Question about Kenneth Cole Watches
Kc3995 p93-11 trying to replace links on steel band
4 Suggested Answers
escapement
  • 2334 Answers
SOURCE: how do I adjust band on a guess g95290g guess steel mens watch ?
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Feb 16, 2009
  • 8 Answers
SOURCE: link removal from band
if you don't have the necessary tools or knowledge then your best bet is to take it in and have a professional remove the link(s) for you. It all depends but sometimes if you take it to Macy's or Neiman's they will do it for free.
Posted on May 23, 2009
  • 9 Answers
SOURCE: need watch links cartier stainless steel
Cartier does not police watches. On the contrary, questions about how you obtained the watch could result in a libel/defarmation of character lawsuit against them. They are way too smart to fall for that trap. They are not the police. By the way their records are private and they would never engage in a witch hunt that could come back and bite them in their very very deep pockets. What that other guy said here is not true. (see more of my comments on this in my answer to the Pathere watch owner looking for links).
Posted on Oct 26, 2012
I have a ESQ E5262 stainless steel and the band is a little tight. I am looking for a band link.
go to a jeweler or watch maker as they often have spare links from bands they adjust in shop when making a sale
take the watch in to match the links
Nov 11, 2015 | ESQ Watches
How do I adjust the band on a Casio AQ 160 watch?
try this link below there are several diffarant band adjustments that may help you
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Nov 02, 2012 | Casio Watches
How do I adjust my watch band?
If you want to deuce the size of your band then I have found some instructions on the Fossil website and since most watches are very similar you can try the method described there.
If you need to replace links then you can get them for Skagen (free!).
Go to "fossil.com", go to the bottom of the page and you will see a menu, click on "customer care", and then look under "Product Info" on the left and you will see "watch instructions"
Go down the list to the bottom and under "Phillipe Stark" there is an item "bracelet instructions"
Feb 14, 2010 | Skagen 355LGSC Wrist Watch
Broken Watch band
you probably just need a pin to secure the links back together. an authorized Movado retailer will have the tension or screw pins to put the band back together. They can also order additional links if needed. you can find a local retailer on www.movado.com
Jan 07, 2009 | Watches
Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
To shorten the band you have to:
Extract the pins.
Take link(s) off.
Join the rest of band together and drive pins back.
Jan 01, 2009 | Fossil JR8096 Wrist Watch
Stainless steel band won't snap into my watch
Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
Another way is to use curved spring lugs (pins).
Dec 12, 2008 | Philip Stein Teslar Large Gunmetal Watch
Band Replacement
The replacement bands for the Cartier 21 Chronoscaph are a complete rip off. Get a replica one!
Now, where can I get a replica one... anyone know please? Thanks.
Feb 22, 2008 | Cartier 21 Chronoscaph W10125U2 Wrist...
Watch band repair
Cleaning yellow Nautica plastic or rubber wach bands
Oct 31, 2006 | Nautica N07518L Wrist Watch
Watches Logo
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
