Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
My tract does not start
I was cutting the grass I try to turn off the tractor white smoke came out.I was not able to stated again
  • 24 Answers
Check oil if low some engines wont let it start because low oil level
Posted on Jul 28, 2013
SOURCE: TRACTOR BLEW WHITE SMOKE, AND STARTS TO SPUTTER
Start with making sure your oil lever is not over full. If it is it may be getting into the crankcase breather hose that goes to the carburetor hence the white smoke. Sometimes also you can blow a gasket in the breather system and it will do the same. Check for oil leaks in the breather system. Hope this helps. donnyb60
Posted on Mar 21, 2009
  • 3911 Answers
SOURCE: cutting unevenly
Set the mower on a known flat piece of concrete. Now look at the deck and the support connections where the deck hangs from from the mower. Should be adjustments such as pins with clips or threaded bolt hangers which will allow you to raise or lower the corner of the deck which is low or high. Conversely you could have put a blade in upside down or left out a washer making one blade higher than the other. Usually an owner's manual will detail this process. As you just changed your blades, as opposed to wear and tear, likely you did not put it back together exactly as you took it apart.
Posted on Jul 07, 2009
backwoodsctr
  • 169 Answers
SOURCE: I have a Craftsman Tractor 42
perform a cylinder leak down test, any readings over 30 percent loss means the engine may have internal problems, Many things it could be. Blown head gasket that is blown between the cylinder and oil gallery. Overfilled with oil or gas in the oil from a faulty carburetor. Leaking valve stem seals. Worn piston rings. Hope this steers you in the right direction. Good luck
Posted on Nov 23, 2009
SOURCE: The tractor stalls
My experience has been lead peroxide build up between battery terminal and battery cable end. You could wait an hour or so and it usually disolves (only to keep on returning) or you can clean both the battery terminal and cable clamp and reinstall using electrical anti-corrode grease (even use electrical paste used when connecting copper to aluminum wiring) The root of the problem is different alloy of lead used for battery post and cable clamp or the tinning on the cable clamp. This incompatibilty causes thge formation of the temporarty oxide interface.
Good luck
Posted on Jun 30, 2010
  • 110 Answers
SOURCE: Tractor starts blowing white smoke , then runs a
Check the oil level. Sounds like it is to full.
Posted on Nov 01, 2010
Tractor moves 5 feet then stops belt starts to smoke
There is something in a wad! You cranked it up to warm up. You drove it to the crime scene. You first engaged the blade which was OK?
Then released clutch to drive which, smokes the belt.
Most interesting and perhaps you tried to cut some super thick grass at high driving speed with a low/dull blade and the belt just can't tolerate that combination.
Sep 10, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
I have a Craftsman 42 Lawn tractor that is exhausting white smoke
i have seen head gaskets blow out then the oil gets sucked into the cylinder on the intake stroke
Jun 02, 2012 | Garden
I have a Simplicity model 1692762 with a 16hp Briggs and Stratton. The mower blew large plume of white smoke three times while cutting grass over a period of 10 minutes. Engine seemed to lose some power...
I suspect an internal engine issue such as a valve, the white smoke was oil and it could mean a bent, burned valve or damaged valve seat causing the valve stem seal to leak allowing the engine to **** some oil and burn it (the white smoke) and now you lack compression. It is less likely but possible the oil was overfilled and you "lipped" the piston which causes the compression to drop. check the compression, 100-120 is normal, less than that means bad internal parts.
May 27, 2010 | Garden
Engine only runs at low idle and smokes
So now, without the blades engaged, it smokes and then dies?
In your first description it sounded like the engine was under a strain. Overfilling with oil could produce a strain, but since it ran ok until you said you engaged the blades, I would have to ask if the blades themselves, were causing the strain. Sometimes if you cut wet grass, the clippings stick to your underside of the deck and can really build up. Also some rope, wire or twine would around the spindles could creat one. Check this out...
Now, with the "smoke" issue (I'm assuming a blue smoke from burning oil) I'm inclined to think your rings aren't compressing any longer and you're burning oil. You might be in for a rebuild... I hope not.
Aug 31, 2009 | Husqvarna 19.5hp 46" Yard Tractor
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Oil causing a problem?
Sound as if you have too much oil in the machine. Anytime you see white or lite gray smoke it is a sign of too much oil. Before you go through the routine of cleaning the oil out of every nook and cranny, try unscrewing the spark plug and clean it with a soft rag. It would have oil on it preventing the machine from starting. If this does work and there isn't a lot of oil in the gas tank now, just continue running the engine until the smoke clears. It won't hurt anything. But if cleaning the plug doesn't help you will have to empty all gas and oil from the gas tank, refill with new gas, squirt a little gum out carb cleaner in your carb to remove any oil there (this can be done when you try to restart the engine). Remember, when you are mowing grass if you are mowing on a hill) of any knd, make sure to turn the mower so the gas tank is on a higher level than the oil.
Jun 18, 2009 | Toro Lawn Mower With Toro Power Tools
Engine bogs big puffs of white smoke from front
the engine will bog because the cutting blades are either cutting to much grass or the blades are touching the ground making it hard to keep rpm's then it will smoke a bit
Jun 05, 2009 | Garden
Tractor?troy bilt/mtd 2002
the electric clutch that operates the blades needs replaced
Sep 22, 2008 | Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
80 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
