Question about Lenovo IdeaCentre Computers & Internet
Media test failure ideacentre 320
Media test failure
  • Lenovo Master
  • 32,281 Answers
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty.
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Posted on May 05, 2013
I have lenovo IdeaCentre A300 the hard drive died and needs to be replaced does anyone know where i can get directions i already checked youtube no how too videos.
Here is a YouTube video showing how to replace the CPU on an IdeaCentre A310, which should be similar to the A300. When he takes off the back cover, you can see the hard drive on the right side.
CPULenovo IdeaCentre A310 Core i3 350MCore i5 460M
Feb 03, 2015 | Lenovo 40181EU IdeaCentre A300 AllInOne PC...
IdeaCentre B300 power failure
first check if there is power failure in your locality
check if switch is on
check if UPS is working
check SMPS
if sms ok then check motherboard
could be static current in ram
May 03, 2014 | Lenovo IdeaCentre Computers & Internet
My optiplex 320 is making two high pitched beeps on starting boot, also im not getting anything on the monitor
James,
It sounds like the refresh rate is set to high. Since you do not mention what OS is installed I have listed information on how to change in Windows,XP.
Start the computer and press the F8 key. Choose Safe Mode. Once the system gets into Windows follow the steps below and then restart the computer. If this does not resolve your issue email me at my email address below and include your OS information.
How to Change the Screen Refresh Rate of Your Monitor
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Or your system is giving off a beep code in which case the beeps come in a 3 beep sequence. Below is the beep codes and what each represents.Beep Codes
Troubleshooting steps and more information about the OptiPlex 320 beep codes Beep Codes Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3-1 through 2-4-4 DIMMs not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller Test failure 3-3-1 NVRAM power loss 3-3-2 NVRAM configuration 3-3-4 Video Memory Test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No time tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math coprocessor test failure 4-4-4 Cache test failure
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email jesse_leonard@dell.com
Sep 18, 2013 | Dell Computers & Internet
Pxe E61 Media Test Failure Check Cable
my server ph prolite doesn't start gives an error essage "PXE-E61: Media test failure, check cable" the reboots after 5 seconds
Apr 22, 2012 | HP ProLiant DL180 G5 Server
Usb power failure lenovo idea center k210
use a powered usb hub a 3 volt unit will do it
Feb 25, 2012 | Lenovo IdeaCentre K210 - 53132CU PC...
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
Media Test Failure, cheack cable. What exactly
This means that the "Media" CD, DVD, HDD has been "Tested" by the Window Operating System, for veracity, and has been found NOT to have passed the "Test", therefore windows WILL NOT USE IT, as it doesn't want the data corrupted. This usually means that the device is defective in some way. Replacement is the usual answer.
Mar 22, 2010 | Acer Aspire 5735 Notebook
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
Graphics card failure
the error: (Under this test, results show Error code 5300: 0119, which different comments for different parameters) Msg: Detected a failure while writing and reading video memory. (e.g.) Video mode: Dh (320 x 200 16) Address A002Ch, expected to read Oh, but read 1Dh instead *
indicates the video card has failed and need to be replaced.
Apr 14, 2009 | Dell Inspiron 8500 Notebook
PXE-E61: media test failure, check cable.
Save your self a lot of reading, do this first.
Check in BIOS rom for start up sequence and check if there is an asterist (!) in front of the hdd. If there is, it’s disabled. Select the hdd and press shift key plus “1′ This removes the ! and you can then use the hdd to re-format or….
Dec 15, 2007 | Toshiba Satellite A105-S4004 Notebook
Computers & Internet Logo
131 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
