Question about Microsoft Forefront TMG Standard - Processor License & SA
How to configure forefront gateway 2010
Configure
  • 26 Answers
I'd recommend checking out the Forefront Edge Support Center , there is an in-depth user guide for download to get you started on using Forefront Gateway 2010
http://support.microsoft.com/ph/815
Posted on May 06, 2013
I need the address ip for configure?
Open command prompt. Type netstat -rn.
The IP address under "Gateway" for either the "default" line or the address 0.0.0.0 would be the gateway IP address of the router and likely the address used to configure it.
For example:
Internet:
Destination Gateway
default 192.168.2.1
Jun 08, 2014 | Cisco DDR2201 Residential Gateway -...
Winzip fails
Just right click on the WINZIP.exe , then compatibility tab, click on litlle square of "Run this program in ...", choose one from the menu, then click a little square down "run as administrator", apply , OK, and hopefully that's it !
Apr 21, 2014 | Microsoft Forefront TMG Standard -...
Cannot connect to 192.168.0.1
How you connect to the router configuration page is depended upon how you have your router management configured. I believe by default belkin routers allow for remote configuration so if you didn't configure any security on your router someone may have altered your configuration.
The default method for configuring your router requires.
  • An ethernet cable plugged from your computer to a LAN port on the router
  • The correct Gateway address (Start > Run > Type "CMD" at the command prompt type "ipconfig" look at your gateway address
  • In a web browser type in http://192.168.0.1 in this example
If you still can't access it I'd suggest pressing the reset button on the back of the router and re-configure the router in case of tampering.
Comment if you need any further assistance
Oct 27, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
BUFFALO WCR-G54 I LOST MY CD ROUTER, NOW I CAN'T CONFIGURE MY NETWORK ROUTER, PLEASE GIVE ME THE EXACT CD ROUTER OR MY BUFFALO WCR-G54 I REALY APPREACIATED THANKS.. & GODBLESS
You do not need a CD to configure the router. Simply, hook up the router to your modem, and make sure a computer you will use to configure it is plugged into the router.
Once everything is turned on, you can simple go to the router homepage by typing in your gateway ip address in your internet browser(like going to a website).
Usually, the gateway IP address is 192.168.1.1
Once you type this in the internet browser, it should take you to the configuration page.
I appreciate a thumbs up if this helps!
May 04, 2011 | Computers & Internet
Please tell me how to configure ip address in printer 4350
Press Check mark (SELECT button) to open the menus.
2. Use (UP button) or (DOWN button) to scroll to CONFIGURE DEVICE menu, and then press
(SELECT button).
3. Use (UP button) or (DOWN button) to scroll to I/O submenu, and then press
(SELECT button).
4. Use (UP button) or (DOWN button) to scroll to EMBEDDED JETDIRECT MENU
5. Use (UP button) or (DOWN button) to scroll to TCP/IP
Then: Select whether the TCP/IP protocol
stack is enabled or disabled. You can set several
TCP/IP parameters.
Select the TCP/IP CONFIGURE METHOD to
configure the EIO card. For the MANUAL option,
set the values for IP ADDRESS , SUBNET
MASK , LOCAL GATEWAY, and DEFAULT
GATEWAY
Nov 14, 2010 | HP LaserJet 4350 Printer
I cant get acces to my Modem or Wifi using "192.168.0.1? Help
May be 192.168.0.1 is not the address to configure that router.
Start, Run, CMD to open a command prompt:
Type the following command:
IPCONFIG /ALL
Right click in the command window and choose Select All, then hit Enter.
example results.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Adamprince>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Adamprinces
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : VIA Rhine III Fast Ethernet Adapter
Physical Address. . . . . . . . . : 00-0A-48-08-24-52
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.6
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DNS Servers . . . . . . . . . . . : 202.27.184.3
Lease Obtained. . . . . . . . . . : Tuesday, 24 August 2010 5:35:33 p.m.
Lease Expires . . . . . . . . . . : Wednesday, 25 August 2010 5:35:33 p.m.
____________________________________________________
The address to configure that router is 192.168.1.254
Aug 26, 2010 | Computers & Internet
IP Addressing by dhcp for vlans
tell each vlan about DHCP server using
ip helper <DHCP servers ip adddress>.
in config mode.
Mar 03, 2009 | Cisco Catalyst 2950 24x10/100 Mbps...
3com officeconnect wireless 11g cable/dsl router
router default ip gateway will be the 192.168.1.1,so you can able to give the same ip address,so you configure only other ip address & try it.
May 25, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Microsoft Forefront TMG Standard - Processor License & SA Logo
50 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
