Wont turn on
Plz help my Samsung 50" rear projection tv turned off so I changed fuse in plug tried again it clicked then blew fuse in plug.
    Top Expert:
  • Televison & ... Master
  • 74,468 Answers
Please understand, that if a fuse must bow up, there must be a reason. Without recitfying that reason, if we put an other fuse, you've already did it, will make things worse. There are mainly two reasons for failure of fuse. A short circuit, and an over load. It will be best for your to contact any service technician in this case. Do not put an other fuse and make an experiment.
Posted on May 04, 2013
  • 150 Answers
SOURCE: Samsung 54" rear projection PCL5415R Won't Turn On
Although I am not incredibly familiar with your model, There is most likely a small board mounted above the others near the crts, there is a small red connector with a blue wire if you unhook it it will remove power from the convergence IC's and if they are shorted it might come up with conv out, will need a new module.
Posted on Jul 07, 2007
  • 5 Answers
SOURCE: sony projection tv no power
I purchased a service manual for $16.99 from ServiceManual.net. I downloaded the manual. Read it and you have to make note of how many times the power LED blinks red. My 55" Wega was blinking 6 times then pause then repeat.
The manual indicated it was a "Low B error, No "DD 6V" output ( G1 Board) No picture/No Sound.
The manual gave me instuctions on how to remove the G1 Board. I took it out and clean off the dust reseated the G1 Board, still the same problem. I order an new G1 Board, part# A-1060-177-A from the "Partstore.com" for $186.25
Problem is fixed and I save $350 on service call.
Bobby G aka poolmvp1
Posted on Jan 02, 2008
SOURCE: SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
got mine working better unplugged the sound and wiggled the plastic coated wire above the large fan works but freezes maybe once in a day some days never have the sound running through the receiver (surround) I shut it off and it comes back on when it does freeze figure loose connection
Posted on Jan 06, 2008
SOURCE: 52 inch rca rear projection tv wont turn on
I have the same problem. I had someone come look at it and he showed me the problem but a terrible price, so i didnt have it fixed. The reason the light blinks is there is a problem and the safety mech is kicked in which shuts the TV off. If you take the back of the TV off, about 15 screws, you will see right in the front on the left side a part shaped like the letter "C". The number on top of mine is S5 19 2. That is the part that needs to be replaced. Now to find the part on the internet and figure out how to change it out. any suggestions?
Posted on Nov 05, 2008
SOURCE: Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Posted on Aug 13, 2009
My 50" samsung projection tv
Your power supply board is dead, you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
May 13, 2011 | Samsung PCJ522R 52" Rear Projection...
My Samsung HLR5067 was working fine last night. I left the house open and it dipped in temp (only to 40 degrees or so though)...Woke up this morning and it wont turn on at all. Just beeps a few times,...
Tv projection Lamp might be some how the causes again.Tries unplug,replug tv back like about an hour later.Try it again,should work now.If not,yes the projection lamp,might have been kill by the cold weather.
Dec 06, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I was watching tv then it shut off i tried multiple outlets but still wont turn on the little light in fron does turn on but nothing else
When you try to turn on the TV that when the light on front comes on or is it on when you plug in the TV to an outlet? I
Aug 28, 2010 | Samsung HLN5065W 50" Rear Projection...
Tv wont turn on
I have a Philips 60" Rear Projection, and all of a sudden I have no picture or sound. I push the power button, and all it does is click. It will keep clicking until I turn it off. Anyone seen this problem?
May 15, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Have to frequently replace lamps on Samsung 50% rear projection
U hear many clicking atemp,before the tv even turn on or trying to turn on.Ur ballast it dying or dead.Replaced the Ballast to solved this.
May 03, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
My panasonic rear projection tv will not power on and no lights turn on. Any suggestions?
Please plug TV in another power source and turn it ON,
if still does not turn ON, unplug AC wire of TV, take off back cover and follow AC cord f TV that will take you in power supply board, find fuse nearby and check is it blew off? if yes, replace it with same ratings written on it.
Plug TV in AC wall socket and turn ON, if fuse blow again that means power supply section in TV got problem and need qualified tech to find out and replace components or power board.
Thanks.
Sep 18, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Fuse Blowing Repeatedly
if you are not a tech have one check your tv,the voltage regulator is shorted and needs to be replace.this component can be found in the power supply.i do not have the part number and location as i have no schematic for this set.
good luck
May 03, 2008 | Televison & Video
Tv wont turn on
Unplug it for 20 mins then try again plugged in.
It could be something as simple as an inline fuse but dont try opening the set EVER with it plugged in.
Feb 24, 2008 | Zenith IQB50M90W 50" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
