Question about Fascinations Fantazein Clock . XP3 Programmable Message Clock
Fantazein clock manual
How do you program the clock
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
I need owners manual to program RCA RC140-A alarm clock
Hello
Send your Emai Address to me. I've the user manual for your RCA RC 140. I actually do not remember, from which site did I downloaded it. I can't send it to you by this window, as it does not allow me to upload PDF fiels by it. If you send your Email ID, I'll send a copy of it to you by return mail. OK.
Nov 27, 2011 | RCA Radio Alarm Clock
HOW DO I SET CLOCK
1 Press STANDBY/ON to turn off the unit, if it is turned on.
The clock flashes on the display window.
2 Press and hold PROGRAM/CLOCK SET for more than 2 seconds.
The hour digits start flashing.
AM
3 Press the CD forward or CD back button (track skip buttons) to adjust the hour, then press PROGRAM/CLOCK SET.
The minute digits start flashing.
PM
4 Press CD forward or CD back button (track skip buttons) to adjust the minutes, then press PROGRAM/CLOCK SET.
I hope this helps.. !
If you need more info have a look here for the manual which is in pdf format:
The clock information is on page 10
JVC RC-EX25 manual
Regards
Mike
Oct 12, 2010 | JVC RC-EX25 Radio/Cassette/CD Boombox
My clock went back one hour on Sunday 10/25, need to get it to move ahead one hour.
The clock program for Daylight savings Time is programmed for the old "third Sunday in October" changeover. The new changeover is the first Sunday in November. The program probably cannot be updated. If there is no button or setting to disable automatic change to Daylight Savings Time you can set the time manually and then change it manually to Daylight Savings on November 1 for the time to be correct.
Oct 26, 2009 | Emerson Smartset Clock Radio
Repair of Fantazein clock
If the moving spindle, where the LEDs are attached is either not moving, or jittering when power is applied, it is most likely that the PNP transistor (only one on board) is burnt and needs to be replaced by the like of 2N3906. It can be located next to where the speaker wires (x4) are soldered to the PCB, and next to the snubbing diode.
Bic Tran
May 17, 2009 | SkyScan 86742 Digital Atomic Wall Clock
Programing clock on saeco coffee pot
You can get the instruction manual for your machine at saecooutlet.com, Click on user manuals and then select your machine.
To set the clock, hold the hour or minute button until the display flashes then adjust the time.
Feb 01, 2009 | Saeco TDCM15 Renaissance Stainless Steel...
I have just been given a Panasonic microwave (NN-E255W)but have no idea how to program the clock, no manual either
On most microwaves, to program the clock you press the button marked, "Clock," or "Timer/Clock," or something similar. You then enter the time on the keypad by pressing just the numbers for the current time, then press the clock button again.
Mar 03, 2008 | Microwave Ovens
Fascinations Fantazein Clock . XP3 Programmable Message Clock Logo
278 people viewed this question
Top Fascinations Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Fascinations Audio Player and Recorder Expert? Answer questions, earn points and help others
