SoundCube Troubles My SoundCube won't work! Disassembly help?
    Problem Solver:
  • 8 Answers
Like I said run audio through the USB ,RCA ,3/8 audio and the 5/8 audio ports if you get audio it is the one port is bad if all fail it may be the amp. and test the speakers if speakers respond to audio signals from another amp then it is more than likely is the factory amp in the cube that failed
Posted on May 07, 2013
Truck troubles
inspec idle air control motor-they wear--or the throttle position sensor--both found on air intake----------get a scan done and pick up a haynes manual at a parts store
Jun 26, 2013 | Cars & Trucks
Lift is out of vehicle and won't go up or down
Sounds like the jack screw has bound. That requires a complete disassembly and inspection to see if it just needs lubrication or a part.
Feb 27, 2013 | Pride Backpacker Avp Lift SSBPAVP
Whirlpool electric dryer
Hello there and welcome to Fixya :
This is a fairly common problem with these whirpool dryers.
I will provide you with the 7 most common things to look for
which contribute to the symptom Dryer won't stop are listed below. Check or test each item and watch any available videos. If you are still unable to solve the problem you may need to do additional research and troubleshooting.
Show all parts for model GEW9878LW0 For the symptom you selected, these are the most common parts or causes, ordered by the likelihood of fixing the symptom.
othercausesandconditions.jpg Air Flow Problem The most common problem when a dryer is slow is when the vent is clogged. If the dryer is slow, check the vent from the back of the dryer to the outside of the house. If that is clogged, clear it completely and test the dryer. If the dryer is slow after the vent is cleaned, clean the internal ductwork of the dryer. This will require some disassembly.
blower-wheel-694089-00918612.jpg Blower Wheel
Item # 686172
The blower wheel draws air through the dryer and pushes the air out the vent. If the dryer won't stop, the blower wheel may not be spinning properly, which reduces the air flow. Check to see if the blower wheel is securely fastened to the drive motor shaft.
Skill Level Skill Level
Part Replacement Video $23.40 Quantity:
In Stock
heating-element-assembly-3401338--00621237.jpg Heating Element Assembly
Item # 528055
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity.
Part Testing Video $91.05 Quantity:
In Stock
lint-filter-349639--00685658.jpg Lint Filter
Item # 2659
Dryer sheets and fabric softener can leave a residue on the lint filter, reducing the air flow. If the dryer won't stop, check to be sure air can flow freely, clean the filter as needed.
$38.95 Quantity:
In Stock
moisture-sensor-279366-00565298.jpg Moisture Sensor
Item # 469522
Although not as common, if the dryer won't stop it may be because the moisture sensor is either defective or coated with fabric softener. Clean the moisture sensor contacts inside the dryer and th
Oct 11, 2012 | Whirlpool GEW9878LW Electric Dryer
My laminator won't stop heating
so what model are you having troubles with
Aug 30, 2012 | Gbc HeatSeal H425 Laminator
Hi, i am having troubles with my laptop (HP 6735s), the fan is too loud, and it gets very hot. if there is a solution please help me out. i've also tried to buy a new fan, but can't find any...
@fatma_ahmed9
If you hear rattling or grinding noise from your fan, that's already a sign that it's breaking down and needs to be replaced and the computer will eventually gets very hot because it couldn't accommodate and blow the heat out of the processor anymore. If you know your way around the computer and want to replace the fan yourself, you can get spare parts here or here and disassembly guide here.
Good Luck.
Sep 04, 2011 | HP Compaq 6735s Notebook
When I start up the Acer Aspire M3710 Desktop it won't do anything but run the processor, it won't give any results of the POST and it also refuses to show anything on my screen (no Signal)....
1. Check the video cable (the one going from the monitor to the video card) 2. Check if the video card is properly connected to the motherboard (must be tightly plugged into the port)3.This could also mean that the drivers for the video card are not correctly installed
Jun 13, 2011 | Computers & Internet
Dear sirs, I have a 2000 Ford Explorer which won't start. All light in the dashboard turn on but the engine won't crank. We've tried to crank the engine direct from the battery and it cranked....
yea got get you more troubles
just check the alternator is charging well and no battery light on dashboard it indicate the bad alternator
monitor your battery if it got old and cannot hold the charge any more
you said when you used another one your car turned on
Jun 06, 2011 | 2000 Ford Explorer
My Paloma tankless water heater stopped working after we had a block out, all the lights are working and doubled checked the electrical connector.... it just won't turn on as it should when I run the...
Try reseting it by unplugging it. Also is there any display lights on (troubles). If that dont work it might have fried the circuit board in the black out.
May 09, 2011 | Heating & Cooling
310 people viewed this question
 Grubhead
Grubhead
