Question about LG Dryers
DLG 3788W Dryer
Loud rubbing noise then shuts off after 1 minute
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Could be the drum wheels
Posted on Dec 19, 2013
SOURCE: LG DLG 3788W not heating
can you look in one of the holes in the back and see if the inside glows orange after you turn it on? If it doesn't could be the igniter, if it does glow orange, clicks or clacks, and glows again 20-30 seconds later, click/clack and nothing, it's probably the gas valve. I'm going through the same thing with a new one and they had to order the valve and a new controller board in case it is bad too. If you are handy, have an electronic tester, and have the patience, go to http://136.166.4.200/contents/Laundry/DLG3788.htm for the service manual and disassembly instructions and see if you want to tackle the test flow for no heat. I just stumbled on the site.
Posted on Dec 05, 2007
SOURCE: Noise
how to replace a fan impellar on a zanussi
Posted on Nov 22, 2008
  • 11 Answers
SOURCE: New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Posted on Aug 19, 2009
heatman101
  • 43501 Answers
SOURCE: Loud Rubbing noise from my Maytag Performa Dryer
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Jul 20, 2010
heatman101
  • 43501 Answers
SOURCE: My dryer doesn't seem to function properly, it's
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 26, 2010
Thumping noise
Sounds like the tub is unbalanced from either a bearing/pulley suspension problem or the unit has broken something off in between the tub and outer portion of the unit before you get to the walled panels, and you are hearing a rubbing and thumping noise. This is not a typical DIY job since the entire back panel of the unit needs to be pulled off and diagnosed.
Sep 18, 2012 | Frigidaire FEQ1442ES Electric Dryer
Maytag dryer model MDET236AYW drum rubs against blower = loud squealing. drum slides forward and back about 1/4 to 1/2 inch. when slid back, it rubs against blower. when slid forward, does not rub. how can...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 21, 2011 | Maytag Dryers
The dryer will make a loud scretching noise like metal rubbing on metal and then after about 10 minutes the dryer will shut off and when you try to restart pushing the timer/start button, it just make a...
heatman101
Jan 31, 2011 | Dryers
Loud Bank noise when Creda Vent dryer is in motion.
Unplug or disconnect power before disassembling the dryer.
Most likely the noise is coming from 1 of the 2 drum support rollers or the shaft. It also could be the blower wheel loose or rubbing the blower housing. There is also a belt and belt idler assembly that could be making the noise.
Jan 17, 2011 | Hotpoint Dryers
My dryer doesn't seem to function properly, it's just blowing cold air. I had it on for over one hour, my clothes are still wet and the air is still cold. The dryer model is LG Tromm DLG 3788W. The...
heatman101
Dec 24, 2010 | LG Dryers
heatman101
Jul 20, 2010 | Maytag Dryers
Dryer shuts off quickly
The problem could be with the thermostats...or maybe the motor.
It would be wise to check those out first.
The thermostats are normally located in the air tube from the blower to the drum, this is where the heating coil in normally located also.
Hope this helps
Oct 01, 2009 | Whirlpool Dryers
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Dlg 3788w-7.3 cu ft gas dryer
You don't, it is gas dryer, so I advise you to get a authorized gas technician to look at your unit.
Chances are the blower assembly is out of whack, maybe the motor is off its brackets.
Sgt 48
May 23, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Dec 03, 2007 | LG DLG5932W Gas Dryer
Dryers Logo
62 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
