Question about Maytag CWG3100A Gas Single Oven
Oven will not light. i think it is self lighting as i have never lit a pilot light.
  • 1 more comment
  • Anonymous Dec 23, 2007
    pilot
  • ejgp Dec 23, 2007
    pilot light is lit but oven does not heat up
  • Anonymous Oct 25, 2008
    my oven will not light. Broil works, the range top works, the self clean works, but the damned oven will not work on bake.
    Sergeant:
  • 415 Answers
does your oven make a clicking sound? if it doesn't it's the spark module, if not it's the electrode.
Posted on Sep 14, 2008
6ya staff
SOURCE:
Hi The pilot light when out and the oven has stop working does the pilot light double as a fuse ?? BSO 6000
No. The pilot light uses a thermocouple(safety device) to let the main gas valve know that the pilot is lit so that the main gas valve can operate safely by not letting the main gas valve turn on without a lit pilot light. This way, in no way can the main gas valve turn on until the heat from the pilot light causes the thermocouple to produce an electrical current which allows the main gas valve to operate when the thermostat switch closes.
Nov 22, 2015 | Ovens
Blodgett pizza oven won't stay lot. Pilot stays lit as long as oven is off
Sadly when dealing with GAS I prefer not suggesting any self repairs . call a certified gas repairman .
Sep 25, 2015 | Blodgett Ovens
Oven wont lite
if its a pilot lightr that stays lit all the time,then its the thermocouple next to the pilot light thats bad and cant keep the pilot on
Nov 24, 2012 | Ovens
Dont know how to light oven with pilot light
So-- your oven DOES have a pilot light?
Most ovens today, use ignitors-- not pilots--
However, if yours does have a pilot, Here is how we used to light ours back home many years ago.
We pushed in on the oven's thermostatic (Temperature control) knob.
(Note-- that knob connected directly to the main gas valve-- so by pushing in on the knob, we were by-passing the safety's---
There was a little hole in the center of the oven-- bottom pan...
We had to have a match lit, and ready to go when we pushed in on the knob--
We inserted the burning (Wooden) match into the hole, and 'WHOOSH'!-- the pilot lit with a rush of gas and air-- It used to scare us kids!-- But Mom was brave!
I hope this helps--
But if you need more help, let us know--
Mack B
Jan 19, 2011 | Ovens
Pilot light is lit both on oven and stove top... previous user says to turn on gas and lite "sensor" or "2nd pilot" it stays lit as long as oven knob is on but oven burner does not light. "sensor" goes out...
On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 06, 2010 | Magic Chef 9122 Gas Single Oven
Oven won't get hot
If your oven still uses a pilot light, it also probably has a thermocouple positioned in the pilot's flame path to detect whether if is safe to turn on the main burner. When the thermocouple fails, the oven thinks the pilot light is not lit and will not let gas flow to the primary burners. The part isn't costly (should be <$20 US) but replacing it may require some expensive labor.
Feb 11, 2010 | Frigidaire 30 in. Electric Gallery Series...
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
Pizza oven does not light
thanx for the email reply .oven lighting problem was caused by the pilot light not quite touching the flame tubing
Dec 17, 2008 | Bakers Pride Y-600 Gas Single Oven
Whirlpool Super Capacity 465 Gas-pilot light won't stay lit
I have a whirlpool accubake system / super capacity 465 oven ... the top burners do fine...but my oven pilot went out... and I don't know how to re-lite the pilot... the owners manual doesn't help ... it doesn't show anything a layman could understand ... no visual illustrations ... when I turn on the oven ... the display shows that it's been activated... it clicks a couple of times but does not light ... what is a simple way to re-light the pilot? thanks, A
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Maytag CWG3100A Gas Single Oven Logo
168 people viewed this question
Top Maytag Ovens Experts
Marvin
Marvin
Paul Carew
meowwl
Level 1 Expert
Are you a Maytag Oven Expert? Answer questions, earn points and help others
