Question about Refrigerators
Kenmore refrigerator model 795-7395-2300
Water collects on bottom under drawers....is there a drain? i have to mop up every other day?
aborcass
  • 2651 Answers
SOURCE: Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
aborcass
  • 2651 Answers
SOURCE: Refrigerator/ water collecting under veggie bins
sounds like you do have a clogged drain tube, its self defrosting but the defrost water is pooling under hte crispers instead of in the drain pan under unit.so you ll either have to remove hte rear panel of freezer and locate the drain trough/ tube, and defrost it allowing for water to drain down, o rclear all the tube leading down to the drain pan.
Posted on Mar 21, 2008
Sea Breeze
  • 4655 Answers
SOURCE: water collects in bottom of refrigerator
This is something you will be able to solve, the like below will take you to a detailed instructions and photos of what to do. Let me know if you need more help, Thanks Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
Posted on May 23, 2009
  • 3600 Answers
SOURCE: Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Posted on Aug 28, 2009
Testimonial: "found a drain hose but can't see where either end is located"
tbirdfan1
  • 3051 Answers
SOURCE: bottom of fridge collects water
Hello there:
I have written a few steps for you to follow and try ok?
  1. Manufacturers have different ways to dispose of the water created during automatic defrost cycles. The most common design routes the water down a rubber tube on the back of the fridge to a tray beneath. This tube often gets plugged with breadcrumbs, peas etc. and can generally easily be removed and cleaned.
  2. Make sure the end of the hose is sitting in the defrost tray.
  3. If your hose was not plugged and you have found water running down the back wall inside the fridge or a pool under the bottom crisper has formed. Check if there is a small funnel located on the back wall near the top inside the fridge. It can also get plugged; you can use a small wire and work it in and out of the hole.
  4. Some designs do run the water down the back wall and have a drain hole under the crisper, make sure it is not plugged.
I hope that this has been verry helpfull for you
best regards michael
Posted on Nov 06, 2009
Water accumulating inside fridge bottom make GE Model #gta18pbnaww
That's normal especially if you tend to leave the door open alot. Moisture from the outside air condenses and drips to the bottom. Also, if the refrigerator is automatic self-defrosting it will melt ice collecting around the refrigerator and the resulting water will collect at the bottom. Check under the food drawers for a drain hole. If it is clogged, clean it out. If it doesn't exist, periodically sponge out the bottom under the drawers.
Jan 12, 2013 | Refrigerators
Kenmore side by side model 106.53582300 water collects under bottom drawer freezer .thaws out runs out bottom door onto the floor seems like it does it when in defrost mode
Hello, Thank You for using FixYa. I will be helping you today.You have a frozen drain line behind the back panel in the bottom of the freezer.Remove the panel and use a hair dryer to defrost the drain.Or pour boiling water until you hear it draining into the pan
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Refrigerators
Frigidaire Gallery, model GLRT183TDW0 Water is leaking underneath, and water is collecting in the bottom under the crisper drawers
Is there a drain hole under the crsper drawers if so see if it is pluged. And leting water to drain to the drain pan under the frig. I hope this will help. Jim
Oct 27, 2010 | Frigidaire Refrigerators
My refrigerator is collecting water under the vegetable drawers
The defrost water is supposed to go into a drain hole below the evaporation coils. The hole is clogged and the water goes down the back side of the refrigerator to the bottom. Seen it. You gotta clean out that drain hole. Shop vac works great.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 12, 2010 | Kenmore Refrigerators
Model 363.9668513 water collects under the fruit
this is because the plastic is shiny and attracts condensation,only "cure "is a piece of kitchen towel under drawer to mop up as/when.(when you open door all the cold air drops to the floor and is replaced with warm moist air from the kitchen.hence condensation.
Apr 13, 2010 | Refrigerators
Water collects under the veg tray on bottom of fridge
Good day,
That's a classic example of the drain system either plugged up or iced up.
Remove the rear panel in the freezer, and inspect the drain hole where the condensed water drains out of the machine. Must be blown out or de-iced. Service techs use compressed air tank with hose to blow out the dirt. You'll need to improvise. However...
There are a few models that let the condensed water run down the back wall of the fridge, under the crisper drawers and then out a drain plug.
Check for this first.
Nov 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Aug 28, 2009 | Refrigerators
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
GE Refrigerator, Model TBX22ZA
the drain hole is blocked in the bottom of the fridge. if the water is not able to drain down the hole it will overflow into the fridge base. check any holes at the inside back of the fridge.
Jun 11, 2007 | Kenmore 26.0 cu. ft. Side-By-Side...
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
