Question about Dyson Vacuums
Turbine head dyson dc32
The turbine head in not rotating well what is the problem?
  • Dyson Master
  • 18,424 Answers
Make sure the yellow knob is pulled all the way out the link below is th manual
http://media.dyson.com/downloads/uk/floorcare/manuals/dc32_uk_manual_060710.pdf
Posted on May 04, 2013
  • 53 Answers
SOURCE: my dyson dc17 amimal's main turbine head is not
Right next to the power switch is a switch that will turn on/off the beater brush. Push firmly on this button and see if that turns it back on. It will turn itself off if it has too much resistance on it from getting tangled in something like a long carpet fiber that wraps itself around the beater brush. Check and make sure it's not bound up by something and then press the on/off button for the beater brush.
Posted on May 31, 2010
VacuumRepair
  • 438 Answers
SOURCE: hoover steam vac all terrain turbine gear assembly
I'd be happy to walk you through this repair. Unfortunately this is a very common problem with the Hoover SteamVacs.
Here's what you'll need to complete this repair:
- Hoover Turbine Assembly For Model F5866-900 Part # 43191001 or 90001354
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to unclip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before tighting the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
That's about it. If you have any trouble with this repair, please don't hesitate to use the Clarification request form here on Fixya. I'm always more then happy to answer any follow up questions that you might have. If this repair was helpful to you, please help other Fixya members with this same problem find my repair by rating it helpful. You can do this by clicking the 4 Thumbs up icons in the right hand corner.
Thank you very much,
Chris J.
GoVacuum
Posted on Apr 10, 2010
Testimonial: "Excellent description! Thanks for the great solution and pictures to help!!!!"
SOURCE: turbine head of my Dyson DC08 does not spin
This response is likely too late coming, however for others the problen appears to be the same as the fault with my turbine head which was that the turbine fan had become loose on its spindle. With no pressure on the brushes, friction would allow the fan to turn and drive the brushes via the belt. The faulty part is not available separately however I have repaired mine using araldite glue. Other things to check is for a worn belt. Cheers.
Posted on Apr 28, 2010
SOURCE: Need to dismantle a dyson
I just cracked this. The cover can be prised off using a flat-blade screwdriver. There is a little slot for this. I imagine there is a proper tool for the job, because it's a bit difficult and a bit frightening, but it does come off. I couldn't do the same with the larger cover on the other side, though. My brush wasn't rotating, so I squirted as much WD40 as I dared in as many orifices as I could find, and, lo and behold, on reassembly it started working again.
Posted on Oct 01, 2010
small6363
  • 18424 Answers
SOURCE: We have a Dyson stowaway
this link may help you
https://www.dyson.co.uk/support/help.asp?article=984&product=DC20-STOW-STD
Posted on Dec 28, 2010
Hi Im using the tangle free turbine tool on DC32. looking bit dirty, pet hairs around filter and not picking up well. Is there anyway of removing filter to clean it? Or take head apart at all?
Hello, this is Ava with Think Crucial.
It is available to wash you filter every now and then and necessarly replace the filters for optimal performance. For instructions on how you can wash the filters, please check the online manual below by clicking the link:
Dyson DC32 Operating Manual Page 4
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 24, 2017 | Dyson Vacuums
Turbo head has stopped spinning
Hi Fay, it's Jack at Dyson.
If your DC39 Multi Floor's turbine head has stopped spinning, this could mean there's a blockage in the turbine head, wand, hose or lower duct hose. This could reduce the airflow passing through the machine, which in turn will affect the turbine which powers the rotating brush bar.
It's also a good idea to check the Turbine head is free of any threads, hair or other obstructions:
If you need further help once you've given this a go, you can reach our experts at the Dyson Customer Helpline by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
Mar 05, 2016 | Dyson DC39 Multi floor canister vacuum...
Dyson DC54 brush bar not rotating. Have removed all the hair, cleaned the brush and replaced, still not spinning.
Brushbar not turning Clutch check - Dyson
www.dyson.com/...dyson...not.../brushbar-not-turning-clutch-chec...
DysonBrushbar not turning - Clutch check. Please ensure that your hands are clear of the soleplate and brushbar before completing this test. Clutch check.
Resetting the brush bar (Official Dyson video) - YouTube
? 3:52
https://www.youtube.com/watch?v=AiKnefEr7ns
Jan 16, 2014 - Uploaded by AskDyson
How to clear and reset the brush bar of your Dyson DC41 Mk2, DC55, ... Dyson DC41 Mk2, DC55, DC65, DC66 - Resetting thebrush bar (Official Dyson video) .... Dyson Cinetic DC52, DC54with the Musclehead™ floor tool ...
Dyson DC44 - Remove & clean the Brush Bar - An owners ...
? 4:13
https://www.youtube.com/watch?v=_0a71p84sp8
Nov 12, 2012 - Uploaded by Tom Strong Reviews
Here is the fantastic Dyson Digital Slim Mk2 DC44 Animal. (DC45 in ... Europe) Here I show how to remove and clean the Brush Barof any tr... ... It is and easy operation and one you need to do whenever the brush is not clear.
Dyson DC54 Support - Turbine head not working properly
https://www.dyson.com.au/.../dc54/dc54...not.../turbine-head-not-workin...
Dyson DC54 Support - Turbine head not working properly. ... If you cannot clear an obstruction you may need to remove the brush bar. Use a coin to unlock the ...
Jan 24, 2016 | Dyson Vacuums
How do I get a new belt to repace a broken one in a DC23 turbine head
Hi there, it's Jack at Dyson.
The Turbine head's belt is not a part we would ask a customer to fit, and therefore it's not available as an individual component. It's part of the turbine drive mechanism, and we'd advise against attempting to dismantle this as it could result in damage to the Turbine head. If the Turbine head happened to fail within the Dyson warranty period we should normally be able to replace it, as long as it's been used and maintained according to the User guide. Out of warranty, a replacement Turbine head could be chargeable.
If you'd like some additional help or advice from our experts you're welcome to contact us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 07, 2014 | Dyson DC23 Turbinehead Canister Vacuum...
Why does it not fit?
Hi Clint, it's Jack at Dyson.
DC24 is not compatible with the original Mini turbine head as this tool is engineered to work with the performance characteristics of our full size upright and canister vacuums.
However, we do make a Mini turbine head which is compatible with DC24 - for help ordering this, I would encourage you to contact us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA). Once we've taken the serial number of your machine we'll be able to confirm the correct Mini turbine head for your vacuum.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Nov 08, 2013 | Dyson Mini Turbine Head Universal Fit,...
Dyson mini turbine head
I can't tell from the information provided what sort of issue you're having with your mini turbine head, but you may find our support guide of use in resolving any difficulties:
http://support.dyson.co.uk/support/dc11/dc11-all-floors/maintaining-your-dyson-machine/how-to-remove-a-blockage/from-the-mini-turbine-head/mini-turbine-head-not-working-
Alternatively, one of our advisors will be happy to provide assistance if you call our free Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
http://www.dyson.com
Feb 08, 2012 | Dyson DC11 All Floors Bagless Canister...
Dyson32 animal removing turbo brushes for cleaning
For directions on removing the brushbar from the large turbine head, please follow the steps shown in our online support guide:
http://www.dyson.co.uk/support/help.asp?article=1694&product=DC32-ANIMAL
To remove the brushbar from the mini turbinehead, please refer to these directions:
http://www.dyson.co.uk/support/help.asp?article=1690&product=DC32-ANIMAL
Hopefully this should give you all the information you need - however, if you need any additional assistance, please get in touch with us directly on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Oct 07, 2011 | Vacuums
I have a DC32 animalpro and there is very little suction on the large carpet cleaner head. When I use another head the suction works normally. I have checked for blockages and there are none. Any...
I'm sorry to hear you're having difficulties with your DC32 Animalpro. If the turbine head doesn't seem to be working correctly, and is not blocked, you may need to wash the cleaner's filter. Under normal use, this needs to be done at least once every 3-6 months. Use cold water without detergent, and allow the filter to dry completely before replacing it - this may take up to 24 hours. For guidance on washing the filter, please see the guide linked below:
http://www.dyson.co.uk/support/help.asp?article=1847&product=DC32-ANIMAL
This should allow you to resolve your issue without further assistance, but if your problem with the turbine head persists, please get in touch with us directly. If it's necessary to replace the turbine head, it should be covered by our 5-year warranty, as long as the cleaner has been used in accordance with the terms and conditions listed in the user guide. You can call us free on 08002980298 - our Helpline is available from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Sep 10, 2011 | Vacuums
Vacuums Logo
357 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
