Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I am trying to change the blades on my Craftsman 42 in mowing deck, but cannot loosen the bolt. Is it a right hand thread?
    Sergeant:
  • 416 Answers
They are real tight
reg thread
righty tighty lefty loosy
get a cheater bar some good leverage or an impact wrench
Posted on Oct 17, 2013
  • 37 Answers
SOURCE: Which way do the mower blades mount, on a Craftsman DT4000, 19HP Mower 42" deck?
Hi, make sure to put your blade curve end up. another word facing the motor
Posted on Nov 23, 2008
  • 49 Answers
SOURCE: craftsman snow blade install instructions
Go to sears.com and click on the PartsDirect link at the top. Enter the model number of the blade and you will see a parts diagram of blade. Hope this helps.
Posted on Feb 06, 2009
wadembly
  • 475 Answers
SOURCE: 42 inch Craftsman blades won't engage
is the belt spinning & smoking when blades are engaged or the belt won't spin if the belt spins but blades wont go then there is something stuck under the deck or the bearings are gone out do to not being greased
Posted on Jun 14, 2009
wadembly
  • 475 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
wadembly
  • 475 Answers
SOURCE: 42" deck - uneven mowing in the center
yes its repairable & yes it can bend the spendle but most likely the blades is it one that does it or both blades or the center or the sides of deck is bent by stepping on the deck let me know if i can further help thanks wade
Posted on Jul 04, 2009
How do I change blades on a toro 42 in zero turn
Lift front of machine and secure,
Use a pipe wrench over top of blade and against deck, to keep blade from turning,
Use 1/2 " breaker bar to loosen bottom bolt,
Remove blade,
If the bottom bolt doesn't loosen, you may need a wrench at top of deck, above the bottom bolt, to loosen the bottom bolt.
Replace, or sharpen blades, install in reverse order.
GOOD LUCK FRIEND.
Sep 16, 2014 | Toro 42 In 22 Hp Kawasaki Vtwin...
How do you replace the blades on a 42 in. deck? do they need to be placed in a special way?
use the blades for leverage when loosening the bolts. when putting new blades on, hold the blade in the star center hub install washer and bolt. use blade for leverage when tightening.
Jun 23, 2014 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Bolt that holds blade well not loosen what is the correct direction to loosen bolt
Remember that on a circular saw, the bolts are typically left-handed thread so it is the opposite of a typical bolt. This is because the blade spins to the right so if a normal bolt was used it would loosen as the saw operates.
Jul 19, 2011 | Sears Craftsman 7-1/4 in. Circular Saw...
19.5hp 42" cut. Shakes when mower is engaged to cut
how hard does it shake? and does it mow?
most lawn tractor will shake a quick almost violent shake at first then it should vibrate quite a bit more while you are mowing this is just caused by the power being pulled from the motor to power not only the drive but the mowing deck. its normal.
if its worse than what i described you may have a bigger problem, if there is excessive clanking from the deck your blade may be loose/installed upside down.
Aug 05, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman Zeroturn deck mows unevenly??
u should get on flat surface an loosen guides bolts let it drop all the way down then tighten ur guide bolds an that should solve problem u can make sure none of ur pins are wore but they can usually ware almost all the way through and still not make it cut bad now before u adjust the deck check blade they have been known to cut bad if wore or bent
Mar 27, 2017 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Replacing blades
It is standard threads and should turn left.
May 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Changing blades.To loosen the blades nut, which way does it turn?
hi. you dont say what make or model but I offer the following. if it's just a single bolt or nut holding the blade it will rely on a bellville type washer (dished ) or will be pegged either side of the nut or bolt, if the later try to drive the pegs down level with the mounting boss, now get a couple of friends to lift the whole deck so you can secure the nut or bolt in a vice (vise) and using both hands turn the blade itself the opposite way that you would turn the nut, this has never failed for me, if the blades counter rotate, one will be left hand thread the other right hand. bear in mind that a rotary blade spins at around 150-200 mph, every time you hit an obstruction (and you will) the blade will tighten particularly if secured with a belleville type washer. best of luck
Nov 28, 2009 | Garden
Changing out the blades...are the attachment bolts reverse thread or normal, i.e. clockwise to tighten?
Should be clockwise to tighten, use some "PB blaster or Deep Creep" penetrating oil on the bolts before trying to take them off. It will help.
Sep 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman mandrel replacement::?????HELP
You dont have to drop the deck. Remove the belt first then hold the blade in place so you can loosen the nut on top of the pulley. after you remove the pully then remove the blade. There are 3 bolts holding the mandrel in place remove the bolts. Then pull the mandrel out from underneath the mower deck. There is a shroud that will come loose with it or it may stick from accumilated grass regardless it needs to go back during reassembly. When putting it back together the 3 bolts are usually self tapping into the new aluminum mandrel. Its much easier to put these in and take them out before you install the new mandrel as the bolts cut the threads.
Hope this helps
Brent
Jun 23, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Mowing blades on 42 inch deck are not cutting evenly.
go to sears.com
find parts direct at the top click on it
a place will come up where you can enter you mod#
click on search aftermod # entered and everything part wise will come up for that tractor
on the left hand side
Jun 15, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
79 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
