Question about Mtd 22" Yard Machine Push Mower
Replace Cord how to replace pull chord
    Problem Solver:
  • 4 Answers
Take the cover off the top of the motor witch I think it is like 5 or 6 10 mm bolts take them out and u should have pull starter in that. So wind the the spring till its pretty tight and the cord u should have already put the handle on feed the other end of the rope thru the wound tight spring and put it thru the hole on the plastic piece in the center that u wound up and tie a double knot and then slowly let it wind it back in. if it stops before all the string goes in there is either to much string or u didnt wind it enough before u put the string in it. It should take like three foot of rope if the handle is at the motor but if the handgrip is up the handle u will need like 9 feet of rope
Posted on May 07, 2013
  • Mike Carew Jun 12, 2014
    7 ft is enough to reaxh the loop bolt on the handle.
    Habit-Forming:
  • 78 Answers
See attached video provided below...its an easy job when you do.
https://www.youtube.com/watch?v=d4r8wbejHXY
Posted on Mar 02, 2015
I lost the power chord to the remote on my George sound system by Chestnut Hill
unfortunately it seems the George is no longer available. However, the power cord is a USB cord then you should be able to replace it by picking up a multiple USB cord kit (the one that has both the standard and mini sized cords).
May 23, 2014 | Apple Chestnut Hill Sound GEORGE Compact...
Replace pull chord
Depends on your make and model.
Some are really easy, some impossible.
The easy ones go like this.
You remove the top of the motor, which is held on with a few screws. You will then have a bowl shaped piece, usually metal, which you will turn upside down, and see the cord-winder reel inside the top of it.
You will remove the cord winding reel, and wind a new cord onto it. However, the cord winding reel is spring loaded, and it takes knowledge and experience to do that.
The harder ones, I cannot begin to describe.
Be blessed.
May 04, 2013 | Mtd 22" Yard Machine Push Mower
The chord that you pull to turn the light on on the "Square Floor Lamp With Paper Shade And Shelves - Black" I accidently pulled out from pulling it too hard or the wrong way. How can I fix it?
Before anything ***UNPLUG UNIT FROM WALL***
Some lighting fixtures you can take apart, others you cannot. Turn the item upside down so you can see the lighting fixture. If you see that it has a few screws you can take it apart and replace the cord.
If not, take out the lighting fixture (one or two screws at the maximum) and go to Hobby Lobby or Michael's...something like these. They will have a similar product you can replace it with. It might not be te same, but if it is close then you should be able to affix it in your unit.
Jan 11, 2013 | Adesso Square Floor Lamp with Paper Shade...
The chord you pull to start the engine as snappedand the remaining chord does not retract
you need to remove the recoil cover to replace the cord make sure the hub movers freely
Mar 26, 2012 | Garden
Broken pullcord . cord is missing how long should new cord be and how hard is it to replace
Just went through this pain today. Here's how I did it. Use allen wrench with T handle to remove the shroud over the carb controls and plug. Then remove about 10 screws and split the case. Use tool that comes with the unit to remove the nut holding the impeller. Behind the impeller, use torx head to get the other bolts to remove the motor. There are two other screws on the other side that hold the motor on. Drop the motor from the case carefully. It is still attached by wires to the throttle and kill switch. Note how the throttle linkage is connected because it will come apart for sure. On the one side of the housing you are looking at the plastic cord spool with the spring unit behind it. My chord simply pulled out of the spool. It was held on with a 10mm nut and start washer (not a good design). If the chord broke, remove the remnant from the take up spool. To rewind the new chord or replace the one that pulled free, you need to wind the spring to put tension on it. Make sure the take up spool engages with the spring tang otherwise it will turn free and not tense the sprint. Once engaged with the tang, the spool should set to the bottom to be level with the metal chord guide. Turn the spool clockwise 3-4 turns until you feel it tighten. With a 2nd pair of hands, hold the tension on the spool and tread in your chord. Route the chord through the take up reel into the hole on the side. Loosen the 10mm nut with the star washer and route the end of the chord through it. Tie a simple knot in the end to prevent it from pulling through. Tighten the 10mm nut which clamps on the chord. Now, slowly, let the spring tension take up the loose chord until fully retracted. Make sure the metal chord guide fits in the slot to channel the chord properly into the take up reel. Hold the spool down and give the chord a gentle test or two. The chord should retract easily and fully. Simple as pie!!! Reverse the disassembly and you are back in business.
Apr 01, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
When i put the power cord on my acer aspire 9500 the light of the power cord turns off and it makes a sound like a bomb...please help
there is a problem in ur power chord please check it with other chord or else replace with a new chord if the other chord is workin or change the battery .................
Sep 16, 2010 | Acer Aspire 9500 Notebook
I broke the pull cord on my generator; how do I
you should remove the housing usually 4 bolts
dont remove anything else then look at the pully and remove the old chord tie a knot in the new chord and slot it into the hole on the pulley
you should then see a notch in the edge of the pulley this is for the chord to sit in while you turn the pully enough times to tension the recoil spring once tensioned enough so that it recoils all the chord slot the chord through the hole in the outer casing through the pull hande and knot it job done then refit
May 09, 2010 | Electrical Supplies
My pull chord snapped in half where do
Go to smalleng.com they have video on how to do what you need. Check it out awesome website! The cord you can buy at any local home center. or repair shop.
Apr 17, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Mtd 22" Yard Machine Push Mower Logo
223 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
