Question about Behringer DDM4000 Digital Pro DJ Mixer with Sampler DDM-4000
Ddm4000 system why it bursted into high volume and then froze?
Ddm4000 flashing and crashing
It sounds like it got blasted with ESD, see if you can get it repaired under warrenty.
Feb 16, 2014 | Behringer DDM4000 Digital Pro DJ Mixer...
Volume decreases drasticly when playing fairly loud for 15-20 minutes
You're probably overdriving the amplifier, meaning the speakers are sucking up more power than the amplifier is capable of. When you turn it up loud it overheats and causes the system to go into a protect mode so it doesn't catch on fire (yes... it happens!). Make sure your system is capable of handling the power needs of your speakers. And don't burn your house down! I had a high-end Harmon-Kardon receiver burst into flames. It's a good thing I was standing next to it or my house would have been toast.
Dec 03, 2013 | Kenwood Kdc-x994 Car CD/ MP3 Player
Ddm4000 system reset
TURN OFF UNIT
ON CHANNEL A HOLD DOWN ALL 3 BUTTONS ( LOW,MID,HIGH AT SAME TIME )
FOLLOW INSTRUCTIONS
BEFORE YOU START THE RESET PROCEDURE
YOU ARE GONNA NEED A MIDI WIRE
CONNECT IT TO THE IN & OUT JACKS
ITS GONNA GO INTO SELF TESTING MODE YOU ARE GONNA SEE ALL THE LIGHTS.LIGHT UP IN ORDER. FOLLOW WHAT THE SCREEN SAYS.AFTER YOU HAVE FOLLOW THAT
REMEMBER DO NOT TURN OFF UNIT UNTILL YOU HAVE COMPLETED THE TASK.IT WILL TELL YOU WHEN IT IS COMPLETED
NEVER USE OR LET NO MIXER PIONEER,BEHRINGER,AMERICAN AUDIO,RANE,ALLEN & HEATH. ETC STAY IN FULL RED PEAKING WHEN PLAYING OUT. YOU CAN PEAK INTO RED BUT NOT STAY IN FULL RED.
WHAT I ALWAYS DO IS SET THE VOLUME FIRST THAT I WANT THEN MAKE YOUR ADJUSTMENTS FROM THERE.GET A GOOD PROGRAM THAT CAN MAKE ALL YOUR MP3 THE SAME VOLUME.( YOU CAN USE WINDOWS MEDIA PLAYER USE THE VARIABLE BITE RATE SETTING LEAVE THE EQ AT DEFAULT SETTING OR USE ITUNES WITH THE SAME SETTINGS AS WINDOWS MEDIA PLAYER. THERE IS ONE PROGRAM YOU CAN USE BUT YOU ARE GONNA PAY FOR ( PLATINUM NOTES ) THERE IS NO FREE DOWNLOAD PROGRAM TO THIS )DIGITAL RECORDINGS HAVE A HIGHER FREQENCY MAINLY ON BASS. ANALOG HAS A WARMER SOUND.ME PERSONALLY I PREFER ANALOG OVER DIGITAL
PLEASE BRING BACK VINYL$$$$$
May 04, 2013 | Behringer DDM4000 Digital Pro DJ Mixer...
Hi... when i increase volume my laptop internal speaker's sound burst, high pich echo sound comes. and every time a noise comes out of it even here is nothing played.. is this a technical problem or...
Try to use system restore, so that for you to be able to analyze the problem. Click on start then select all programs, then accessories , system tools, system restore. Please select the day or time you think your loptop was working properly just before you encountered the sound problem. wait till it reboots. select ok at windows option. try it if it still exists. Have a nice day.
Aug 22, 2011 | Acer Aspire 5742Z-4200 Notebook
Ddm4000 freeze up and got to turn it off and turn back on
Freeze up is usually overheating, check your heatsinks and if the compound has dried up.
Dec 15, 2010 | Behringer Ddm4000 5-channel Digital Midi...
Volume control of system output is not stable with sudden high volume output bursts. Any ideas?
Sounds like a faulty / worn fader. If it does it on all channels then look at the master fader 1st.
A good source of parts is available here :-
http://stores.ebay.co.uk/methleykev
Jul 01, 2010 | Pioneer DJM-600 Silver Professional DJ...
"protect" display when volume is high and volume cuts in and out.
you should have it repaired.the audio circuit is malfunctioning because of the sudden burst/surge of current.
May 15, 2009 | Onkyo TX-SR502 Receiver
Volume varies by itself on the Yamaha htr5840 Receiver
The pod that controls the volume knob is either very dirty or needs replaced! (If you remove knob you will see the shaft of the volume pod go into the pod itself) You may try cleaning with a can of high pressure air by spraying short bursts of air in and around the pod area! If that doesent work you will have to replace the volume pod!...Please rate my response! Thank You!
Jan 11, 2009 | Yamaha HTR-5840 Receiver
While playing the DVD of Dark Knight on my 5.1 surround system last night, my audio system would simply turn itself off.  It seemed to happen during moments of extreme sound, i.e. explosions, gun shots,...
this is a common problem with this unit the main thing is a low grade capcitor that the manufacturers used which is known to discharge all of its power at once which it recieves a high signal output and tells the unit to shut down the solution is very technical but basiclly you gave to install a higher amp capacitor.
Dec 19, 2008 | Sharp CD-DD4500 System
Behringer DDM4000 Digital Pro DJ Mixer with Sampler DDM-4000 Logo
41 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
