Question about Home Security
Tenpro door opener wiring schematic
I have a tenpro garage door opener, the dip switches on the opener no longer match the manufactures setting. The dip switches were reset on both the opener and the universal remote. The door will not open. Any suggestions. Would unplugging and plugging back in the opener work?
myob247
  • 1342 Answers
SOURCE: garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Posted on Jun 19, 2008
  • 244 Answers
SOURCE: keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Posted on Jan 28, 2009
SOURCE: My Chamberlin remote garage door opener stopped working.
Try this website for a possible solution
http://www.bearcatco.com/helpgifs/liftmaster_troubleshooting.html
Posted on Feb 16, 2009
  • 3197 Answers
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Posted on Dec 08, 2009
  • 3197 Answers
SOURCE: Trying to clear the codes from my Garage Door
In most cases, when a garage door opens or closes by itself, or when you find your door open, upon returning home, the problem is due to a short somewhere. This short is most likely to be in one of two places: either in one of your transmitters or in the wall button or its wiring.
When there is a short in your garage door transmitter, you will often find the garage door is up upon returning home, even though you know you closed the door when you left the house. A short in your transmitter causes a continues signal to be sent. As you are pulling out of the driveway the garage door closes fully and appears to stop, but as the carriage and arm run past the down limit and hits the header bracket it reverses, and the door begins to open, just as you start driving off down the road. You come home to find the garage door is up, as if someone else had opened your door. The best thing to do to troubleshoot the garage door problem is remove the batteries from your transmitters and try operating the door from the wall button. If the problem is intermittent, you may want to do this for a day or two to eliminate the transmitters as the culprit.
If the problem persists, try removing the wall button wire at the motor head to ensure it is not a short in the wire to the button, then try operating the garage door with the transmitters only. If it stops the problem, replace the wires and test the wall button. It is a process of elimination.
Posted on Mar 29, 2010
Tenpro garage door opener
There are 12 DIP switches inside the motor compartment, which correspond to the switches in the remote. For access to the switches remove the panel at the left side of the motor (1 screw) and you will see the circuit board with the switches
May 30, 2014 | Building Materials
How can I reprogram an old style 61LM to a garage door with a learn button? Thanks!
This Liftmaster 61LM remote is the equivalent remote t? the Sears Craftsman 139 model number listed above. It h?? dip switches inside the battery compartment that ??? match up w?th ???r existing remote t? m?k? ?t open ???r garage door. There is also a set ?f dip switches ?n the overhead opener itself ?f ??? n? longer h??? a working remote. It ?h???? b? easy t? find ?n the garage door opener. This remote operates ?n a 390 MHZ Frequency, and works ?n models fr?m 1984-1992 essentially.
There will be a colored learn button on the motor head. Press and release this button and then press the button on the remote. That is it. Thanks BB Sorry about the lousy question marks in the last post
May 13, 2010 | liftmaster Chamberlain Garage Door Opener...
Th?? Liftmaster 61LM remote ?? th? equivalent remote tο th? Sears Craftsman 139 model number listed above. It h?? dip switches inside th? battery compartment th?t ?ου match up w?th ?ουr existing remote tο m?k? ?t open ?ουr garage door. Th?r? ?? ???ο a set οf dip switches οn th? overhead opener itself ?f ?ου nο longer h?ν? a working remote. It ?hου?? b? easy tο find οn th? garage door opener. Th?? remote operates οn a 390 MHZ Frequency, ?n? works οn models frοm 1984-1992 essentially.
Mar 21, 2010 | liftmaster Chamberlain Garage Door Opener...
I have a Chamberlain garage door opener - Electrolift Executive with command control model #5446. I need to program the remotes but do not have a manual. The remotes have dip switches inside that I can set...
THERE SHOULD BE A SQUARE BUTTON NEAR THE ANTENNA WIRE THAT IS THE LEARN BUTTON. IF THERE IS NO SQUARE BUTTON THEN THER SHOULD BE A ROW OF SWITCHES ALSO NEAR TH ANTENNA WIRE
HOPE THIS HELPS
Mar 07, 2010 | liftmaster Chamberlain Garage Door Opener...
My neighbors remote opens my garage door too!
Open your remote and there are dip switches that you set to be either on or off. Set them to any sequence you want, but you need to set the dip switches on your main unit to match the ones on your remote. For example: 1 off, 2 on, 3 on etc. Set the main unit to 1 off, 2 on, 3on and so forth.
Jun 28, 2009 | liftmaster Chamberlain Garage Door Opener...
How to set dip switches on remote for Chamberlain Liftmaster 1000
I would go with a chamberlain clicker on this issue. These remote are phased out and the 9 dips don't work well with them. Thanks BB
Mar 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not open or close with remotes
Put new batteries in the remotes.
Check the DIP switches in the opener
Check the dip switches in the remotes. They must match the opener.
Feb 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to match DIP switchs on a universal garage door remote
I find Clicker products confusing. Might want to buy whole new replacement readio control set. how old is operator?
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Remote
open the remote there are dip switches in side and also the same looking dip switches are in the door opener check to see if they match
Sep 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door beeper
Call Sears and get user manual. It tells you how in the manual. Older models have dip switches and you set the unit to match the motor by turning the corresponding switches on or off. Hope this helps
Aug 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
70 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
