Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Mower replacement spindle
How long should it to switch out the spindle
    Sergeant:
  • 416 Answers
Maybe an hour
plan on old bolts breaking off
Posted on Oct 17, 2013
How to replace spindle bearings on woods l59 woods mower
well last time I looked their spindle assy's weren't rebuildable. since I cant remember I will say this, you have to remove the center bolt to explore further...
Sep 02, 2014 | Garden
Main spindle needs replacement how to
Typical Kubota mower spindles are mounted with 4 bolts. Some have 4 more on a larger support plate. First the belt pulley must be removed, possibly with the help of a jaw-type puller. Then remove the 4 bolts around the perimeter of the spindle. Using a soft mallet or wood block, drive the spindle assembly down through the deck, making sure there is room underneath for it to fall. Kubota sells replacements as complete assemblies which saves a lot of time vs. rebuilding the spindle.
Oct 05, 2013 | Kubota Garden
My mower will die everytime i engage the blades to mow
Check to see if one of your deck spindles isn't seized. Disengage the blades and turn each blade to see if its free. Sounds like either a spindle is seized or your electric clutch on the motor has a problem.
Jul 20, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
Craftman 42 inch riding mower deck shakes and make noise
sounds like he bent a blade that's when the belt went
Apr 10, 2012 | Garden
How to replace the spindle on a 48 inch mower deck
OK, Now I see your question under a different post. You are going to have to pull the deck out from under the spindle housing and spindle and replace them. They usually come as an assembly. after removing teh deck you should see the spindle housing retaining bolts to remove. Make sure you pull the blade off that spindle before you try removing it.
Oct 02, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
One blade is "froze" and can hardly be moved with mush effort.
Well that spindle is probably damaged from striking object, the shaft may be bent or the housing is damaged. Replace spindle again.
Aug 13, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Aug 08, 2009 | Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
