Question about VXI Corporation VT-90 Digital Voice Recorder
Instructions manual replace batteries
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
Klik radio controlled watch
Why would he need the manual to do that ???
The time is self setting !
and to chage the battery just take out the back cover and slide the pin holding the battery in place, and replace it with the with similar battery...
I will try to find the manual for you..
post back in a second
Jan 09, 2008 | Watches
How to replace the battery on Genie ACSCTG Type 1
http://www.geniecompany.com/support_technical-faq.aspx
Call the number on this link to the company which it seems does not offer owner manuals online--if you have the manual it will have battery replacement instructions and type of battery used.
May 01, 2012 | Genie Company IntelliCode GICT390-1BL...
Misplaced my instruction manual - need to reset all after battery replacement - it's been a great watch
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Most makers advise you to have the battery replaced professonally, so you may not find anything useful in the hand book.
It is usual to shor the battery case to the ac point on the watch using a metal object (e.g. a pair of tweezers), to reset the watch.
Jun 03, 2011 | Timex Expedition 84601 Wristwatch
How do I change the batteries on my WW60X? I can't find my manual but was able to open the battery cover to get the number for the batteries. Now I can't get the batteries out of the scales. ...
Your Instruction Manual is here:
http://www.conaircanada.ca/pdf/en/ibs/en_WW60XC.pdf
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
Mar 10, 2011 | Conair WW60X memory electronic Weight...
Is the battery replaceable on the MB-300?
Unfortunately not. The rechargeable nickel-cadmium is hard-wired and not replaceable. The battery is hazardous waste and must be removed for proper disposal. Instructions for removing the battery from the user manual:
1. Make sure your groomer is unplugged from any outlets so you don't risk an electric shock.
2. Remove side panels/grips
3. Remove the 4 housing screws
4. Pull or gently pry the clipper halves apart, exposing the batteries.
5. Remove batteries from the unit.
6. Twist batteries to break wires. Wires may also be cut.
The user manual has a toll-free phone number to call for disposal instructions in your area: 1-800-822-8837
Feb 24, 2011 | Remington MB-300 Beard Trimmer
Need instructions to take laptop apart to replace bios battery, my laptop is losing time and i think it needs replaced. Can someone tell me how to locate the battery?
Here is the service manual for your laptop courtesy of HP:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00622160/c00622160.pdf
Look in section 6.3 for dissasemly instructions on how to take apart the laptop.
Then go to page 6-51 of the service manual and it shows you a picture of the BIOS Battery as it looks to be in the top cover.
May 30, 2009 | HP Compaq nc6220 Notebook
Cannot reset my SkyScan Atomic clock after changing batteries
Online manual is at link http://skyscan.info/content/manuals/25-model-87315.html
Dec 29, 2008 | SkyScan 86709 Atomic Wall Clock
Replacing the battery
Download the user manual - it has battery removal instructions ----
http://safemanuals.com/user-guide-instructions-owner-manual/REMINGTON/MS3-1000
Nov 28, 2007 | Remington MicroScreen 3-3000 Electric...
VXI Corporation VT-90 Digital Voice Recorder Logo
54 people viewed this question
Top VXI Corporation Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a VXI Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
