Question about Palm TX Handheld
Hotsync problem Every time I try to sync my palm I get an error message. It says "The connection between your device and desktop could not be established. Please check your setup and try again." I don't know how to fix this...
  • ambermoon Aug 10, 2007
    I restarted my computer and ran the hotsync first thing. I got a different error message. I'll try again and see if it works next time. Thanks for helping. :)
    The hotsync problem now says: The connection betweet your device and desktop was lost. Some of your data was NOT backed up. Please check your setup and try again.-- So, it worked for a minute and then I got this message. It seems to get locked up on the sync documents. Does that mean anything?
    Problem Solver:
  • 8 Answers
With a USB 1.1 machine .. try this ...My work around - disconnect ALL USB devices from the computer, NO multiport hubs, make a direct USB connection to one of the available open ports, then reboot the computer. Upon gaining control, then try to hotsync. If I had any other items connected or ran any other programs prior to hotsync, I was not able to perform a successful hotsync. The qwerks of the T5 and the sync conduits. Hope this helps Bob
Posted on Aug 10, 2007
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
Unable to connect
Palm TX - Bluetooth Synch with Windows 8 - HP Support ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
www.hivmr.com/db/1dxpd1fc31admksspczm98j7fp979x1p
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Setting Up Your Palm Device's Internet Connection - For ...
www.dummies.com/.../setting-up-your-palm-devices-internet-connection...
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
Bluetooth syncing problem ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities Apple Inc.
Jan 03, 2016 | Palm TX Handheld
I am unable to HotSync and cannot load HotSync manager
Reinstall Hotsync manager and make sure selected port is correct. Use alternate method to sync like Infrared
May 29, 2009 | Sony CLIE PEG-TJ37 Handheld
HotSync error ((sys 0505) (0,841)
I also had this problem. Searched for a solution and found that the error message refers to older programs incompatible with newer models of the palm. If you do a Hot Sync on a different and/or newer model palm device there may be these incompatibilities. The usual problem programs are mypalm and mytreo. You need to delete them by
first doing a Hot Sync
going to Applications on the palm
tap on the menu icon (or the left upper corner of the display)
tap on Delete
go down the list to delete each of these programs.
Hot Sync problems should stop
If not, you need to do a hard reset and then slowly add third-party software one by one and look for problems.
Jun 23, 2008 | Palm TX Handheld
Trying to hotsync my desktop and my 755, and I use Outlook.
if using verizon go into the wireless sync application and select settings> connection> advanced settings> and select enable other sync apps.
Apr 07, 2008 | Palm Treo 755p Smartphone
Why will my Garmin not sync into my computer?
First, right click the hotsync button in the task bar and make sure "USB" is selected (assuming you're using USB...).
If that doesn't work, let me know.
Oct 06, 2007 | Garmin iQue 3600 GPS Receiver
Ibm workpad sync & port issues help!
You have your Hotsync software set to use a com port instead of USB. Right Click on the Hotsync icon on the lower right part of your PC desktop and change it to USB and you should be good to go. The IBM Workpad is just like a Palm. I have the Workpad C500 which is actually a Palm M500. If you have a Workpad C505 it is a Palm M505. Anything you can buy for a Palm M500 will work with a C500 and anything you get for a M505 will work with a C505. If you do NOT have a USB Sync cable for your Workpad I suggest you do what I did... Just get a combination Sync and charge USB cable at Staples or Best Buy for your M500 or M505 and use it. It was about 20 but you can get them cheaper on the Net. I hope this helps you!
Sep 14, 2005 | IBM WorkPad z50
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Sep 11, 2005 | Palm m105 Handheld
Sync fails with "too many open databases"
This is what I did to fix that error:
Hard-reset your Palm to erase all data (that usually involves pushing the small "reset" button on the back, then pressing the "power on" button until the device boots, and then pressing "up" to confirm the hard-reset)
After that, sync your palm. The sync software will ask if you want to use your existing profile or create a new one. Create a new one. Then the program will offer to sync your Outlook profile with your Palm. Click on "ok", and a message asking you to accept to sync your Outlook data with more than one profile will pop-up. Click on OK, again... and that's it!
Sep 07, 2005 | Palm Tungsten T3 Handheld
Palm TX Handheld Logo
226 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
