & Trucks
Toyota ceilca 2000 gts will not start
try reseting the alarm,maybe all thats needed.....
May 01, 2010 | 2000 Toyota Celica
93 saturn turns over but wont start it has spark and fuel pump comes on with ignition in on position
Is fuel pump real loud? See if fiter is clogged> If not see if injectors are spraying. See if there is electric power at the injectors. Spray starting fluid {not alot} inthe throttle bank, this will tell if you have fuel problem.
Feb 07, 2010 | Saturn SL2 Cars & Trucks
1990 toyota pickup engine won't start
CHECK THE COLD START INJECTOR ON THE INTAKE MANIFIOLD.
1. UNPLUG THE POWER WIRES TO THE IGNITION COIL(NOT THE HI VOLTAGE WIRE TO THE DISTRIBUTOR)
2, UN BOLT AND PULL OUT THE COLD START INJECTOR(LEAVE IT PLUGED IN TO POWER AND FUEL
3. BREIFLY CRANK OVER THE ENGINE AND WATCH THE SPRAY FROM THE TIP. (A FIRE EXTINGUSHER WOULD BE A VERY GOOD IDEA)
4. HOW DID THE SPRAY LOOK
WAS THE SPRAY QUICK, IN A FINE MIST? IF SO ITS OK AND NOT THE PROBLEM.
IF IF IT RAN ON, A STEADY STREAM OR POURED OUT THERE IS SOME THING WRONGE WITH THE COLD START INJECTOR
Oct 28, 2009 | 1990 Toyota Pickup
No start 09 impala 30% fuel in tank hear pump run fuse/relay good
This is still a new car try not to do anything to void warranty. I know if you could get to run most likely would drive it to dealer. When your spraying the choke cleaner it is going directly into the intake to the piston area, fuel from the tank must go through the injectors which are electrically controlled, before making it to the pistons. Due you have power to the injectors when motoring the engine over. Remember you must have a very strong battery on todays new cars when attempting start it has to turn quickly. Check wiring diagram to see where injector harness power feed comes from and follow back. I hope this helps God Bless
Sep 18, 2009 | 2008 Chevrolet Impala
94 Celica GT, Fuel Problem?
The computer is what outputs that. So you want to check the wire at the computer and see what your getting. Has the motor been pressure washed or have any changes been done recently?
Thanks,
Lee
Aug 10, 2008 | 2000 Toyota Celica
Toyota Sequoia Dash Kits - Dash Kits 7053-CN Logo
230 people viewed this question
Top Sherwood Innovations Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Sherwood Innovations Vehicle Part and Accessory Expert? Answer questions, earn points and help others
