Sky box I bought a secondhand skybox nd needs a pin to get into other channels any1 no how to find pin
How do I tune my TV in the kitchen to my Sky box in another room.
Sky box stuck in Stand By on red light Sky Box Guides faq
Sky Troubleshooting faq
either you have it hooked up wrong or skybox doesnt allow 2 screen use,you may need another skybox
May 14, 2015 | Televison & Video
HOW to view sky tv on ..
Hi.
Connect skybox using scartlead, or if you have HD use HDMI lead connection..
Select connection by using the AV (alternate video input) on your remote control--this will switch from freeview to sky.
Happy viewing.
Aug 10, 2014 | Hitachi L32H01 32 in. HD-Ready LCD TV
Sky Remote control
The new remote may not be compatible with your Skybox. The manufacturer probably made some significant changes to the remote in getting to rev. 9 and did not make it reverse compatible with older Skyboxes.
Nov 08, 2013 | Televison & Video
Hi I've recently bought a UMC 40" TV (model: M40/74G-GB-FTCU-UK) and everytime I try to tune it, it just says there is no signal and no channels are found. Everything is connected as it should be....
strange it sounds like there could be more of an issue with the skybox but if you have any RCA cables plug them in and use AV1 or AUX on the tv set however if it has HDMI then plug in a HDMI cable to and from the skybox otherwise check on the back of the skybox and see if there's a channel the TV must be set to
Aug 22, 2017 | Televison & Video
My digivox has lost nearly all channels apart from freeview options nd sky sports 1-4. All movies nd espn gone. I've tried rebooting box,checked emu1004 nd changed frequencys back nd fourth but now back to...
if its a cable box then sorry there is no fix for this problem yet if it is a terrestrial box then delete the scrambled channels and rescan if you factory reset the box then you must install the latest firmware
Apr 26, 2010 | StarTech.com StarView SV431USB 4-port KVM...
How do i connect dvd recorder to tv only receiving sky channels through skybox
If you have two scart sockets on your tv,then connect a scart from av1 on the dvd into the tv,then connect a scart from the sky box into av2 on the dvd,your recording channel on the dvd will be av2.
If you only have on socket on the tv,then connect a scart from av1 on the dvd into the sky box,your recording channel will be av1,connected like this you may have to turn off the sky to watch dvd`s.
Oct 30, 2009 | Televison & Video
How do I connect my sky,dvd,vcr and tv together so that I can record a sky progrmme on a video?
You need to connect a SCART lead from the video output of the skybox to the SCART input on your video recorder.
Be aware that you can only record what you are watching, and if you are out the skybox needs to be on and on the correct channel
Nov 19, 2008 | Televison & Video
42'' LG Plasma bought in Australia doesn't work in UK?
Find out if Australia uses a different standard of HD programming than Guernsey or not since it's not picking up any channels at all with an attenna. Does the skybox use only scart connections and that's how your small lcd is connected to it?
Nov 14, 2008 | LG 42LC2D 42 in. LCD HDTV
WIRELESS LINK FOR SKY+ BOX
your sky box should have 2 scarts ;input and tv.I have one so as can watch sky upstairs and on projector screen.
reciever sender is in av on tv upstairs sender downstairs is in scart next to tv scart on skybox scart lead in tv scart connected to av on tv.some senders need to be turned on.when you plug in adapter and led is on doesnt necessarily mean sender is on .is this a new sender with instructions youve bought
Jan 01, 2008 | Acer TravelMate 2300 Notebook
Televison & Video Logo
358 people viewed this question
Top Televison & Video Experts
Electro Med Services...
