Question about Toys
I need help
How do I put this together on a vauxall combo 02 plate
    Problem Solver:
  • 8 Answers
I suggest if you don't feel confident enough to do it yourself then go to your local auto electrician,
Posted on Oct 20, 2013
  • 3,457 Answers
First of all is it compatible with the locking system on an 02 plate. also you need to locate the central locking module on your car. and will need your cars wiring code to know what wire does what. some vauxhalls have a link system that is the engine ecu and central locking and immobiliser are linked. and if any one of them brakes the link the engine will not start. also there should be a book in the box telling you what wire go to what on a stander central locking system. some models don't work. there is a system that i know works as it fits in the driver door and works of the drivers door locking system....
Posted on Sep 30, 2013
Pit bike starts, idle and revs good. But when I put it in any gear it cuts out. No electric starter, battery or kick stand switch!!? Help please?
does this happen as soon as you put it into gear or does it do it when you let the clutch out,as this sounds like the clutch plates are stuck together,you need to drain the oil then take the clutch cable off ,then take the clutch cover off remove the bolts and springs from the clucth basket make sure you do this evenly,then you take the clutch plates out if they all come out together then there locked up pry them apart and see if there is blueing of the steel plates and check the fibre plate for wear or cracks ,if the plates are bluing you may need to renew all of the steel and friction as this may have been caused by slipping the clutch or not having the clutch adjusted right and you may need a different type of oil that is suited to wet clutches.hopefully it could be just a matter of it sitting too long without being used.cheers hopes this helps
Sep 18, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
Zafira juddering
vauxall zafira 1.8 04 plate auto . problem when on starting it doesnt let me rev and jerks on take off but after 2 minutes it runs fine worried incase start of bigger problem any ideas would be great.
Sep 15, 2012 | 2006 Opel Zafira 1.8
Can`t get netural
Yep I can help.The clutch has about 6-8 or more plates in it.When they are not used they can stick together.It needs to be taken apart,cleaned and put back together in exactly the same order.Instead of all the plates slipping,only a few spin.This goes into the g/box and makes it spin when it should be stopped.The fj have a great clutch in them.This may really help your problem.
Jul 11, 2009 | 1986 Yamaha FJ 1100
I cant get my 03 yz250f out of first and back into neutral
Your clutch is maybe malfunctionning.
Check if your clutch cable is tight enough.
Apr 02, 2009 | 2003 Yamaha YZ 250
Putting seat together
http://www.coscojuvenile.com/instructions/ or email consumer@djgusa.com give them your model and manufacture date & they can send you one.
Apr 30, 2008 | Cosco 02-442
Toys Logo
80 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
