Question about Dell Vostro Computers & Internet
Interactive logon process initialization failed
My lappy was hanging during startup so i decide to format the harddisk...but it show this error when the installation of window is almost to complete...i already try to 2 3 times of fresh installation...wt to do?
ComputerDave
  • 128 Answers
SOURCE: Acer Aspire 5100 will not log on
If you have a Finger Print scanner (on select models), it may have failed, if you do not have this device , you may have installed malware - try rebooting and after you see the Acer screen start tapping F8 to get to speacial boot menu - choose Safe Mode and see if you can log in. If still unable, you will have to perform a system recovery - Acer provides an alternate way to recover - when you start the computer you see the Acer logo screen - after this displays hold down the Alt Key by the spacebar and tap the F10 key at the top of the keyboard once or twice - this will start the Acer E-Recovery program - follow the on screen instructions.
Posted on Jan 31, 2008
Rubec
  • 42 Answers
SOURCE: Bootup problem
Your CPU is overheating.
Try and get into the BIOS and increase the fan speed & any aother fan on the system. Don't increase the temperature range, as this will damage the system.
You won't be able to sort out the software problem until the system is running within the hardware limits.
You can also run a office fan to help get the system to cool while making the changes in the BIOS.
Posted on May 11, 2008
joelmar
  • 96 Answers
SOURCE: LOGON PROCESS INITIALIZATION FAILURE
Assuming you are using Windows XP. There's some file corrupt or missing when you start your pc. If you have floopy disk you can boot disk, it not your can insert your Windows XP installer and then you can repair you OS.
Posted on Jun 26, 2008
gnkanang
  • 63 Answers
SOURCE: Windows XP SP2 Repair
Solution: Rename the C:\WINDOWS\SYSTEM32\CATROOT2 folder to something such as catold to prevent WinXP's Setup program from locating the folder and halting the installation. If you are still in Setup, press SHIFT-F10 to launch a command prompt from within Setup. At the command prompt, type cd\win dows\System32 to open the System32 folder and then type rename CATROOT2 catold, press ENTER, restart the computer, and attempt the upgrade again.
If you cannot reach a command prompt from Setup, reboot the computer from a Win95, Win98, or WinMe startup disk and rename the folder from the command prompt. You can also launch a command prompt by booting from the WinXP installation CD and running the Recovery Console.
Posted on Mar 25, 2009
heavyice
  • 374 Answers
SOURCE: HDD not recognized whe installing fresh Windows XP!
Go to the BIOS setup, & change the disk controller setting from AHCI to IDE. might worth the try. Some Laptops don't have option of SCSI or IDE. But there are SATA Enable/Disable option. Try disabling SATA.
You will be able to load XP but I suggest you to install Dell Vostro and SATA drivers.That you'll probably find it here:
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=VOS_N_1400&hidos=WLH&hidlang=en&TabIndex=
Posted on Jul 31, 2009
Interactive logon process failed
I would attempt either trying to login as administrator, and if not then a Windows OS repair with the operating system disk. This should repair any of the OS files allowing you to login again.
Dec 29, 2013 | Computers & Internet
Asus netbook
Have you tried to boot in safe-mode?
try f8 on boot up and when it ask what to do. load "last good profile that worked.
Open up a command prompt from your recovery options and copy C:\Windows\System32\winevt\Logs\Application.evtx to an external disk. Get on another computer with Vista and open up Application.evtx with the Event Viewer. Find the error where SideBySide is the source in the event log and it should say something about an error in some manifest file. Now go back to your computer and replace that file on your C drive with a copy of that file from your recovery partition or recovery disk. Restart your computer and it should work.
Dec 17, 2013 | Computers & Internet
When i switch it on it boot alright the after booting it tels me that logon process initilla
You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode). Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 10, 2012 | Samsung N150 (36725723009) Netbook
When i startd my laptop(dell Inspiron) i got error msg as "interactive logon initialization failed ". I tried to login in safe mode still i got same msg. when i run diagnostics utility, 0F00 131B...
You have to make a new account on the computer to resolve this issue (Or a fresh format/factory reset). If you are able to log in at all, make a new account and move your data. Otherwise, factory reset might be the easiest solution. You can recover your data by removing the hard drive and using an external hard drive to usb cable if you are not able to log in at all.
Jun 29, 2011 | Computers & Internet
Start up is very slow and its hanging all the process is stopping with hang what can i do will u pls help me to come out of this problem
this problem may be attributed to many programs loading during start up
Startup tasks can be easily disabled with the help of a utility by Microsoft called Autoruns. You can download Autoruns from this link. After download, unzip and run Autoruns.exe . It will load like snapshot below. Click on Logon tab as shown in red circle in picture below.
Logon tab shows all the tasks which are automatically start every time windows starts. Have a close look and disable some of the tasks which you don't need at startup. For example, in some computers, at logon, web cam software, acrobat reader, real player up-dater, yahoo messenger , etc. applications start running while you may not be needing the all the time.
To disable un-necessary items to load at logon, simply un-check those items in the log-on tab as above. These applications can be started later when needed from start menu. After un-checking, just restart your computer and see the difference.
Jun 16, 2011 | HP Pavilion dv2000t Notebook
Hi everyone, I'm having the same problem too.. Everytime I start my laptop, It show these two option: Startup repair or Start Windows normally. I "Start Windows normally" and then it comes...
Hi.
It looks like your going to have to perform a full system recovery as you are not getting anywhere with start-up repair or safe mode.
For a full system restoration, press the F11 key during bootup and then select "Recover PC" from the menu.
Regards.
Jan 25, 2011 | HP Mini 1000 Netbook
Interactive logon process initialization has failed
Can you start on safe mode? If you can do that and go to C:\ and type dir/p and look for any file regardless of its extensions that created at the time you lost control, and keep note of it then logout and start again in safe mode by pushing F8 at the startup few times tell you bypass the window startup and click on safe mode…login as admin and uninstall the software then search for any file that was created on the same day that you had the issues with and delete them including the one in the recycle bin. Logout and restart again as admin from safe mode and try to login to the net and go to free scan website and scan your system. If that did not work you can try to restore to the last day that you can and that will not effect your folder that you need unless it is new and after the restore dat..let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 20, 2009 | Dell Inspiron 530s Desktop Computer
Acer Aspire SA85 stays on Acer logo
Hi bob,
Usually system stops at the startup screen or the startup logo, when it finds some fault in detecting the IDE drives(ie,your harddisk or cd drive), if you dint get any get stuck in the logo, you have to see what happens at the background by clicking on f1 key or f12 or TAB or some key to show the activity rather than logo.....
After seeing the error we can conclude or decide about the problem, but when you were not able to see the screen after pressing any key as specified in your manual, Or it hangs after the LOGO screen, this must be problem with your harddrive, try changing the harddish or try connecting once again by removing it...
Enjoy Rate!
RNJ VINOD KUMAR
Jul 01, 2009 | Acer Computers & Internet
Deleting hard drive
I see..try the F8 option...that will take you to safe mode..
May 25, 2008 | Dell Inspiron 1300 Notebook
Login problem
hi selvathinesh
the problem is in ur operating system just reinstall it ..it would not show any messages trust me
shailesh
Mar 08, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
