Question about Toshiba 24SLV411U LCD TVDVD Combo
Power board will not power on
    President:
  • Toshiba Master
  • 749 Answers
Just for the record this may not necessarily be because of the power board.
We do not have experience with the power board from your particular TV as of the date of this posting, but if you can't find it elsewhere feel free to send it in for evaluation and possibly repair.
We do a lot of power boards and shouldn't have much trouble with it.
www.coppelltvrepair.com
Posted on May 30, 2013
I HAVE REPLACED THE POWER BOARD. STILL WONT COME ON. CHECKED THE CIRCUITS. YES POWER IS TO THE BOARD. COULD IT BE THE SIGNAL BOARD?
Hi Pam,
For a TV to come on, the power board has to send 'stand by or SB5V or 3.5V ' to the main board. On your pressing power on button on remote control, the main board sends power on command to the power board which in turn produces all the necessary supplies to run the TV. If the main board does not respond to your TV on command, the TV will not work. So It is not the power board which is responsible for not powering on of a TV every time. A voltage investigation before changing boards is always helpful. I hope it helps.
Aug 14, 2015 | Televison & Video
What makes the HISENSE LCD (Model LCD 42W58P1) power supply failed to produce output voltage goes to the main pc board?
First of all the power supply makes 'Stand By 5 or 3.5V which goes to main board. When we give power on command to the TV the main board sends 'stand by or Power ON' command to the power board which then makes other necessary voltage for the main board as well as other sections. If the power board does not receive 'Power On' command from main board, it will not produce the necessary voltages to operate the TV set.
May 20, 2015 | Hisense Televison & Video
My Vizio VW42L will not power on. No backlights, no power from pson pin. has 5v stand by power on power to main board. no 12 or 24 volt power. has a new power board and inverter boards.
The main board is defective the power on command originates from the main board and thats what gives the signal to start powering up the set. Replacing the main board should solve the issue. You can get the main board from www.tvcircuitboards.com
Jan 02, 2013 | Vizio L32 32 in. LCD HDTV
I have a panasonic TC-P42C1 blinks 10 times no picture no sound What is common to go on this model (which board)?
Check the tv power supply board.That the board where the tv power A/c plug into it.Check the tv power supply board carefully for dying components parts that are called capacitors parts.Bad or dying capacitors parts on the tv power supply board are alway causes this problems to the tv.Bad or dying capacitors parts are very easily to spots,all these capacitors parts are alway bulges up onto it tops.Never have plats round tops as they suppose too.U have all the tools and know basic electronic also can do basic soldering work,u should changes all these dying capacitors parts in the tv power supply board with no problems at all.If u check all over the tv power supply board and it have no dying and leaking capacitors parts to the tv power supply board all.Then the tv Y-Sustain main logic Tuner board it is the causes and the problems.The tv Y-Sustain main logic Tuner signal board that is the board that take in the tv imcomming tv broadcasting signal cable plug into it.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board and or the tv Y-Sustain main logic Tuner signal board for the replacement.
Nov 06, 2011 | Panasonic TCP42C1 Plasma TV
Will not power up. Tested from plug to power board. Power does not leave power board from any terminals.
The power supply board could very well be defective. I would also check the Zsus board and the Xsus boards. If either of these boards fail it could also cause the power supply board to fail.
You can unplug the connectors to the zsus board at the power supply and try to turn the set on. If it does turn on, the power supply board is ok. If not, the power supply is bad. If the power supply board is ok, undo the plug connectors that power the Xsus board and hook up the plug connectors to the Zsus board. Turn the set an and see if it stays on or shuts down. Part numbers should be on the boards. Zenith is really LG Corp. Their customer support number is 1800-243-0000.
Hope this helps,
Steve
Nov 25, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
Power light is flashing green. i hold the power button it turns red. i press it again it turns yellowish then solid gree the screen comes on the 3 second later screen goes blank and flashing green power
Sharp tv are famous for this problems.Take ur tv aparts,where the a/c power cord go into it.That ur tv power supply board,check for all those dead leakage capacitors parts that bulges up on it top or puff up on it top.Than it ur power supply board,replaced those dead leakages capicitors or replaced the whole power supply board.No leakage capcitors on the power supply board.Than it 100% the Tuner board it dead,this board is where the coalax broacast tv signal cable go into it.This board can't not be repair only replaced,because it alway some ICS it the problems it dead on this Tuner board.Tries websties like Shopjimmy.com,Ebay.com to buy either or both refurbishes the power supply board or the Tuner board.
May 26, 2010 | Sharp LC32D47UT 32 in TV
Hi i changed colour cartridge tried trial run printer died; changed fuse in plug; still no power any suggestions please
in the printer there is a power supply board.there is a same type of 3amp fuse on the power supply board.if there is any kind of overheating in the power then the fuse in the plug and fuse on the power supply board blows out.in some cases only fuse on power supply board blows out.this fuse is placed on the board for safety reasons.because in the older model printers when this short circuit problem was happening at that time whole board used to blow out.so in the new model of printer a fuse is placed on the board ,so if any overheating or any power outage or any short circuit occurs.the fuse blows out instead of whole power supply board. You just need to replace the fuse on the power supply board by disassembling the printer.the power supply board is the green color square shaped board.its the board to which your power wire of printer is connected. the fuse is available at any local electric hardware shop.its not any special kind of fuse. This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | Lexmark X5150 All-In-One InkJet Printer
Hitachi
Without the correct meters and equipment it can get exspensive replacing boards however it almost has to be located on the power filter or the power board. I would suggest the power board over the power filter.
May 16, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Toshiba 24SLV411U LCD TVDVD Combo Logo
57 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
