Question about Behringer DDM4000 Digital Pro DJ Mixer with Sampler DDM-4000
Ddm4000 system reset
Why it bursted into uncontrolled volume and then froze
    New Friend:
TURN OFF UNIT
ON CHANNEL A HOLD DOWN ALL 3 BUTTONS ( LOW,MID,HIGH AT SAME TIME )
FOLLOW INSTRUCTIONS
BEFORE YOU START THE RESET PROCEDURE
YOU ARE GONNA NEED A MIDI WIRE
CONNECT IT TO THE IN & OUT JACKS
ITS GONNA GO INTO SELF TESTING MODE YOU ARE GONNA SEE ALL THE LIGHTS.LIGHT UP IN ORDER. FOLLOW WHAT THE SCREEN SAYS.AFTER YOU HAVE FOLLOW THAT
REMEMBER DO NOT TURN OFF UNIT UNTILL YOU HAVE COMPLETED THE TASK.IT WILL TELL YOU WHEN IT IS COMPLETED
NEVER USE OR LET NO MIXER PIONEER,BEHRINGER,AMERICAN AUDIO,RANE,ALLEN & HEATH. ETC STAY IN FULL RED PEAKING WHEN PLAYING OUT. YOU CAN PEAK INTO RED BUT NOT STAY IN FULL RED.
WHAT I ALWAYS DO IS SET THE VOLUME FIRST THAT I WANT THEN MAKE YOUR ADJUSTMENTS FROM THERE.GET A GOOD PROGRAM THAT CAN MAKE ALL YOUR MP3 THE SAME VOLUME.( YOU CAN USE WINDOWS MEDIA PLAYER USE THE VARIABLE BITE RATE SETTING LEAVE THE EQ AT DEFAULT SETTING OR USE ITUNES WITH THE SAME SETTINGS AS WINDOWS MEDIA PLAYER. THERE IS ONE PROGRAM YOU CAN USE BUT YOU ARE GONNA PAY FOR ( PLATINUM NOTES ) THERE IS NO FREE DOWNLOAD PROGRAM TO THIS )DIGITAL RECORDINGS HAVE A HIGHER FREQENCY MAINLY ON BASS. ANALOG HAS A WARMER SOUND.ME PERSONALLY I PREFER ANALOG OVER DIGITAL
PLEASE BRING BACK VINYL$$$$$
Posted on Oct 22, 2016
Worked one day and froze up and cut off the next day
You may have to reset it. With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Mar 13, 2014 | RCA Tablets & eReaders
Ddm4000 flashing and crashing
It sounds like it got blasted with ESD, see if you can get it repaired under warrenty.
Feb 16, 2014 | Behringer DDM4000 Digital Pro DJ Mixer...
How do i fix a frozen htc hd7 t-mobile phone?
All you need do is to HARD RESET the phone.
1. Press down the volume up and down button
2. Briefly press the power button still holding down the volume button
3. release the volume button when the screen flash a reset instruction menu, then press volume down butoon to reset your device.
Apr 26, 2013 | HTC HD7 Cell Phone
My girlfriends phone is a pantech burst and it only comes up to the pantech screen and then it does nothing what should I do?
Hard Reset using keys for Burst is as follows:
1. (with phone off) press and hold volume down and power key(when PANTECH appears release power but continue to hold vol down) triangle with android guy will appear.
2. tap "menu key"(button on bottom left) this will bring up Android System Recovery.
3. (using volume keys for up/down and the home key for SELECT) select wipe data/factory reset.
4. scroll down to YES and tap home key again to select.
5. select Reboot and you're all set.
***this will remove ALL DATA(contacts/photos/music files) saved to the phone, will not harm contacts on your SIM or files on your SD card(if you have one)***.
Oct 31, 2012 | Cell Phones
My at&t pantech burst keeps restarting. how can i get it to turn on and not restart?
You have to reset your whole phone. Hold the power button and the volume button down at the same time until Pantech pops up on the screen and when it does let go of the power button but keep holding the down volume button down. When the triangle pops up let go of the volume button and press the menu button. Use the volume button to scroll down to wipe data. Hit the home key.. scroll down again to yes and hit the home key. Hit the home key again on reboot system. That's it ! :)
Oct 20, 2012 | Cell Phones
Ddm4000 freeze up and got to turn it off and turn back on
Freeze up is usually overheating, check your heatsinks and if the compound has dried up.
Dec 15, 2010 | Behringer Ddm4000 5-channel Digital Midi...
Not booting Properly.
have try to reset bios if not u have to reset bios.
Pullcmos cell for 15 seconds from mohter bord also u can reset bios with jumper settigns it is near cmos read carefully on motherbord u can find jumper u can see "clear cmos " on motherbord
May 06, 2009 | Fujitsu Siemens LifeBook E8020 Notebook
Uncontrolling!!
You've either got a short from faulty manufacturing or possibly from moisture entering your unit. Or the wiring may be faulty, if you know how take the unit out and examine the wiring; make sure the wires are all taped with electrical tape and that no bare wires exposed or touching. If everything looks ok then you might as well just exercise the warranty. They come with a 1 year warranty from Dual.
May 20, 2008 | Dual XD-7500 CD Player
UNCONTROLLABLE SURROUND VOLUME
bad solder connections and or dirty controls.
Dec 12, 2006 | Technics SA-AX530 Receiver
Behringer DDM4000 Digital Pro DJ Mixer with Sampler DDM-4000 Logo
151 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
