Question about Craftsman 25cc Gas Line Trimmer
Champion spark plug number for craftsman 25 cc trimmer model number 316.711470
  • 8 Answers
SOURCE: 32 cc craftsman trimmer starts but will not run at full rpm
Air fuel mixture problem,,,you need to have the filter pulled out and cleaned. Check fuel system for debris and clean, that includes all the fuel lines and possibly disassemble carb and clean and reassemble.
Posted on Apr 27, 2010
rycgl
  • 1545 Answers
SOURCE: 25 cc craftsman weed trimmer.\r\nNot getting spark
If you're sure it's not getting spark, the first thing to check would be the "air-gap" setting between the magnets on the flywheel and the ignition coil module . The correct setting basically only requires the use of a regular business card and is around .010"-.014" If there is an air gap present, check it and then you can move on to diagnose the coil module ( they don't go bad very often) if necessary.
Posted on Jun 09, 2010
rycgl
  • 1545 Answers
SOURCE: can you recomend a cleaner
Any petroleum based cleaner added to the fuel will dilute the gas/oil mixture, thinning it and possibly not allowing enough lubrication during operation; if this is a 2-stroke engine. This is not recommended. Removing the carburetor and cleaning it is usually the best and accepted way to go.
You can do this on a 4-stroke engine and there are many, many choices for fuel system cleaners available for these. You just pour the cleaner into the fuel tank and run it. If this is a 4-stroke, then check for cleaners at your local auto parts store.
Posted on Oct 10, 2010
rycgl
  • 1545 Answers
SOURCE: I need to purcase Air Filter
A small engine repair (lawn mower) shop will have all those items you need. You could order directly from Sears is you prefer but it is pricey. Here are a few places online.
http://www.searspartsdirect.com/partsdirect/index.action
http://www.outdoordistributors.com/Craftsman/Craftsman_Search.html
http://www.fourbridgessmallengine.com/id4.html
Your trimmer is a Poulan product and may come up on these sites as such.
Best bet is a lawn mower shop but you can probably find all those parts at Home Depot. I know the spark plug and filter are there. Take the primer bulb with you and compare.
Posted on Nov 02, 2010
rycgl
  • 1545 Answers
SOURCE: I have a craftsman convertiable,
My work and research show that most problems of this type are fuel system related. There is no "miracle" cure to keep the 32cc engine running. Many different things come into play here. The most common problem is dried out parts inside the carburetor. There is a small gasket and diaphragm kit to cure this however.
Your fuel system must be fairly new and with a clean fuel filter inside the fuel tank. The old fuel lines tend to become brittle and flakes of them break off and enter the carb. They get lodged on a very small screen filter that allows fuel to flow thru the carb.If fuel lines are old or brittle, replace them.
Another problem is that the carb has gone "out" of adjustment or never was adjusted correctly in the first place (not uncommon). With new, stringent EPA and CARB laws and regs, the manufacturers of these carbs set them to run very "lean". This means a lot of air and very little fuel. The problem here being that the lubricant for the engine (in this case) is IN the fuel.
Check the condition and color of the spark plug. It will tell you how the engine is performing. Clean the black carbon off of it and reinstall, or just put a new one in.
So brittle fuel lines, old, stale fuel, clogged up screen strainers inside carb, weak spark and misadjusted carbs can ALL contribute to your machine's problem. It is NOT rocket science but some standard diagnostics and testing is required to narrow down exactly what the problem is. Take a look at the things I have mentioned and remember, I have no idea how OLD or in what mechanical condition your machine is (even though I own one just like it). Post back as needed.
Posted on Sep 04, 2011
On my craftsman 25 cc weedeater...i lost the little screen inside the carborater that everyone on here says not to lose....now what do i do?
As much as I hate to say this...
AFTER CHECKING eBay... get our PRECISE
model number and give SEARS PARTS a whirl...
Just button you pockets (in my humble opinion)
Water Filters Lawn Garden Appliance Parts
Nov 12, 2016 | Craftsman Garden
Champion strimmer 25 cc cord
its a pdf
Champion Strimmer Manual - 64.140.158.30
64.140.158.30/champion/champion-strimmer-manual.pdfhomelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s ... kimmel manual kawasaki petrol strimmer tg24 manual ' champion ...
Jul 17, 2016 | Garden
Need spark plug
Champion spark plug RCJ6Y
May 04, 2013 | Garden
I have a Craftsman 917377590, and I cannot find any information non what spark plug to put in this thing.
It is more than likely the Champion J19LM. But to be 100% certain, go to:
http://www.championsparkplugs.com/Default.asp
Click on Vehicle Type - Lawn and Garden / Category - Lawnmowers / Make - Craftsman and then select your motor model number and this will return your models spark plug. You can get your motor model number off of the tag on the top of the motor. You are good to go.
Jul 14, 2011 | Garden
I need to purcase Air Filter Prime Bulb Spark Plug (Champion RCJ-6Y) for Craftsman Gas Grass Trimmer Model # 358.791070 Serial # 32CCTWC
Nov 02, 2010 | Craftsman 25cc Gas Line Trimmer
Jun 08, 2010 | Craftsman Garden
My craftsman 32 cc 2 cycle line trimmer doesn't
Check the line head and cable, there may be grass or something like twine twisted between the shaft and housing. If nothing is found there take the spark plug out and see if it will turn over, possibly liquid gasoline has gotten into the cylinder somehow.
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
Spark Plug for Briggs & Stratton Engine
you'll need a champion J19LM [or RJ19LM, same plug except the RJ is a resistor plug]
Mar 23, 2009 | Craftsman Woodstock Percussion Crcbm ...
Craftsman 25cc Gas Line Trimmer Logo
29 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
